With the removal of the CONFIGURE_HAS_OWN_INIT_TASK_TABLE configuration
option at most one Classic API user initialization task can be
configured.
Provide an RTEMS API configuration table for backward compatibility.
Update #3873.
Use functions instead of macros. Add missing
rtems_configuration_get_maximum_*() functions.
Update #3621.
Closes #2997.
Use object allocator lock instead of disabled thread dispatching.
Update #2555.
The work areas (RTEMS work space and C program heap) will be initialized
now in a separate step and are no longer part of
rtems_initialize_data_structures(). Initialization is performed with
tables of Heap_Area entries. This allows usage of scattered memory
areas present on various small scale micro-controllers.
The sbrk() support API changes also. The bsp_sbrk_init() must now deal
with a minimum size for the first memory chunk to take the configured
work space size into account.
* libmisc/monitor/mon-config.c: Configuration table entry
work_space_size was not removed.
* itron/include/rtems/itron/itronapi.h, libmisc/capture/capture.c,
libmisc/monitor/mon-config.c, libmisc/monitor/mon-driver.c,
libmisc/monitor/mon-itask.c, libmisc/monitor/mon-mpci.c,
posix/include/rtems/posix/config.h,
posix/include/rtems/posix/posixapi.h,
rtems/include/rtems/rtems/config.h,
rtems/include/rtems/rtems/rtemsapi.h, rtems/src/taskinitusers.c,
sapi/include/confdefs.h, sapi/include/rtems/config.h,
sapi/include/rtems/init.h, sapi/src/exinit.c, sapi/src/itronapi.c,
sapi/src/posixapi.c, sapi/src/rtemsapi.c, score/src/isr.c,
score/src/thread.c, score/src/threadcreateidle.c,
score/src/threadstackallocate.c, score/src/threadstackfree.c,
score/src/wkspace.c: Eliminate pointers to API configuration tables
in the main configuration table. Reference the main configuration
table and the API configuration tables directly using the confdefs.h
version rather than obtaining a pointer to it. This eliminated some
variables, a potential fatal error, some unnecessary default
configuration structures. Overall, about a 4.5% reduction in the code
size for minimum and hello on the SPARC.
* itron/src/exd_tsk.c, itron/src/task.c, libmisc/capture/capture.c,
libmisc/monitor/mon-itask.c, libmisc/monitor/mon-monitor.c,
libmisc/monitor/mon-mpci.c, libmisc/monitor/mon-object.c,
libmisc/monitor/mon-symbols.c, posix/src/cancelrun.c,
posix/src/pthreadexit.c, rtems/Makefile.am, rtems/preinstall.am,
rtems/include/rtems.h, rtems/include/rtems/rtems/support.h,
rtems/inline/rtems/rtems/tasks.inl, rtems/src/eventmp.c,
rtems/src/msgmp.c, rtems/src/partmp.c, rtems/src/regionmp.c,
rtems/src/rtemsobjectgetname.c, rtems/src/semmp.c,
rtems/src/signalmp.c, rtems/src/taskdelete.c, rtems/src/taskmp.c,
rtems/src/timerserver.c, score/Makefile.am,
score/inline/rtems/score/object.inl, score/src/Unlimited.txt,
score/src/objectgetnameasstring.c,
score/src/threadqextractwithproxy.c: Add new Object Services
collection. This changed the name of a few previously public but
undocumented services and added a some new services.
* rtems/include/rtems/rtems/object.h, rtems/src/rtemsbuildid.c,
rtems/src/rtemsbuildname.c, rtems/src/rtemsobjectapimaximumclass.c,
rtems/src/rtemsobjectapiminimumclass.c,
rtems/src/rtemsobjectgetapiclassname.c,
rtems/src/rtemsobjectgetapiname.c,
rtems/src/rtemsobjectgetclassicname.c,
rtems/src/rtemsobjectgetclassinfo.c,
rtems/src/rtemsobjectidapimaximum.c,
rtems/src/rtemsobjectidapiminimum.c, rtems/src/rtemsobjectidgetapi.c,
rtems/src/rtemsobjectidgetclass.c, rtems/src/rtemsobjectidgetindex.c,
rtems/src/rtemsobjectidgetnode.c, rtems/src/rtemsobjectsetname.c,
score/src/objectapimaximumclass.c, score/src/objectgetinfo.c,
score/src/objectgetinfoid.c, score/src/objectsetname.c: New files.
* rtems/src/rtemsidtoname.c: Removed.
