* | This is another pass at making sure that nothing outside the BSP | Joel Sherrill | 1999-11-05 | 1 | -2/+1 |
| | | | | | | | | | | | | unnecessarily uses any variables defined by the BSP. On this sweep, use of BSP_Configuration and Cpu_table was eliminated. A significant part of this modification was the addition of macros to access fields in the RTEMS configuration structures. This is necessary to strengthen the division between the BSP independent parts of RTEMS and the BSPs themselves. This started after comments and analysis by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | ||||
* | Cleaned up as part of adding the Monitor test. | Joel Sherrill | 1997-09-21 | 1 | -1/+1 |
* | updates from Tony Bennett | Joel Sherrill | 1996-04-22 | 1 | -3/+0 |
* | Numerous miscellaneous features incorporated from Tony Bennett | Joel Sherrill | 1995-08-17 | 1 | -0/+190 |
(tbennett@divnc.com) including the following major additions: + variable length messages + named devices + debug monitor + association tables/variables |
