* cpukit/libmisc/cpuuse/cpuuse.h,
cpukit/libmisc/cpuuse/cpuusagedata.c,
cpukit/libmisc/cpuuse/cpuusagereport.c,
cpukit/libmisc/cpuuse/cpuusagereset.c: Fixed timestamp usage.
PR 1826/cpukit
* libmisc/cpuuse/cpuusagereport.c, rtems/Makefile.am,
rtems/preinstall.am, rtems/include/rtems.h: Add SMP Helper methods to
Classic API.
* rtems/include/rtems/rtems/smp.h: New file.
* include/rtems/bspIo.h, include/rtems/concat.h,
include/rtems/endian.h, include/rtems/fs.h, include/rtems/irq.h,
include/rtems/pci.h, include/rtems/userenv.h,
libblock/include/rtems/flashdisk.h,
libblock/include/rtems/nvdisk-sram.h,
libblock/include/rtems/nvdisk.h, libcsupport/include/clockdrv.h,
libcsupport/include/console.h, libcsupport/include/iosupp.h,
libcsupport/include/spurious.h,
libcsupport/include/motorola/mc68230.h,
libcsupport/include/rtems/assoc.h, libcsupport/include/rtems/error.h,
libcsupport/include/rtems/framebuffer.h,
libcsupport/include/rtems/gxx_wrappers.h,
libcsupport/include/rtems/libcsupport.h,
libcsupport/include/rtems/libio_.h,
libcsupport/include/rtems/malloc.h,
libcsupport/include/rtems/termiostypes.h,
libcsupport/include/sys/statvfs.h, libcsupport/include/sys/termios.h,
libcsupport/include/sys/utsname.h, libcsupport/include/zilog/z8036.h,
libcsupport/include/zilog/z8530.h, libcsupport/include/zilog/z8536.h,
libfs/src/imfs/imfs.h, libfs/src/pipe/pipe.h,
libmisc/capture/capture-cli.h, libmisc/capture/capture.h,
libmisc/cpuuse/cpuuse.h, libmisc/devnull/devnull.h,
libmisc/devnull/devzero.h, libmisc/dumpbuf/dumpbuf.h,
libmisc/fb/fb.h, libmisc/fb/mw_uid.h, libmisc/mouse/mouse_parser.h,
libmisc/shell/shellconfig.h, libmisc/stringto/stringto.h,
libmisc/untar/untar.h, libnetworking/memory.h, posix/include/aio.h,
posix/include/mqueue.h, posix/include/semaphore.h,
posix/include/rtems/posix/aio_misc.h,
posix/include/rtems/posix/barrier.h,
posix/include/rtems/posix/cond.h, posix/include/rtems/posix/config.h,
posix/include/rtems/posix/key.h, posix/include/rtems/posix/mqueue.h,
posix/include/rtems/posix/mutex.h,
posix/include/rtems/posix/posixapi.h,
posix/include/rtems/posix/ptimer.h,
posix/include/rtems/posix/rwlock.h,
posix/include/rtems/posix/sigset.h,
posix/include/rtems/posix/spinlock.h,
posix/inline/rtems/posix/barrier.inl,
posix/inline/rtems/posix/rwlock.inl,
posix/inline/rtems/posix/spinlock.inl,
posix/inline/rtems/posix/timer.inl, rtems/mainpage.h,
rtems/include/rtems/rtems/barrier.h,
rtems/include/rtems/rtems/object.h,
rtems/include/rtems/rtems/timer.h,
rtems/inline/rtems/rtems/barrier.inl,
rtems/inline/rtems/rtems/timer.inl,
rtems/src/semtranslatereturncode.c, sapi/include/rtems/config.h,
sapi/include/rtems/fatal.h, sapi/include/rtems/mptables.h,
score/inline/rtems/score/object.inl,
score/inline/rtems/score/priority.inl: Add @file Doxygen directives
and descriptions to files which originated with RTEMS. This improves
the file list page generated by Doxygen.
PR 1818/misc
* libmisc/cpuuse/cpuusagereport.c: Add SMP support to CPU Usage
Reporting.
* libmisc/cpuuse/cpuusagereport.c: Make compile again.
* libmisc/cpuuse/cpuusagereport.c: Avoid assumptions on execution
context.
* libmisc/cpuuse/cpuusagereport.c: Fix calculation in case a thread
dispatch happends in the meantime. The percent values will not sum up
to one hundred percent.
* libmisc/cpuuse/cpuusagereport.c: We have to take the time since the
last context switch before the uptime.
