path: root/cpukit/libmisc/shell/main_cat.c (follow)
* 2008-02-27 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-02-271-5/+10
| | | | | | | | | | | | | | | | | | | | | | | * libmisc/shell/cat_file.c, libmisc/shell/main_alias.c, libmisc/shell/main_blksync.c, libmisc/shell/main_cat.c, libmisc/shell/main_chdir.c, libmisc/shell/main_chmod.c, libmisc/shell/main_chroot.c, libmisc/shell/main_cpuuse.c, libmisc/shell/main_date.c, libmisc/shell/main_help.c, libmisc/shell/main_id.c, libmisc/shell/main_logoff.c, libmisc/shell/main_ls.c, libmisc/shell/main_mallocinfo.c, libmisc/shell/main_mdump.c, libmisc/shell/main_medit.c, libmisc/shell/main_mfill.c, libmisc/shell/main_mkdir.c, libmisc/shell/main_mmove.c, libmisc/shell/main_mount.c, libmisc/shell/main_mount_nfs.c, libmisc/shell/main_msdosfmt.c, libmisc/shell/main_mwdump.c, libmisc/shell/main_perioduse.c, libmisc/shell/main_pwd.c, libmisc/shell/main_rm.c, libmisc/shell/main_rmdir.c, libmisc/shell/main_stackuse.c, libmisc/shell/main_tty.c, libmisc/shell/main_umask.c, libmisc/shell/main_unmount.c, libmisc/shell/main_whoami.c, libmisc/shell/shell.h: Clean up done while writing documentation. Some command improvements such as date now allows setting of the current TOD. Often commands did not use stdout/stderr per expectations and did not return -1 on an error.
* 2007-12-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2007-12-171-1/+1
| | | | | | | | | | | | | | | | | | | | | | | * libmisc/shell/main_alias.c, libmisc/shell/main_blksync.c, libmisc/shell/main_cat.c, libmisc/shell/main_cd.c, libmisc/shell/main_chdir.c, libmisc/shell/main_chmod.c, libmisc/shell/main_chroot.c, libmisc/shell/main_cpuuse.c, libmisc/shell/main_date.c, libmisc/shell/main_dir.c, libmisc/shell/main_exit.c, libmisc/shell/main_help.c, libmisc/shell/main_id.c, libmisc/shell/main_logoff.c, libmisc/shell/main_ls.c, libmisc/shell/main_mallocinfo.c, libmisc/shell/main_mdump.c, libmisc/shell/main_medit.c, libmisc/shell/main_mfill.c, libmisc/shell/main_mkdir.c, libmisc/shell/main_mmove.c, libmisc/shell/main_mount.c, libmisc/shell/main_mount_ftp.c, libmisc/shell/main_mount_msdos.c, libmisc/shell/main_mount_nfs.c, libmisc/shell/main_mount_tftp.c, libmisc/shell/main_msdosfmt.c, libmisc/shell/main_mwdump.c, libmisc/shell/main_pwd.c, libmisc/shell/main_rm.c, libmisc/shell/main_rmdir.c, libmisc/shell/main_stackuse.c, libmisc/shell/main_tty.c, libmisc/shell/main_umask.c, libmisc/shell/main_unmount.c, libmisc/shell/main_whoami.c, libmisc/shell/shell_cmdset.c, libmisc/shell/shellconfig.h: Change rtems_Shell_ to rtems_shell_.
