Move implementation specific parts of extension.h and extension.inl into
new header file extensionimpl.h. The extension.h contains now only the
application visible API.
Move implementation specific parts of pthread.h and pthread.inl into new
header file pthreadimpl.h. The pthread.h contains now only the
Move implementation specific parts of message.h and message.inl into new
header file messageimpl.h. The message.h contains now only the
Move implementation specific parts of sem.h and sem.inl into new header
file semimpl.h. The sem.h contains now only the application visible
API.
Change event implementation to enable reuse for system events.
The work areas (RTEMS work space and C program heap) will be initialized
now in a separate step and are no longer part of
rtems_initialize_data_structures(). Initialization is performed with
tables of Heap_Area entries. This allows usage of scattered memory
areas present on various small scale micro-controllers.
The sbrk() support API changes also. The bsp_sbrk_init() must now deal
with a minimum size for the first memory chunk to take the configured
work space size into account.
* libmisc/monitor/mon-network.c: Include <rtems/monitor.h>.
* libmisc/monitor/mon-object.c:
Make rtems_monitor_object_canonical_next_remote,
rtems_monitor_object_dump_1, rtems_monitor_object_dump_all static.
* libmisc/monitor/mon-prmisc.c:
Make rtems_monitor_dump_assoc_bitfield static.
* libmisc/monitor/mon-symbols.c:
Make rtems_monitor_symbol_dump_all static.
PR 1941/cpukit
* libmisc/monitor/mon-server.c, score/include/rtems/system.h: Remove
use of RTEMS_offset() in favor of standard offsetof(). This was
undocumented and there was only one internal use. Change noted in
4.11 release notes.
* libmisc/monitor/mon-monitor.c (rtems_monitor_wakeup):
Remove unused var "status" (Avoid warning).
* libmisc/monitor/mon-editor.c (rtems_monitor_task):
Comment out unused vars "debugee", "rp", "fp".
* libmisc/monitor/mon-monitor.c: Removed "exit" and "quit" commands to
avoid confusion. They were an alias to the "fatal" command.
* libfs/src/dosfs/fat_file.c, libmisc/monitor/monitor.h,
score/cpu/m68k/rtems/score/cpu.h: Remove stray spaces from unsigned32
to uint32_t conversion.
* include/rtems/irq-extension.h: Documentation.
* libmisc/monitor/mon-prmisc.c: Fix for multiprocessing configuration.
* libmisc/monitor/mon-monitor.c: Fixed broken monitor command list.
* libmisc/monitor/mon-monitor.c: Move node code into multiprocessing
ifdef.
* libmisc/monitor/mon-symbols.c: Fix length of buffer passed to
strncpy() so there is room for a NULL terminator.
PR 1559/misc
Coverity Id 16
* libmisc/monitor/mon-editor.c: Fix buffer overflow.
to print addresses.
* libmisc/monitor/mon-monitor.c, libmisc/monitor/monitor.h: Add const
to fix warning. Spacing.
* libmisc/monitor/mon-monitor.c, libmisc/monitor/monitor.h: Add reset
command.
* ftpd/ftpd.c, httpd/asp.c, httpd/ejparse.c, httpd/emfdb.c,
httpd/misc.c, httpd/um.c, httpd/webs.c, httpd/websuemf.c,
libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_format.c,
libfs/src/dosfs/msdos_misc.c, libfs/src/nfsclient/src/nfs.c,
libmisc/capture/capture-cli.c, libmisc/monitor/mon-network.c,
libmisc/shell/hexdump-odsyntax.c, libmisc/shell/main_ifconfig.c,
libmisc/shell/shell.c, libmisc/shell/shell_makeargs.c,
libmisc/uuid/parse.c, libnetworking/libc/gethostbydns.c,
libnetworking/libc/gethostbyht.c, libnetworking/libc/gethostnamadr.c,
libnetworking/libc/getnetnamadr.c, libnetworking/libc/inet_addr.c,
libnetworking/libc/inet_network.c, libnetworking/libc/res_debug.c,
libnetworking/libc/res_init.c, libnetworking/libc/res_query.c,
libnetworking/rtems/rtems_mii_ioctl.c,
score/src/objectgetnameasstring.c: Readdress use of ctype methods per
recommendation from D.J. Delorie on the newlib mailing list. We
should pass an unsigned char into these methods.
* ftpd/ftpd.c, httpd/uemf.c, httpd/um.c, httpd/webs.c,
httpd/websuemf.c, libblock/src/diskdevs.c,
libmisc/uuid/parse.c, libnetworking/lib/ftpfs.c,
libnetworking/libc/gethostbyht.c, libnetworking/libc/getnetnamadr.c,
score/src/objectgetnameasstring.c: Fix warnings for ctype methods.