* score/src/iterateoverthreads.c, libmisc/cpuuse/cpuusagereport.c:
Avoid dead code if POSIX API is enabled.
Fixed NULL pointer access in case POSIX API is disabled.
* libcsupport/src/privateenv.c, libmisc/cpuuse/cpuusagereport.c,
posix/Makefile.am, posix/include/rtems/posix/key.h,
posix/src/keycreate.c, posix/src/keydelete.c,
score/src/iterateoverthreads.c: Since removing ITRON, the loop over
all APIs for tasks has a path that cannot be reached. Either modify
the code or mark tests for NULL as RTEMS_DEBUG.
* posix/src/keyfreememory.c: New file.
* libblock/include/rtems/ide_part_table.h, libblock/src/bdbuf.c,
libcsupport/src/__times.c, libcsupport/src/libio_init.c,
libcsupport/src/mallocfreespace.c, libcsupport/src/mount-mgr.c,
libcsupport/src/mount.c, libcsupport/src/rewinddir.c,
libcsupport/src/seekdir.c, libcsupport/src/telldir.c,
libcsupport/src/unmount.c, libfs/src/dosfs/fat.c,
libfs/src/dosfs/fat_fat_operations.c, libfs/src/dosfs/msdos_create.c,
libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_eval.c,
libfs/src/dosfs/msdos_file.c, libfs/src/dosfs/msdos_format.c,
libfs/src/dosfs/msdos_fsunmount.c, libfs/src/dosfs/msdos_initsupp.c,
libfs/src/dosfs/msdos_rename.c, libmisc/cpuuse/cpuusagereport.c,
libmisc/shell/vis.c, libmisc/stackchk/check.c, sapi/src/posixapi.c,
telnetd/telnetd.c: Remove include of assert.h when it is not needed.
* libcsupport/src/__times.c, libmisc/cpuuse/cpuusagedata.c,
libmisc/cpuuse/cpuusagereport.c, libmisc/cpuuse/cpuusagereset.c,
rtems/include/rtems/rtems/types.h, rtems/src/ratemongetstatistics.c,
rtems/src/ratemonreportstatistics.c, score/src/threaddispatch.c,
score/src/threadinitialize.c, score/src/threadtickletimeslice.c:
Updated copyright line.
* configure.ac, libcsupport/src/__times.c,
libmisc/cpuuse/cpuusagedata.c, libmisc/cpuuse/cpuusagereport.c,
libmisc/cpuuse/cpuusagereset.c, rtems/include/rtems/rtems/ratemon.h,
rtems/src/ratemongetstatus.c, rtems/src/ratemonperiod.c,
score/include/rtems/score/thread.h, score/src/threaddispatch.c,
Changed the configuration of statistics granularity to use just one
define.
PR 1471/cpukit
* libmisc/cpuuse/cpuusagereport.c: Rework statement to ensure 64-bit
multiplication is used to avoid overflow with intermediate value.
* libmisc/serdbg/termios_printk.c, libmisc/serdbg/termios_printk.h:
Fixed incompatible return value.
* libmisc/cpuuse/cpuusagereport.c: Changed output format.
* libmisc/Makefile.am, libmisc/monitor/mon-editor.c: New file.
* libmisc/capture/capture-cli.c, libmisc/monitor/mon-command.c,
libmisc/monitor/mon-monitor.c, libmisc/monitor/mon-object.c,
libmisc/monitor/mon-prmisc.c, libmisc/monitor/mon-symbols.c,
libmisc/monitor/monitor.h, libmisc/shell/cat_file.c,
libmisc/shell/cmds.c, libmisc/shell/internal.h,
libmisc/shell/main_help.c, libmisc/shell/shell.c,
libmisc/shell/shell.h, libmisc/shell/shell_cmdset.c,
libmisc/shell/shell_getchar.c, libmisc/shell/str2int.c: Various global
data is now read only. Added 'const' qualifier to many pointer
parameters. It is no longer possible to remove monitor commands.
Moved monitor line editor into a separate file to avoid unnecessary
dependencies.
