| | | | | | | | | | * cpuuse/cpuuse.c, cpuuse/cpuuse.h, devnull/devnull.c, devnull/devnull.h, dummy/dummy.c, dumpbuf/dumpbuf.c, dumpbuf/dumpbuf.h, fsmount/fsmount.c, fsmount/fsmount.h, serdbg/serdbgio.c, serdbg/termios_printk.c, stackchk/check.c, stackchk/internal.h, stackchk/stackchk.h, untar/untar.c, untar/untar.h: URL for license changed. | ||||
* | 2003-07-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-07-08 | 1 | -0/+4 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * capture/capture-cli.c: Add config-header support. * capture/capture.c: Add config-header support. * cpuuse/cpuuse.c: Add config-header support. * devnull/devnull.c: Add config-header support. * dummy/dummy.c: Add config-header support. * dumpbuf/dumpbuf.c: Add config-header support. * monitor/mon-command.c: Add config-header support. * monitor/mon-config.c: Add config-header support. * monitor/mon-dname.c: Add config-header support. * monitor/mon-driver.c: Add config-header support. * monitor/mon-extension.c: Add config-header support. * monitor/mon-itask.c: Add config-header support. * monitor/mon-manager.c: Add config-header support. * monitor/mon-monitor.c: Add config-header support. * monitor/mon-mpci.c: Add config-header support. * monitor/mon-object.c: Add config-header support. * monitor/mon-prmisc.c: Add config-header support. * monitor/mon-queue.c: Add config-header support. * monitor/mon-server.c: Add config-header support. * monitor/mon-symbols.c: Add config-header support. * monitor/mon-task.c: Add config-header support. * mw-fb/mw_fb.c: Add config-header support. * mw-fb/mw_uid.c: Add config-header support. * rtmonuse/rtmonuse.c: Add config-header support. * serdbg/serdbg.c: Add config-header support. * serdbg/serdbgio.c: Add config-header support. * serdbg/termios_printk.c: Add config-header support. * shell/cmds.c: Add config-header support. * stackchk/check.c: Add config-header support. * untar/untar.c: Add config-header support. | ||||
* | 2001-09-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2001-09-28 | 1 | -0/+4 |
| | | | | | | * dummy/dummy.c: Now a useful configuration that starts main(). * wrapup/Makefile.am: Include a base level configuration in RTEMS library. | ||||
* | Increased the defaults to be more reasonable. | Joel Sherrill | 2000-08-01 | 1 | -1/+3 |
* | Merged from 4.5.0-beta3a | Joel Sherrill | 2000-06-12 | 1 | -0/+1 |
* | New files from Ralf Corsepius <corsepiu@faw.uni-ulm.de> which | Joel Sherrill | 1999-10-27 | 1 | -0/+36 |
are a dummy for linking programs together when you are primarily concerned with tricking another package into building. This may grow into something which could help link programs on the command line by having a default start sequence. |
