* libmisc/monitor/mon-extension.c, libmisc/monitor/mon-itask.c,
libmisc/monitor/mon-part.c, libmisc/monitor/mon-prmisc.c,
libmisc/monitor/mon-queue.c, libmisc/monitor/mon-region.c,
libmisc/monitor/mon-sema.c, libmisc/monitor/mon-task.c,
libmisc/monitor/monitor.h: Use rtems_object_get_name() instead of
internal routine. This makes it possible to also print string names
of POSIX objects. Adjust task report to realign since we can have
longer names.
* libmisc/capture/capture-cli.c, libmisc/cpuuse/cpuuse.c,
libmisc/dumpbuf/dumpbuf.c, libmisc/fsmount/fsmount.c,
libmisc/monitor/mon-command.c, libmisc/monitor/mon-config.c,
libmisc/monitor/mon-dname.c, libmisc/monitor/mon-driver.c,
libmisc/monitor/mon-monitor.c, libmisc/monitor/mon-mpci.c,
libmisc/monitor/mon-object.c, libmisc/monitor/mon-prmisc.c,
libmisc/monitor/mon-queue.c, libmisc/monitor/mon-symbols.c,
libmisc/monitor/mon-task.c, libmisc/rtmonuse/rtmonuse.c,
libmisc/shell/cmds.c, libmisc/shell/shell.c, libmisc/shell/shell.h,
libmisc/stackchk/check.c, libmisc/untar/untar.c: Use
fprintf(stdout,...) instead of printf.
* libmisc/capture/capture-cli.c, libmisc/capture/capture.c,
libmisc/capture/capture.h, libmisc/cpuuse/cpuuse.c,
libmisc/devnull/devnull.c, libmisc/fsmount/fsmount.h,
libmisc/monitor/mon-config.c, libmisc/monitor/mon-dname.c,
libmisc/monitor/mon-driver.c, libmisc/monitor/mon-extension.c,
libmisc/monitor/mon-itask.c, libmisc/monitor/mon-monitor.c,
libmisc/monitor/mon-mpci.c, libmisc/monitor/mon-object.c,
libmisc/monitor/mon-prmisc.c, libmisc/monitor/mon-queue.c,
libmisc/monitor/mon-server.c, libmisc/monitor/mon-symbols.c,
libmisc/monitor/monitor.h, libmisc/monitor/symbols.h,
libmisc/mw-fb/mw_uid.c, libmisc/rtmonuse/rtmonuse.c,
libmisc/serdbg/serdbg.h, libmisc/serdbg/serdbgio.c,
libmisc/serdbg/termios_printk.c, libmisc/serdbg/termios_printk.h,
libmisc/shell/shell.c, libmisc/shell/shell.h, libmisc/stackchk/check.c,
libmisc/stackchk/internal.h: Convert to using c99 fixed size types.
* capture/capture-cli.c: Add config-header support.
* capture/capture.c: Add config-header support.
* cpuuse/cpuuse.c: Add config-header support.
* devnull/devnull.c: Add config-header support.
* dummy/dummy.c: Add config-header support.
* dumpbuf/dumpbuf.c: Add config-header support.
* monitor/mon-command.c: Add config-header support.
* monitor/mon-config.c: Add config-header support.
* monitor/mon-dname.c: Add config-header support.
* monitor/mon-driver.c: Add config-header support.
* monitor/mon-extension.c: Add config-header support.
* monitor/mon-itask.c: Add config-header support.
* monitor/mon-manager.c: Add config-header support.
* monitor/mon-monitor.c: Add config-header support.
* monitor/mon-mpci.c: Add config-header support.
* monitor/mon-object.c: Add config-header support.
* monitor/mon-prmisc.c: Add config-header support.
* monitor/mon-queue.c: Add config-header support.
* monitor/mon-server.c: Add config-header support.
* monitor/mon-symbols.c: Add config-header support.
* monitor/mon-task.c: Add config-header support.
* mw-fb/mw_fb.c: Add config-header support.
* mw-fb/mw_uid.c: Add config-header support.
* rtmonuse/rtmonuse.c: Add config-header support.
* serdbg/serdbg.c: Add config-header support.
* serdbg/serdbgio.c: Add config-header support.
* serdbg/termios_printk.c: Add config-header support.
* shell/cmds.c: Add config-header support.
* stackchk/check.c: Add config-header support.
* untar/untar.c: Add config-header support.
+ variable length messages
+ named devices
+ debug monitor
