path: root/cpukit/libmisc/fb (follow)
* cpukit: Remove old DESCRIPTION: in commentsJoel Sherrill2015-03-112-8/+4
| | | | These were remnants of pre-Doxygen comment style.
* mw_uid: corrects uid_read_message short timeoutsAllan Hessenflow2014-01-091-2/+11
* cpukit: Doxygen group fixes and many warnings addressedJoel Sherrill2013-01-101-5/+8
| | | | | | | The output of the modules.html is much improved. Most filesystem and POSIX API related groups are properly nested. Some formatting issues were addressed as were multiple inconsistencies.
* libmisc: Doxygen Clean Up Task #1Ayush Awasthi2013-01-042-30/+38
| | | | | Conflicts occured durning this patch and modifications in the repo were favored over the patch.
* Header File Doxygen Enhancement Task #2Mathew Kallada2012-12-281-2/+5
* libmisc: Doxygen Enhancement Task #1Mathew Kallada2012-12-213-3/+22
* Make uid_buttons static.Ralf Corsépius2012-10-191-3/+3
| | | | | Reorder include-files. Remove stray blanks.
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-114-8/+0
* 2011-07-11 Sebastien Bourdeauducq <sebastien.bourdeauducq@gmail.com>Sebastian Huber2011-07-111-0/+1
| | | | | PR 1823/cpukit * libmisc/fb/fb.h: Added FBIOSETVIDEOMODE define.
* 2011-06-24 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-06-242-4/+12
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * include/rtems/bspIo.h, include/rtems/concat.h, include/rtems/endian.h, include/rtems/fs.h, include/rtems/irq.h, include/rtems/pci.h, include/rtems/userenv.h, libblock/include/rtems/flashdisk.h, libblock/include/rtems/nvdisk-sram.h, libblock/include/rtems/nvdisk.h, libcsupport/include/clockdrv.h, libcsupport/include/console.h, libcsupport/include/iosupp.h, libcsupport/include/spurious.h, libcsupport/include/motorola/mc68230.h, libcsupport/include/rtems/assoc.h, libcsupport/include/rtems/error.h, libcsupport/include/rtems/framebuffer.h, libcsupport/include/rtems/gxx_wrappers.h, libcsupport/include/rtems/libcsupport.h, libcsupport/include/rtems/libio_.h, libcsupport/include/rtems/malloc.h, libcsupport/include/rtems/termiostypes.h, libcsupport/include/sys/statvfs.h, libcsupport/include/sys/termios.h, libcsupport/include/sys/utsname.h, libcsupport/include/zilog/z8036.h, libcsupport/include/zilog/z8530.h, libcsupport/include/zilog/z8536.h, libfs/src/imfs/imfs.h, libfs/src/pipe/pipe.h, libmisc/capture/capture-cli.h, libmisc/capture/capture.h, libmisc/cpuuse/cpuuse.h, libmisc/devnull/devnull.h, libmisc/devnull/devzero.h, libmisc/dumpbuf/dumpbuf.h, libmisc/fb/fb.h, libmisc/fb/mw_uid.h, libmisc/mouse/mouse_parser.h, libmisc/shell/shellconfig.h, libmisc/stringto/stringto.h, libmisc/untar/untar.h, libnetworking/memory.h, posix/include/aio.h, posix/include/mqueue.h, posix/include/semaphore.h, posix/include/rtems/posix/aio_misc.h, posix/include/rtems/posix/barrier.h, posix/include/rtems/posix/cond.h, posix/include/rtems/posix/config.h, posix/include/rtems/posix/key.h, posix/include/rtems/posix/mqueue.h, posix/include/rtems/posix/mutex.h, posix/include/rtems/posix/posixapi.h, posix/include/rtems/posix/priority.h, posix/include/rtems/posix/psignal.h, posix/include/rtems/posix/pthread.h, posix/include/rtems/posix/ptimer.h, posix/include/rtems/posix/rwlock.h, posix/include/rtems/posix/semaphore.h, posix/include/rtems/posix/sigset.h, posix/include/rtems/posix/spinlock.h, posix/include/rtems/posix/threadsup.h, posix/include/rtems/posix/time.h, posix/include/rtems/posix/timer.h, posix/inline/rtems/posix/barrier.inl, posix/inline/rtems/posix/cond.inl, posix/inline/rtems/posix/mqueue.inl, posix/inline/rtems/posix/mutex.inl, posix/inline/rtems/posix/priority.inl, posix/inline/rtems/posix/pthread.inl, posix/inline/rtems/posix/rwlock.inl, posix/inline/rtems/posix/semaphore.inl, posix/inline/rtems/posix/spinlock.inl, posix/inline/rtems/posix/timer.inl, rtems/mainpage.h, rtems/include/rtems/rtems/barrier.h, rtems/include/rtems/rtems/object.h, rtems/include/rtems/rtems/timer.h, rtems/inline/rtems/rtems/barrier.inl, rtems/inline/rtems/rtems/timer.inl, rtems/src/semtranslatereturncode.c, sapi/include/rtems/config.h, sapi/include/rtems/fatal.h, sapi/include/rtems/mptables.h, score/include/rtems/score/object.h, score/include/rtems/score/priority.h, score/inline/rtems/score/object.inl, score/inline/rtems/score/priority.inl: Add @file Doxygen directives and descriptions to files which originated with RTEMS. This improves the file list page generated by Doxygen.
* 2011-02-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-02-173-116/+251
| | | | | | * libmisc/Makefile.am, libmisc/fb/mw_uid.c, libmisc/fb/mw_uid.h: Clean up. Add Doxygen style comments. Add method to print uid structure. * libmisc/fb/mw_print.c: New file.
* 2010-08-20 <yann.sionneau@telecom-sudparis.eu>Joel Sherrill2010-08-201-0/+4
| | | | * libmisc/fb/fb.h: Add constants for buffer modes.
* Whitespace removal.Ralf Corsepius2009-11-291-2/+2
* 2009-08-21 Roxana Leontie <roxana.leontie@gmail.com>Joel Sherrill2009-08-213-0/+379
* Makefile.am, preinstall.am, libmisc/Makefile.am: Changed the name of mw-fb directory into fb. Relocated files. * libmisc/fb/fb.h, libmisc/fb/mw_uid.c, libmisc/fb/mw_uid.h: New files. * libmisc/mw-fb/fb.h, libmisc/mw-fb/mw_uid.c, libmisc/mw-fb/mw_uid.h: Removed.
