* | monitor: Add const qualifier | Sebastian Huber | 2012-11-07 | 1 | -2/+2 |
* | Use rtems_monitor_dump_addr instead of rtems_monitor_dump_hex | Ralf Corsepius | 2010-04-12 | 1 | -1/+1 |
| | | | | to print addresses. | ||||
* | Whitespace removal. | Ralf Corsepius | 2009-11-29 | 1 | -1/+1 |
* | Add __attribute__((unused)) to unused function args. | Ralf Corsepius | 2009-01-02 | 1 | -2/+2 |
* | Convert to using "bool". | Ralf Corsepius | 2008-09-01 | 1 | -2/+2 |
* | Include "config.h". | Ralf Corsepius | 2008-08-21 | 1 | -0/+4 |
* | 2008-07-23 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-07-23 | 1 | -1/+1 |
| | | | | | | | | | | | * libmisc/monitor/mon-extension.c, libmisc/monitor/mon-itask.c, libmisc/monitor/mon-part.c, libmisc/monitor/mon-prmisc.c, libmisc/monitor/mon-queue.c, libmisc/monitor/mon-region.c, libmisc/monitor/mon-sema.c, libmisc/monitor/mon-task.c, libmisc/monitor/monitor.h: Use rtems_object_get_name() instead of internal routine. This makes it possible to also print string names of POSIX objects. Adjust task report to realign since we can have longer names. | ||||
* | Added osmonweb support functionality to monitor | Thomas Doerfler | 2007-09-05 | 1 | -0/+68 |
