path: root/cpukit/libmisc/monitor/mon-server.c (follow)
* Cleaned up as part of adding the Monitor test.Joel Sherrill1997-09-211-1/+1
* casts added to numerous arguments, prototypes corrected, andJoel Sherrill1996-09-181-0/+1
| | | | proper include files added.
* updates from Tony BennettJoel Sherrill1996-04-221-4/+1
* Update from Tony Bennett (tbennett@divnc.com)Joel Sherrill1996-01-171-4/+4
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-1/+1
* Numerous miscellaneous features incorporated from Tony BennettJoel Sherrill1995-08-171-0/+305
(tbennett@divnc.com) including the following major additions: + variable length messages + named devices + debug monitor + association tables/variables