* libcsupport/src/__times.c, libmisc/cpuuse/cpuusagereport.c,
libmisc/cpuuse/cpuusagereset.c, posix/src/clockgettime.c,
posix/src/pthread.c, posix/src/timersettime.c,
rtems/src/clockgetsecondssinceepoch.c, rtems/src/clockgetuptime.c,
rtems/src/ratemonreportstatistics.c, rtems/src/taskwakewhen.c,
rtems/src/timerfirewhen.c, rtems/src/timerserver.c,
rtems/src/timerserverfirewhen.c, score/Makefile.am,
score/preinstall.am, score/include/rtems/score/thread.h,
score/include/rtems/score/tod.h, score/src/coretod.c,
score/src/coretodget.c, score/src/coretodgetuptime.c,
score/src/coretodset.c, score/src/coretodtickle.c,
score/src/threaddispatch.c, score/src/threadinitialize.c: Add
SuperCore handler Timestamp to provide an opaque class for the
representation and manipulation of uptime, time of day, and the
difference between two timestamps. By using SuperCore Timestamp, it
is clear which methods and APIs really have to be struct timespec and
which can be in an optimized native format.
* score/include/rtems/score/timestamp.h,
score/src/coretodgetuptimetimespec.c: New files.
* libcsupport/include/rtems/libcsupport.h, libcsupport/src/scandir.c,
libmisc/cpuuse/cpuusagereset.c, libmisc/monitor/mon-monitor.c,
libmisc/serdbg/serdbg.c, libmisc/serdbg/serdbg.h,
libnetworking/netinet/in_cksum_powerpc.h, shttpd/compat_rtems.h: Fix
warnings.
libmisc/cpuuse/cpuusagereset.c, libmisc/monitor/mon-task.c,
rtems/include/rtems/rtems/ratemon.h, rtems/src/ratemongetstatus.c,
rtems/src/ratemonperiod.c, score/include/rtems/score/thread.h,
score/src/threaddispatch.c, score/src/threadinitialize.c,
score/src/threadtickletimeslice.c: Add typedefs for cpu usage and
period timing statistics. Also renamed related variables and
structure members so they are the same whether you are using
nanosecond (e.g. struct timespec) or ticks (e.g. uint32_t)
granularity. This lays the groundwork for future cleanup.
* libcsupport/src/printk.c: Added width and padding for %s.
* libmisc/cpuuse/cpuusagereport.c: Support object names that are
strings longer than 4 chanracters.
* libmisc/cpuuse/cpuusagereport.c, rtems/src/ratemonreportstatistics.c:
Cleaned up reports and fixed a bug related the printf format which
resulted in lack of leading zeroes and misleading magnitude.
* score/src/timespecdivide.c: Fixed bugs related to zero divide case.
* libcsupport/Makefile.am, libcsupport/src/printk.c:
* libcsupport/src/printk_plugin.c: New file.
include/rtems/bspIo.h, libmisc/cpuuse/cpuusagereport.c,
libmisc/cpuuse/cpuuse.h, libmisc/stackchk/check.c,
libmisc/stackchk/stackchk.h: rtems/include/rtems/rtems/ratemon.h,
rtems/src/ratemonreportstatistics.c: Added capability to specify
your own "printf" routine to various reporting functions. This
added an XXX_with_plugin as the underlying implementation for
+ rtems_rate_monotonic_report_statistics
+ rtems_stack_checker_report_usage
+ rtems_cpu_usage_report
As demonstration, the http netdemo can now print out stack
and cpu usage reports.
* libmisc/cpuuse/cpuusagereport.c, libmisc/cpuuse/cpuusagereset.c,
score/src/timespecdivide.c: Fix various math and reporting bugs. Now
the time appears to be reported correctly and add up to what is
expected.
* libmisc/Makefile.am, libmisc/cpuuse/cpuusagereport.c,
libmisc/cpuuse/cpuusagereset.c: Fix bug where cpu usage calculation
was always using uptime not time since last cpu usage reset when
using nanoseconds granularity.
* libmisc/cpuuse/cpuusagedata.c: New file.
* libmisc/Makefile.am, libmisc/cpuuse/README: Split remaining CPU Usage
functionality into multiple files to eliminate unnecessary cohesion.
Update README.
* libmisc/cpuuse/cpuusagereport.c, libmisc/cpuuse/cpuusagereset.c:
New files.
* libmisc/cpuuse/cpuuse.c: Removed.
* ChangeLog, configure.ac, libcsupport/src/__times.c,
libmisc/cpuuse/cpuuse.c, libmisc/stackchk/check.c,
rtems/src/ratemonperiod.c, rtems/src/ratemonreportstatistics.c,
rtems/src/ratemonresetall.c, rtems/src/ratemontimeout.c,
score/Makefile.am, score/include/rtems/score/thread.h,
score/include/rtems/score/timespec.h, score/src/threaddispatch.c,
score/src/threadinitialize.c, score/src/threadtickletimeslice.c,
score/src/timespecdivide.c: Add nanoseconds granularity to the rate
monotonic period statistics and CPU usage statistics. This capability
is enabled by default although may be conditionally disabled by the
user. It could be too much overhead on small targets but it does not
appear to be bad in early testing. Its impact on code size has not
been evaluated either. It is possible that both forms of statistics
gathering could be disabled with further tweaking of the conditional
compilation.