Coverity Id 23
* libmisc/monitor/mon-monitor.c: Add fclose() of file.
* libmisc/monitor/mon-editor.c: Eliminate RTEMS_UNIX.
* libmisc/monitor/mon-driver.c: Fix warning if
defined(RTEMS_USE_16_BIT_OBJECT).
* libmisc/monitor/mon-prmisc.c: Fix warning if
* libblock/src/ide_part_table.c: Fixed NULL pointer access.
* libmisc/monitor/mon-command.c, libmisc/monitor/mon-editor.c,
libmisc/monitor/mon-monitor.c, libmisc/monitor/monitor.h,
libmisc/shell/cmds.c: The list of registered monitor commands is now
private and only accessible via a lookup and iterate function.
* libmisc/serdbg/termios_printk.c, libmisc/serdbg/termios_printk.h:
Fixed incompatible return value.
* libmisc/cpuuse/cpuusagereport.c: Changed output format.
* libmisc/Makefile.am, libmisc/monitor/mon-editor.c: New file.
* libmisc/capture/capture-cli.c, libmisc/monitor/mon-command.c,
libmisc/monitor/mon-monitor.c, libmisc/monitor/mon-object.c,
libmisc/monitor/mon-prmisc.c, libmisc/monitor/mon-symbols.c,
libmisc/monitor/monitor.h, libmisc/shell/cat_file.c,
libmisc/shell/cmds.c, libmisc/shell/internal.h,
libmisc/shell/main_help.c, libmisc/shell/shell.c,
libmisc/shell/shell.h, libmisc/shell/shell_cmdset.c,
libmisc/shell/shell_getchar.c, libmisc/shell/str2int.c: Various global
data is now read only. Added 'const' qualifier to many pointer
parameters. It is no longer possible to remove monitor commands.
Moved monitor line editor into a separate file to avoid unnecessary
dependencies.
* libmisc/monitor/mon-config.c: Configuration table entry
work_space_size was not removed.
* itron/include/rtems/itron/itronapi.h, libmisc/capture/capture.c,
libmisc/monitor/mon-config.c, libmisc/monitor/mon-driver.c,
libmisc/monitor/mon-itask.c, libmisc/monitor/mon-mpci.c,
posix/include/rtems/posix/config.h,
posix/include/rtems/posix/posixapi.h,
rtems/include/rtems/rtems/config.h,
rtems/include/rtems/rtems/rtemsapi.h, rtems/src/taskinitusers.c,
sapi/include/confdefs.h, sapi/include/rtems/config.h,
sapi/include/rtems/init.h, sapi/src/exinit.c, sapi/src/itronapi.c,
sapi/src/posixapi.c, sapi/src/rtemsapi.c, score/src/isr.c,
score/src/thread.c, score/src/threadcreateidle.c,
score/src/threadstackallocate.c, score/src/threadstackfree.c,
score/src/wkspace.c: Eliminate pointers to API configuration tables
in the main configuration table. Reference the main configuration
table and the API configuration tables directly using the confdefs.h
version rather than obtaining a pointer to it. This eliminated some
variables, a potential fatal error, some unnecessary default
configuration structures. Overall, about a 4.5% reduction in the code
size for minimum and hello on the SPARC.
* libmisc/monitor/mon-monitor.c, rtems/include/rtems/rtems/types.h: Do
not have fp context type when no hardware or software floating point
is available.
* libcsupport/include/rtems/libio_.h, libcsupport/src/libio_sockets.c,
libfs/src/dosfs/fat.h, libfs/src/dosfs/msdos.h,
libfs/src/imfs/deviceio.c, libmisc/monitor/mon-monitor.c,
libmisc/monitor/mon-object.c, libmisc/monitor/mon-symbols.c,
libmisc/monitor/monitor.h, libmisc/stackchk/internal.h,
rtems/inline/rtems/rtems/part.inl, score/include/rtems/system.h,
score/include/rtems/score/bitfield.h, score/src/mpci.c,
score/src/objectextendinformation.c, score/src/threadmp.c: Remove
extraneous spaces.
* libcsupport/include/rtems/libcsupport.h, libcsupport/src/scandir.c,
libmisc/cpuuse/cpuusagereset.c, libmisc/monitor/mon-monitor.c,
libmisc/serdbg/serdbg.c, libmisc/serdbg/serdbg.h,
libnetworking/netinet/in_cksum_powerpc.h, shttpd/compat_rtems.h: Fix
warnings.
