These modifications were required by hand after running the script.
In some cases, the file names did not match patterns. In others,
the format of the file did not match any common patterns.
* libmisc/Makefile.am: Install serdbg.h, serdbgcnf.h,
termios_printk.h, termios_printk_cnf.h to $(includedir)/rtems.
* libmisc/serdbg/serdbg.c: Include <rtems/serdbg.h> instead of
<serdbg.h>.
* libmisc/serdbg/serdbgio.c: Include <rtems/serdbg.h> instead of
<serdbg.h>.
* libmisc/serdbg/termios_printk.c: Include <rtems/termios_printk.h>
instead of <termios_printk.h>.
* libmisc/capture/capture-cli.c, libmisc/capture/capture.c,
libmisc/capture/capture.h, libmisc/cpuuse/cpuuse.c,
libmisc/devnull/devnull.c, libmisc/fsmount/fsmount.h,
libmisc/monitor/mon-config.c, libmisc/monitor/mon-dname.c,
libmisc/monitor/mon-driver.c, libmisc/monitor/mon-extension.c,
libmisc/monitor/mon-itask.c, libmisc/monitor/mon-monitor.c,
libmisc/monitor/mon-mpci.c, libmisc/monitor/mon-object.c,
libmisc/monitor/mon-prmisc.c, libmisc/monitor/mon-queue.c,
libmisc/monitor/mon-server.c, libmisc/monitor/mon-symbols.c,
libmisc/monitor/monitor.h, libmisc/monitor/symbols.h,
libmisc/mw-fb/mw_uid.c, libmisc/rtmonuse/rtmonuse.c,
libmisc/serdbg/serdbg.h, libmisc/serdbg/serdbgio.c,
libmisc/serdbg/termios_printk.c, libmisc/serdbg/termios_printk.h,
libmisc/shell/shell.c, libmisc/shell/shell.h, libmisc/stackchk/check.c,
libmisc/stackchk/internal.h: Convert to using c99 fixed size types.
* cpuuse/cpuuse.c, cpuuse/cpuuse.h, devnull/devnull.c,
devnull/devnull.h, dummy/dummy.c, dumpbuf/dumpbuf.c,
dumpbuf/dumpbuf.h, fsmount/fsmount.c, fsmount/fsmount.h,
serdbg/serdbgio.c, serdbg/termios_printk.c, stackchk/check.c,
stackchk/internal.h, stackchk/stackchk.h, untar/untar.c,
untar/untar.h: URL for license changed.
* capture/capture-cli.c: Add config-header support.
* capture/capture.c: Add config-header support.
* cpuuse/cpuuse.c: Add config-header support.
* devnull/devnull.c: Add config-header support.
* dummy/dummy.c: Add config-header support.
* dumpbuf/dumpbuf.c: Add config-header support.
* monitor/mon-command.c: Add config-header support.
* monitor/mon-config.c: Add config-header support.
* monitor/mon-dname.c: Add config-header support.
* monitor/mon-driver.c: Add config-header support.
* monitor/mon-extension.c: Add config-header support.
* monitor/mon-itask.c: Add config-header support.
* monitor/mon-manager.c: Add config-header support.
* monitor/mon-monitor.c: Add config-header support.
* monitor/mon-mpci.c: Add config-header support.
* monitor/mon-object.c: Add config-header support.
* monitor/mon-prmisc.c: Add config-header support.
* monitor/mon-queue.c: Add config-header support.
* monitor/mon-server.c: Add config-header support.
* monitor/mon-symbols.c: Add config-header support.
* monitor/mon-task.c: Add config-header support.
* mw-fb/mw_fb.c: Add config-header support.
* mw-fb/mw_uid.c: Add config-header support.
* rtmonuse/rtmonuse.c: Add config-header support.
* serdbg/serdbg.c: Add config-header support.
* serdbg/serdbgio.c: Add config-header support.
* serdbg/termios_printk.c: Add config-header support.
* shell/cmds.c: Add config-header support.
* stackchk/check.c: Add config-header support.
* untar/untar.c: Add config-header support.
* capture/Makefile.am: Remove AUTOMAKE_OPTIONS.
* serdbg/Makefile.am: Remove AUTOMAKE_OPTIONS.
* serdbg/serdbgio.c: Add #include <unistd.h>.
* shell/Makefile.am: Add RTEMS_LIBSHELL conditional.
* wrapup/Makefile.am: Add RTEMS_LIBSHELL conditional.
* configure.ac: Check for stdio assignments.
* With the addition of serdbg, the standard polled I/O functions
for gdbstub and/or printk are optionally routed to any termios-aware
device driver, that supports polled mode. See libmisc/serdbg/README.
* serdbg/Makefile.am, serdbg/README, serdbg/serdbg.c, serdbg/serdbg.h,
serdbg/serdbgcnf.h, serdbg/serdbgio.c, serdbg/termios_printk.c,
serdbg/termios_printk.h, serdbg/termios_printk_cnf.h,
serdbg/.cvsignore: New files.
* configure.ac, Makefile.am, wrapup/Makefile.am: Modified to
reflect addition.