* score/src/timespecdividebyinteger.c: New file.
* libmisc/cpuuse/cpuuse.c: Use rtems_object_get_name and eliminate
functionally similar code here. Also cleanup print formats.
* libmisc/cpuuse/cpuuse.c, libmisc/stackchk/check.c,
libmisc/stackchk/stackchk.h: Clean up as side-effect of making them
suitable for inclusion in the Users Guide.
* libmisc/cpuuse/cpuuse.c, libmisc/cpuuse/cpuuse.h: Promote CPU Usage
to first class citizen. Rename to start with rtems_ and include
documentation in user guide.
* libmisc/cpuuse/cpuuse.c, libmisc/monitor/mon-command.c,
libmisc/monitor/mon-driver.c, libmisc/monitor/mon-symbols.c,
libmisc/rtmonuse/rtmonuse.c, libmisc/stackchk/check.c,
libnetworking/libc/res_debug.c, telnetd/telnetd.c: Remove printf
format warnings.
enabled them.
* configure.ac, libmisc/cpuuse/README, libmisc/stackchk/README,
librpc/src/xdr/xdr_float.c, score/cpu/Makefile.am,
score/include/rtems/score/mppkt.h: i960 obsoleted and all references
removed.
* libmisc/capture/capture-cli.c, libmisc/cpuuse/cpuuse.c,
libmisc/dumpbuf/dumpbuf.c, libmisc/fsmount/fsmount.c,
libmisc/monitor/mon-command.c, libmisc/monitor/mon-config.c,
libmisc/monitor/mon-dname.c, libmisc/monitor/mon-driver.c,
libmisc/monitor/mon-extension.c, libmisc/monitor/mon-itask.c,
libmisc/monitor/mon-monitor.c, libmisc/monitor/mon-mpci.c,
libmisc/monitor/mon-object.c, libmisc/monitor/mon-prmisc.c,
libmisc/monitor/mon-queue.c, libmisc/monitor/mon-symbols.c,
libmisc/monitor/mon-task.c, libmisc/rtmonuse/rtmonuse.c,
libmisc/shell/cmds.c, libmisc/shell/shell.c, libmisc/shell/shell.h,
libmisc/stackchk/check.c, libmisc/untar/untar.c: Use
fprintf(stdout,...) instead of printf.
* libmisc/capture/capture-cli.c, libmisc/capture/capture.c,
libmisc/capture/capture.h, libmisc/cpuuse/cpuuse.c,
libmisc/devnull/devnull.c, libmisc/fsmount/fsmount.h,
libmisc/monitor/mon-config.c, libmisc/monitor/mon-dname.c,
libmisc/monitor/mon-driver.c, libmisc/monitor/mon-extension.c,
libmisc/monitor/mon-itask.c, libmisc/monitor/mon-monitor.c,
libmisc/monitor/mon-mpci.c, libmisc/monitor/mon-object.c,
libmisc/monitor/mon-prmisc.c, libmisc/monitor/mon-queue.c,
libmisc/monitor/mon-server.c, libmisc/monitor/mon-symbols.c,
libmisc/monitor/monitor.h, libmisc/monitor/symbols.h,
libmisc/mw-fb/mw_uid.c, libmisc/rtmonuse/rtmonuse.c,
libmisc/serdbg/serdbg.h, libmisc/serdbg/serdbgio.c,
libmisc/serdbg/termios_printk.c, libmisc/serdbg/termios_printk.h,
libmisc/shell/shell.c, libmisc/shell/shell.h, libmisc/stackchk/check.c,
libmisc/stackchk/internal.h: Convert to using c99 fixed size types.
