path: root/cpukit/libmisc/monitor/mon-object.c (follow)
* Added --disable-multiprocessing flag and modified a lot of files to makeJoel Sherrill1998-11-231-0/+8
| | | | it work.
* Cleaned up as part of adding the Monitor test.Joel Sherrill1997-09-211-3/+1
* casts added to numerous arguments, prototypes corrected, andJoel Sherrill1996-09-181-0/+2
| | | | proper include files added.
* updates from Tony BennettJoel Sherrill1996-04-221-4/+1
* As part of reducing visibility into rtems and hiding the .inl filesJoel Sherrill1996-03-061-0/+1
| | | | | from the application code, this file required more visibility than is given by default to application code.
* Update from Tony Bennett (tbennett@divnc.com)Joel Sherrill1996-01-171-34/+27
* Minor bug fixes to get all targets compilable and running. TheJoel Sherrill1995-09-191-1/+1
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-1/+4
* Moved _Thread_Information -> _RTEMS_tasks_Information.Joel Sherrill1995-08-231-1/+1
| | | | | | | Added a table of object information control blocks. Modified _Thread_Get so it looks up a thread regardless of which thread management "entity" (manager, internal, etc) actually "owns" it.
* + Added object type field to object id.Joel Sherrill1995-08-181-3/+7
| | | | | | | | | | + Added name pointer to Object_Control. + Modified Object Open and Close to address name field. + Removed name as separate element from Thread and Proxy Control. + Added parameter "object class" to calls to Initialize Information
* Numerous miscellaneous features incorporated from Tony BennettJoel Sherrill1995-08-171-0/+376
(tbennett@divnc.com) including the following major additions: + variable length messages + named devices + debug monitor + association tables/variables
