path: root/cpukit/libmisc/shell/errx.c (follow)
* Include "config.h".Ralf Corsepius2008-08-211-0/+4
* 2007-12-22 Chris Johns <chrisj@rtems.org>Chris Johns2007-12-221-0/+60
* configure.ac: fixed bug that always enabled strict order mutexes. * score/inline/rtems/score/coremutex.inl: Fixed coding standard. * score/src/coremutex.c: Add the holder's thread to the lock_mutex list if the mutex is initialised locked. * libnetworking/rtems/rtems_glue.c: Changed semaphore error message to show the error is an rtems-net error. * libmisc/monitor/mon-network.c: Removed warnings. * telnetd/icmds.c: Changed shell_* to rtems_shell_*. * score/Makefile.am: Fixed typo that stopped 'make tags' working. * libmisc/shell/err.c, libmisc/shell/err.h, libmisc/shell/errx.c, libmisc/shell/extern-cp.h, libmisc/shell/fts.c, libmisc/shell/fts.h, libmisc/shell/main_cp.c, libmisc/shell/utils-cp.c, libmisc/shell/verr.c, libmisc/shell/verrx.c, libmisc/shell/vwarn.c, libmisc/shell/vwarnx.c, libmisc/shell/warn.c, libmisc/shell/warnx.c: New. Ported from BSD. * libmisc/shell/shellconfig.h: Add the cp command. * libmisc/Makefile.am: Add the new files to the shell. * libmisc/shell/shell.c, libmisc/shell/shell.h: Add scripting support. * libblock/src/flashdisk.c: Fixed disk drive count size setting bug.