* libblock/src/bdbuf.c, libblock/src/ramdisk.c,
libcsupport/src/newlibc.c, libcsupport/src/sync.c,
libmisc/cpuuse/cpuuse.c, libmisc/monitor/mon-symbols.c,
libnetworking/kern/kern_sysctl.c, libnetworking/lib/ftpfs.c,
libnetworking/lib/tftpDriver.c, libnetworking/libc/gethostbydns.c,
libnetworking/libc/gethostbyht.c, libnetworking/libc/gethostnamadr.c,
libnetworking/libc/getnetbyht.c, libnetworking/libc/getnetnamadr.c,
libnetworking/libc/inet_addr.c, libnetworking/libc/linkaddr.c,
libnetworking/libc/map_v4v6.c, libnetworking/libc/ns_print.c,
libnetworking/libc/ns_ttl.c, libnetworking/libc/nsap_addr.c,
libnetworking/libc/rcmd.c, libnetworking/libc/res_debug.c,
libnetworking/libc/res_mkupdate.c, libnetworking/libc/res_query.c,
libnetworking/libc/res_send.c, libnetworking/libc/res_update.c,
libnetworking/net/radix.c, libnetworking/rtems/mkrootfs.c,
librpc/src/rpc/clnt_perror.c, librpc/src/rpc/svc.c,
score/macros/rtems/score/chain.inl, score/src/objectidtoname.c: Too
much was accidentally committed -- revert.
librpc/src/rpc/clnt_perror.c, librpc/src/rpc/rtems_rpc.c,
librpc/src/rpc/svc.c, sapi/include/confdefs.h,
PR 540/rtems_misc
* cpuuse/cpuuse.c, rtmonuse/rtmonuse.c: Correct object name printing.
* capture/Makefile.am: Remove.
* cpuuse/Makefile.am: Remove.
* devnull/Makefile.am: Remove.
* dummy/Makefile.am: Remove.
* dumpbuf/Makefile.am: Remove.
* fsmount/Makefile.am: Remove.
* monitor/Makefile.am: Remove.
* mw-fb/Makefile.am: Remove.
* rtmonuse/Makefile.am: Remove.
* serdbg/Makefile.am: Remove.
* shell/Makefile.am: Remove.
* stackchk/Makefile.am: Remove.
* untar/Makefile.am: Remove.
* Makefile.am: Merge-in the Makefile.ams above.
* capture/config.h: Remove.
* capture/Makefile.am: Remove config.h.
AM_CPPFLAGS += -I$(top_builddir).
* cpuuse/config.h: Remove.
* cpuuse/Makefile.am: Remove config.h.
* devnull/config.h: Remove.
* devnull/Makefile.am: Remove config.h.
* dummy/config.h: Remove.
* dummy/Makefile.am: Remove config.h.
* dumpbuf/config.h: Remove.
* dumpbuf/Makefile.am: Remove config.h.
* monitor/config.h: Remove.
* monitor/Makefile.am: Remove config.h.
* mw-fb/config.h: Remove.
* mw-fb/Makefile.am: Remove config.h.
* rtmonuse/config.h: Remove.
* rtmonuse/Makefile.am: Remove config.h.
* serdbg/config.h: Remove.
* serdbg/Makefile.am: Remove config.h.
* shell/config.h: Remove.
* shell/Makefile.am: Remove config.h.
* stackchk/config.h: Remove.
* stackchk/Makefile.am: Remove config.h.
* untar/config.h: Remove.
* untar/Makefile.am: Remove config.h.
* cpuuse/cpuuse.c, cpuuse/cpuuse.h, devnull/devnull.c,
devnull/devnull.h, dummy/dummy.c, dumpbuf/dumpbuf.c,
dumpbuf/dumpbuf.h, fsmount/fsmount.c, fsmount/fsmount.h,
serdbg/serdbgio.c, serdbg/termios_printk.c, stackchk/check.c,
stackchk/internal.h, stackchk/stackchk.h, untar/untar.c,
untar/untar.h: URL for license changed.
PR 408/filesystem
* cpuuse/cpuuse.c: Added sync() service. As part of adding this
service, the new RTEMS service rtems_iterate_over_all_threads() was
also added. This new service makes it easier to iterate over all the
tasks/threads in a system and perform an action on them. This change
is to use the new thread iteration service.
* configure.ac: Remove (Merged into ../configure.ac).
* Makefile.am:
* capture/config.h: New.
* capture/Makefile.am: Add config.h.
* cpuuse/config.h: New.
* cpuuse/Makefile.am: Add config.h.
* devnull/config.h: New.
* devnull/Makefile.am: Add config.h.
* dummy/config.h: New.
* dummy/Makefile.am: Add config.h.
* dumpbuf/config.h: New.
* dumpbuf/Makefile.am: Add config.h.
* monitor/config.h: New.
* monitor/Makefile.am: Add config.h.
* mw-fb/config.h: New.
