path: root/cpukit/libmisc/shell/extern-cp.h (follow)
* basdefs.h: Add and use RTEMS_UNUSEDSebastian Huber2015-10-261-0/+1
* 2008-07-29 Chris Johns <chrisj@rtems.org>Chris Johns2008-07-291-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * libblock/Makefile.am: Removed src/show_bdbuf.c. * libblock/src/show_bdbuf.c: Removed. * libblock/include/rtems/bdbuf.h, cpukit/libblock/src/bdbuf.c: Rewritten the bdbuf code. Remove pre-emption disable, score access, fixed many bugs and increased performance. * libblock/include/rtems/blkdev.h: Added RTEMS_BLKDEV_CAPABILITIES block device request. Cleaned up comments. Added block and user fields to the sg buffer request. Move to rtems_* namespace. * libblock/include/rtems/diskdevs.h, cpukit/libblock/src/diskdevs.c: Move to rtems_* namespace. Add a capabilities field for drivers. Change rtems_disk_lookup to rtems_disk_obtain to match the release call. You do not lookup and release a disk, you obtain and release a disk. * libblock/include/rtems/ide_part_table.h, libblock/include/rtems/ramdisk.h, libblock/src/ide_part_table.c: Move to rtems_* namespace. * libblock/include/rtems/nvdisk.h: Formatting change. * libblock/src/blkdev.c: Move to rtems_* namespace. Change rtems_disk_lookup to rtems_disk_obtain * libblock/src/flashdisk.c: Move to rtems_* namespace. Use the new support for the block number in the scatter/grather request struct. This allows non-continuous buffer requests for those drivers that can support increasing performance. * libblock/src/nvdisk.c: Move to rtems_* namespace. Removed warnings. Added better error checking. Fixed some comments. * libblock/src/ramdisk.c: Move to rtems_* namespace. Added some trace functions to help debugging upper layers. Use the new support for the block number in the scatter/grather request struct. This allows non-continuous buffer requests for those drivers that can support increasing performance. * libfs/src/dosfs/fat.c, libfs/src/dosfs/fat.h: Use new chains API. Removed temporary hack and changed set_errno_and_return_minus_one to rtems_set_errno_and_return_minus_one. Move fat_buf_access from header and stopped it being inlined. Updated to libblock changes. * libfs/src/dosfs/fat_fat_operations.c, libfs/src/dosfs/fat_file.c, libfs/src/dosfs/msdos_create.c, libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_eval.c, libfs/src/dosfs/msdos_file.c, libfs/src/dosfs/msdos_format.c, libfs/src/dosfs/msdos_free.c, libfs/src/dosfs/msdos_initsupp.c, libfs/src/dosfs/msdos_misc.c, libfs/src/dosfs/msdos_mknod.c: Use new chains API. Removed temporary hack and changed set_errno_and_return_minus_one to rtems_set_errno_and_return_minus_one. Updated to libblock changes. * libmisc/Makefile.am: Add new ls and rm command files. * libmisc/shell/cmp-ls.c, libmisc/shell/extern-ls.h, libmisc/shell/filemode.c, libmisc/shell/print-ls.c, libmisc/shell/pwcache.c, libmisc/shell/utils-ls.c, libmisc/shell/vis.c, shell/vis.h: New. * libmisc/shell/extern-cp.h, libmisc/shell/main_cp.c, libmisc/shell/utils-cp.c: Fixed the usage call bug. * libmisc/shell/main_blksync.c: Updated to the new block IO ioctl command. * libmisc/shell/main_ls.c, libmisc/shell/main_rm.c: Updated to BSD commands with more features. * score/src/coremutex.c: Fix the strick order mutex code. * libmisc/shell/shell.c: Change shell tasks mode to be timeslice and no ASR. * sapi/include/confdefs.h: Change ata_driver_task_priority to rtems_ata_driver_task_priority. Add the new BD buf cache parameters with defaults. * score/src/interr.c: Do not return if the CPU halt call returns.
* 2008-04-12 Chris Johns <chrisj@rtems.org>Chris Johns2008-04-111-4/+8
| | | | | | | | | | | | * libmisc/shell/shell.c, libmisc/shell/shell.h, libmisc/shell/shell_script.c: Add support to echo the commands to stdout. This is useful with the -v script option to show commands as the run. Also added support to chdir to the directory the task invoking the script is in. * libmisc/shell/extern-cp.h, libmisc/shell/main_cp.c, libmisc/shell/utils-cp.c: Update tro the latest FreeBSD version. * libcsupport/Makefile.am, libcsupport/src/fchown.c: Add fchown support.
* 2007-12-22 Chris Johns <chrisj@rtems.org>Chris Johns2007-12-221-0/+87
* configure.ac: fixed bug that always enabled strict order mutexes. * score/inline/rtems/score/coremutex.inl: Fixed coding standard. * score/src/coremutex.c: Add the holder's thread to the lock_mutex list if the mutex is initialised locked. * libnetworking/rtems/rtems_glue.c: Changed semaphore error message to show the error is an rtems-net error. * libmisc/monitor/mon-network.c: Removed warnings. * telnetd/icmds.c: Changed shell_* to rtems_shell_*. * score/Makefile.am: Fixed typo that stopped 'make tags' working. * libmisc/shell/err.c, libmisc/shell/err.h, libmisc/shell/errx.c, libmisc/shell/extern-cp.h, libmisc/shell/fts.c, libmisc/shell/fts.h, libmisc/shell/main_cp.c, libmisc/shell/utils-cp.c, libmisc/shell/verr.c, libmisc/shell/verrx.c, libmisc/shell/vwarn.c, libmisc/shell/vwarnx.c, libmisc/shell/warn.c, libmisc/shell/warnx.c: New. Ported from BSD. * libmisc/shell/shellconfig.h: Add the cp command. * libmisc/Makefile.am: Add the new files to the shell. * libmisc/shell/shell.c, libmisc/shell/shell.h: Add scripting support. * libblock/src/flashdisk.c: Fixed disk drive count size setting bug.