* 2007-12-17 Chris Johns <chrisj@rtems.org>Chris Johns2007-12-171-4/+4
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * libnetworking/rtems/tftp.h: Provide a decl to the TFTP file system opts table. * libnetworking/rtems/ftpfs.h: Provide a decl to the FTP file system opts table. * libmisc/Makefile.am: Add the mount command and supporting files. * libmisc/preinstall.am: Rebuilt. * libmisc/shell/cat_file.c, libmisc/shell/cmds.c, libmisc/shell/main_alias.c, libmisc/shell/main_cat.c, libmisc/shell/main_cd.c, libmisc/shell/main_chdir.c, libmisc/shell/main_chmod.c, libmisc/shell/main_chroot.c, libmisc/shell/main_cpuuse.c, libmisc/shell/main_date.c, libmisc/shell/main_dir.c, libmisc/shell/main_exit.c, libmisc/shell/main_help.c, libmisc/shell/main_id.c, libmisc/shell/main_logoff.c, libmisc/shell/main_ls.c, libmisc/shell/main_mallocdump.c, libmisc/shell/main_mdump.c, libmisc/shell/main_medit.c, libmisc/shell/main_mfill.c, libmisc/shell/main_mkdir.c, libmisc/shell/main_mmove.c, libmisc/shell/main_mwdump.c, libmisc/shell/main_pwd.c, libmisc/shell/main_rm.c, libmisc/shell/main_rmdir.c, libmisc/shell/main_stackuse.c, libmisc/shell/main_tty.c, libmisc/shell/main_umask.c, libmisc/shell/main_whoami.c, libmisc/shell/shell.c, libmisc/shell/shell_cmdset.c, libmisc/shell/shell_makeargs.c, libmisc/shell/str2int.c, libmisc/shell/write_file.c: Move all shell_* types, variables and functions to rtems_shell_* to avoid namespace clashes with applications. The is an RTEMS shell after all. * libmisc/shell/shell.h, libmisc/shell/internal.h, libmisc/shell/shellconfig.h: Move all shell_* types, variables and functions to rtems_shell_* to avoid namespace clashes with applications. Add the mount command supporting types. * libmisc/shell/main_mount.c, libmisc/shell/main_mount_ftp.c, libmisc/shell/main_mount_msdos.c, libmisc/shell/main_mount_nfs.c, libmisc/shell/main_mount_tftp.c: New.
* 2007-12-14 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2007-12-141-0/+55
* libmisc/Makefile.am, libmisc/shell/cat_file.c, libmisc/shell/shell_makeargs.c, libmisc/shell/shellconfig.h: Rename cmd_XXX.c to main_XXX.c. Add cpuuse and stackuse commands. * libmisc/shell/main_alias.c, libmisc/shell/main_cat.c, libmisc/shell/main_cd.c, libmisc/shell/main_chdir.c, libmisc/shell/main_chmod.c, libmisc/shell/main_chroot.c, libmisc/shell/main_cpuuse.c, libmisc/shell/main_date.c, libmisc/shell/main_dir.c, libmisc/shell/main_exit.c, libmisc/shell/main_help.c, libmisc/shell/main_id.c, libmisc/shell/main_logoff.c, libmisc/shell/main_ls.c, libmisc/shell/main_mallocdump.c, libmisc/shell/main_mdump.c, libmisc/shell/main_medit.c, libmisc/shell/main_mfill.c, libmisc/shell/main_mkdir.c, libmisc/shell/main_mmove.c, libmisc/shell/main_mwdump.c, libmisc/shell/main_pwd.c, libmisc/shell/main_rm.c, libmisc/shell/main_rmdir.c, libmisc/shell/main_stackuse.c, libmisc/shell/main_tty.c, libmisc/shell/main_umask.c, libmisc/shell/main_whoami.c: New files. * libmisc/shell/cmd_alias.c, libmisc/shell/cmd_cat.c, libmisc/shell/cmd_cd.c, libmisc/shell/cmd_chdir.c, libmisc/shell/cmd_chmod.c, libmisc/shell/cmd_chroot.c, libmisc/shell/cmd_date.c, libmisc/shell/cmd_dir.c, libmisc/shell/cmd_exit.c, libmisc/shell/cmd_help.c, libmisc/shell/cmd_id.c, libmisc/shell/cmd_logoff.c, libmisc/shell/cmd_ls.c, libmisc/shell/cmd_mallocdump.c, libmisc/shell/cmd_mdump.c, libmisc/shell/cmd_medit.c, libmisc/shell/cmd_mfill.c, libmisc/shell/cmd_mkdir.c, libmisc/shell/cmd_mmove.c, libmisc/shell/cmd_mwdump.c, libmisc/shell/cmd_pwd.c, libmisc/shell/cmd_rm.c, libmisc/shell/cmd_rmdir.c, libmisc/shell/cmd_tty.c, libmisc/shell/cmd_umask.c, libmisc/shell/cmd_whoami.c: Removed.