* mw-fb/Makefile.am: Add config.h.
* rtmonuse/config.h: New.
* rtmonuse/Makefile.am: Add config.h.
* serdbg/config.h: New.
* serdbg/Makefile.am: Add config.h.
* shell/config.h: New.
* shell/Makefile.am: Add config.h.
* stackchk/config.h: New.
* stackchk/Makefile.am: Add config.h.
* untar/config.h: New.
* untar/Makefile.am: Add config.h.
* wrapup/Makefile.am:
* capture/capture-cli.c: Add config-header support.
* capture/capture.c: Add config-header support.
* cpuuse/cpuuse.c: Add config-header support.
* devnull/devnull.c: Add config-header support.
* dummy/dummy.c: Add config-header support.
* dumpbuf/dumpbuf.c: Add config-header support.
* monitor/mon-command.c: Add config-header support.
* monitor/mon-config.c: Add config-header support.
* monitor/mon-dname.c: Add config-header support.
* monitor/mon-driver.c: Add config-header support.
* monitor/mon-extension.c: Add config-header support.
* monitor/mon-itask.c: Add config-header support.
* monitor/mon-manager.c: Add config-header support.
* monitor/mon-monitor.c: Add config-header support.
* monitor/mon-mpci.c: Add config-header support.
* monitor/mon-object.c: Add config-header support.
* monitor/mon-prmisc.c: Add config-header support.
* monitor/mon-queue.c: Add config-header support.
* monitor/mon-server.c: Add config-header support.
* monitor/mon-symbols.c: Add config-header support.
* monitor/mon-task.c: Add config-header support.
* mw-fb/mw_fb.c: Add config-header support.
* mw-fb/mw_uid.c: Add config-header support.
* rtmonuse/rtmonuse.c: Add config-header support.
* serdbg/serdbg.c: Add config-header support.
* serdbg/serdbgio.c: Add config-header support.
* serdbg/termios_printk.c: Add config-header support.
* shell/cmds.c: Add config-header support.
* stackchk/check.c: Add config-header support.
* untar/untar.c: Add config-header support.
* configure.ac: Add check for weak function attribute.
Remove AM_CONDITIONAL([RTEMS_LIBSHELL].
Add AM_CONDITIONAL(LIBSHELL), AM_CONDITIONAL(LIBSERDBG).
* capture/Makefile.am: Use *.a instead of *-tmp.a.
* cpuuse/Makefile.am: Use *.a instead of *-tmp.a.
* devnull/Makefile.am: Use *.a instead of *-tmp.a.
* dummy/Makefile.am: Use *.a instead of *-tmp.a.
* dumpbuf/Makefile.am: Use *.a instead of *-tmp.a.
* monitor/Makefile.am: Use *.a instead of *-tmp.a.
* mw-fb/Makefile.am: Use *.a instead of *-tmp.a.
* rtmonuse/Makefile.am: Use *.a instead of *-tmp.a.
* serdbg/Makefile.am: Use *.a instead of *-tmp.a.
Build iff LIBSERDBG is true.
* shell/Makefile.am: Use *.a instead of *-tmp.a.
Build iff LIBSHELL is true.
* stackchk/Makefile.am: Use *.a instead of *-tmp.a.
* untar/Makefile.am: Use *.a instead of *-tmp.a.
* configure.ac: Require autoconf-2.57+automake-1.7.2.
* capture/Makefile.am: Eliminate C_O_FILES.
* cpuuse/Makefile.am: Ditto.
* devnull/Makefile.am: Ditto.
* dummy/Makefile.am: Ditto.
* dumpbuf/Makefile.am: Ditto.
* monitor/Makefile.am: Ditto.
* rtmonuse/Makefile.am: Ditto.
* serdbg/Makefile.am: Ditto.
* shell/Makefile.am: Ditto.
* stackchk/Makefile.am: Ditto.
* untar/Makefile.am: Ditto.
* mw-fb/Makefile.am: Eliminate C_O_FILES.
Eliminate SRCS.
Moving libmisc from rtems/c/src to rtems/cpukit.
* Makefile.am: Reflect new path.
* configure.ac: Reflect new path.
Use RTEMS_ENV_RTEMSCPU instead of RTEMS_ENV_RTEMSBSP.
Remove RTEMS_PROJECT_ROOT.
* capture/Makefile.am: Reflect new path.
Remove OBJS from all-local.
* mw-fb/Makefile.am: Ditto.
* wrapup/Makefile.am: Reflect new path.
