* libmisc/Makefile.am, libmisc/cpuuse/README: Split remaining CPU Usage
functionality into multiple files to eliminate unnecessary cohesion.
Update README.
* libmisc/cpuuse/cpuusagereport.c, libmisc/cpuuse/cpuusagereset.c:
New files.
* libmisc/cpuuse/cpuuse.c: Removed.
* configure.ac, libmisc/cpuuse/README, libmisc/stackchk/README,
librpc/src/xdr/xdr_float.c, score/cpu/Makefile.am,
score/include/rtems/score/mppkt.h: i960 obsoleted and all references
removed.
enclose.