* monitor/monitor.h: Let rtems_monitor_config_dump return int.
* monitor/mon-config.c: Ditto. Use PRI*N macros.
* monitor/mon-itask.c, monitor/mon-prmisc.c: Use PRI*N macros.
* libmisc/capture/capture-cli.c, libmisc/cpuuse/cpuuse.c,
libmisc/dumpbuf/dumpbuf.c, libmisc/fsmount/fsmount.c,
libmisc/monitor/mon-command.c, libmisc/monitor/mon-config.c,
libmisc/monitor/mon-dname.c, libmisc/monitor/mon-driver.c,
libmisc/monitor/mon-extension.c, libmisc/monitor/mon-itask.c,
libmisc/monitor/mon-monitor.c, libmisc/monitor/mon-mpci.c,
libmisc/monitor/mon-object.c, libmisc/monitor/mon-prmisc.c,
libmisc/monitor/mon-queue.c, libmisc/monitor/mon-symbols.c,
libmisc/monitor/mon-task.c, libmisc/rtmonuse/rtmonuse.c,
libmisc/shell/cmds.c, libmisc/shell/shell.c, libmisc/shell/shell.h,
libmisc/stackchk/check.c, libmisc/untar/untar.c: Use
fprintf(stdout,...) instead of printf.
* libmisc/capture/capture-cli.c, libmisc/capture/capture.c,
libmisc/capture/capture.h, libmisc/cpuuse/cpuuse.c,
libmisc/devnull/devnull.c, libmisc/fsmount/fsmount.h,
libmisc/monitor/mon-config.c, libmisc/monitor/mon-dname.c,
libmisc/monitor/mon-driver.c, libmisc/monitor/mon-extension.c,
libmisc/monitor/mon-prmisc.c, libmisc/monitor/mon-queue.c,
libmisc/monitor/mon-server.c, libmisc/monitor/mon-symbols.c,
libmisc/monitor/monitor.h, libmisc/monitor/symbols.h,
libmisc/mw-fb/mw_uid.c, libmisc/rtmonuse/rtmonuse.c,
libmisc/serdbg/serdbg.h, libmisc/serdbg/serdbgio.c,
libmisc/serdbg/termios_printk.c, libmisc/serdbg/termios_printk.h,
libmisc/shell/shell.c, libmisc/shell/shell.h, libmisc/stackchk/check.c,
libmisc/stackchk/internal.h: Convert to using c99 fixed size types.
PR 495/rtems_misc
* capture/capture-cli.c, monitor/mon-command.c, monitor/mon-config.c,
monitor/mon-monitor.c, monitor/mon-object.c, monitor/mon-symbols.c,
monitor/monitor.h, shell/cmds.c: Move to making libmisc 16/32 bit
clean.
* capture/capture-cli.c: Add config-header support.
* capture/capture.c: Add config-header support.
* cpuuse/cpuuse.c: Add config-header support.
* devnull/devnull.c: Add config-header support.
* dummy/dummy.c: Add config-header support.
* dumpbuf/dumpbuf.c: Add config-header support.
* monitor/mon-command.c: Add config-header support.
* monitor/mon-config.c: Add config-header support.
* monitor/mon-dname.c: Add config-header support.
* monitor/mon-driver.c: Add config-header support.
* monitor/mon-extension.c: Add config-header support.
* monitor/mon-itask.c: Add config-header support.
* monitor/mon-manager.c: Add config-header support.
* monitor/mon-monitor.c: Add config-header support.
* monitor/mon-mpci.c: Add config-header support.
* monitor/mon-object.c: Add config-header support.
* monitor/mon-prmisc.c: Add config-header support.
* monitor/mon-queue.c: Add config-header support.
* monitor/mon-server.c: Add config-header support.
* monitor/mon-symbols.c: Add config-header support.
* monitor/mon-task.c: Add config-header support.
* mw-fb/mw_fb.c: Add config-header support.
* mw-fb/mw_uid.c: Add config-header support.
* rtmonuse/rtmonuse.c: Add config-header support.
* serdbg/serdbg.c: Add config-header support.
* serdbg/serdbgio.c: Add config-header support.
* serdbg/termios_printk.c: Add config-header support.
* shell/cmds.c: Add config-header support.
* stackchk/check.c: Add config-header support.
* untar/untar.c: Add config-header support.
from the application code, this file required more visibility than
is given by default to application code.
+ variable length messages
+ named devices
+ debug monitor
