* | 2008-01-23 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-01-23 | 1 | -4/+1 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * itron/include/rtems/itron/object.h, itron/src/cre_tsk.c, libblock/src/show_bdbuf.c, libmisc/capture/capture-cli.c, libmisc/capture/capture.c, libmisc/monitor/mon-manager.c, libmisc/stackchk/check.c, posix/src/condinit.c, posix/src/keycreate.c, posix/src/mqueuecreatesupp.c, posix/src/mqueuedeletesupp.c, posix/src/mqueuenametoid.c, posix/src/mqueueopen.c, posix/src/mqueueunlink.c, posix/src/mutexinit.c, posix/src/pbarrierinit.c, posix/src/prwlockinit.c, posix/src/pspininit.c, posix/src/pthreadcreate.c, posix/src/pthreadexit.c, posix/src/semaphorecreatesupp.c, posix/src/semaphorenametoid.c, posix/src/timercreate.c, rtems/src/barrierident.c, rtems/src/dpmemident.c, rtems/src/msgqident.c, rtems/src/partident.c, rtems/src/ratemonident.c, rtems/src/regionident.c, rtems/src/semident.c, rtems/src/taskident.c, rtems/src/timerident.c, sapi/src/extensionident.c, score/Makefile.am, score/include/rtems/score/object.h, score/inline/rtems/score/object.inl, score/src/apimutexallocate.c, score/src/objectextendinformation.c, score/src/objectgetnameasstring.c, score/src/objectmp.c, score/src/objectnametoid.c: Convert the Objects_Name type from a simple type to a union of an unsigned 32 bit integer and a pointer. This should help eliminate weird casts between u32 and pointers in various places. The APIs now have to explicitly call _u32 or _string versions of helper routines. This should also simplify things and eliminate the need for ugly casts in some cases. * score/src/objectclearname.c, score/src/objectcomparenameraw.c, score/src/objectcomparenamestring.c, score/src/objectcopynameraw.c, score/src/objectcopynamestring.c: Removed. | ||||
* | 2008-01-07 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-01-07 | 1 | -5/+5 |
| | | | | * libmisc/monitor/mon-manager.c: Style. Eliminate tabs. | ||||
* | 2004-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-11-01 | 1 | -1/+5 |
| | | | | | * libmisc/monitor/mon-manager.c, libmisc/monitor/mon-object.c: Remove references to _Object_Is_local in single processor configurations. | ||||
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-16 | 1 | -2/+2 |
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-15 | 1 | -1/+0 |
* | 2003-07-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-07-08 | 1 | -0/+4 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * capture/capture-cli.c: Add config-header support. * capture/capture.c: Add config-header support. * cpuuse/cpuuse.c: Add config-header support. * devnull/devnull.c: Add config-header support. * dummy/dummy.c: Add config-header support. * dumpbuf/dumpbuf.c: Add config-header support. * monitor/mon-command.c: Add config-header support. * monitor/mon-config.c: Add config-header support. * monitor/mon-dname.c: Add config-header support. * monitor/mon-driver.c: Add config-header support. * monitor/mon-extension.c: Add config-header support. * monitor/mon-itask.c: Add config-header support. * monitor/mon-manager.c: Add config-header support. * monitor/mon-monitor.c: Add config-header support. * monitor/mon-mpci.c: Add config-header support. * monitor/mon-object.c: Add config-header support. * monitor/mon-prmisc.c: Add config-header support. * monitor/mon-queue.c: Add config-header support. * monitor/mon-server.c: Add config-header support. * monitor/mon-symbols.c: Add config-header support. * monitor/mon-task.c: Add config-header support. * mw-fb/mw_fb.c: Add config-header support. * mw-fb/mw_uid.c: Add config-header support. * rtmonuse/rtmonuse.c: Add config-header support. * serdbg/serdbg.c: Add config-header support. * serdbg/serdbgio.c: Add config-header support. * serdbg/termios_printk.c: Add config-header support. * shell/cmds.c: Add config-header support. * stackchk/check.c: Add config-header support. * untar/untar.c: Add config-header support. | ||||
* | 2002-10-24 Fabrizio Pirovano <pirovano.thysys@tiscalinet.it> | Joel Sherrill | 2002-10-24 | 1 | -3/+6 |
| | | | | | * capture/capture.c, monitor/mon-manager.c, stackchk/check.c: Patch to remove problems introduced by object name rework. | ||||
* | Cleaned up as part of adding the Monitor test. | Joel Sherrill | 1997-09-21 | 1 | -3/+1 |
* | casts added to numerous arguments, prototypes corrected, and | Joel Sherrill | 1996-09-18 | 1 | -1/+1 |
| | | | | proper include files added. | ||||
* | updates from Tony Bennett | Joel Sherrill | 1996-04-22 | 1 | -5/+2 |
* | Update from Tony Bennett (tbennett@divnc.com) | Joel Sherrill | 1996-01-17 | 1 | -4/+5 |
* | Numerous miscellaneous features incorporated from Tony Bennett | Joel Sherrill | 1995-08-17 | 1 | -0/+52 |
(tbennett@divnc.com) including the following major additions: + variable length messages + named devices + debug monitor + association tables/variables |
