line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Conflicts occured durning this patch and modifications in
the repo were favored over the patch.
* libmisc/bspcmdline/bspcmdline.h, libmisc/bspcmdline/bspcmdline_get.c,
libmisc/bspcmdline/bspcmdline_getparam.c,
libmisc/bspcmdline/bspcmdline_getparamraw.c,
libmisc/bspcmdline/bspcmdline_getparamrhs.c: Add rtems_ as prefix to
all routines.
libmisc/bspcmdline/bspcmdline_getparamrhs.c: New files.
Missed in previous commit.
