* monitor/mon-command.c: Don't build rtems_monitor_line_editor for
RTEMS_UNIX to avoid gcc warning.
* capture/capture.c, monitor/mon-manager.c, stackchk/check.c:
Patch to remove problems introduced by object name rework.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* shell/shell.c: #include <time.h>
* wrapup/Makefile.am: Eliminate LIBNAME.
* capture/Makefile.am: Use .$(OBJEXT) instead of .o.
* cpuuse/Makefile.am: Use .$(OBJEXT) instead of .o.
* devnull/Makefile.am: Use .$(OBJEXT) instead of .o.
* dummy/Makefile.am: Use .$(OBJEXT) instead of .o.
* dumpbuf/Makefile.am: Use .$(OBJEXT) instead of .o.
* monitor/Makefile.am: Use .$(OBJEXT) instead of .o.
* mw-fb/Makefile.am: Use .$(OBJEXT) instead of .o.
* rtmonuse/Makefile.am: Use .$(OBJEXT) instead of .o.
* serdbg/Makefile.am: Use .$(OBJEXT) instead of .o.
* shell/Makefile.am: Use .$(OBJEXT) instead of .o.
* stackchk/Makefile.am: Use .$(OBJEXT) instead of .o.
* untar/Makefile.am: Use .$(OBJEXT) instead of .o.
* shell/Makefile.am: Remove shell.h from EXTRA_DIST.
* cpuuse/cpuuse.c (CPU_usage_Dump) : Corrected so it honors when an
object name is raw versus being a string.
* stackchk/check.c: Don't reference the RTEMS allocated interrupt
stack if the port doesn't configure using it.
* wrapup/Makefile.am: Temporarily don't include serdbg since it
causes some BSPs to not link "main(){}" as required by autoconf.
* capture/capture.c: include <string.h> for memset.
* capture/capture-cli.c, cpuuse/cpuuse.c, monitor/mon-monitor.c,
monitor/mon-object.c, monitor/monitor.h: Corrected use of
_Objects_Information_table now that it is a two dimensional
array based upon API and class. In addition, in the monitor,
corrected an error which occured when a target has 64 bit pointers.
* stackchk/check.c: Corrected use of
* With the addition of serdbg, the standard polled I/O functions
for gdbstub and/or printk are optionally routed to any termios-aware
device driver, that supports polled mode. See libmisc/serdbg/README.
* serdbg/Makefile.am, serdbg/README, serdbg/serdbg.c, serdbg/serdbg.h,
serdbg/serdbgcnf.h, serdbg/serdbgio.c, serdbg/termios_printk.c,
serdbg/termios_printk.h, serdbg/termios_printk_cnf.h,
serdbg/.cvsignore: New files.
* configure.ac, Makefile.am, wrapup/Makefile.am: Modified to
reflect addition.
* wrapup/Makefile.am: Don't preinstall libmisc.a.
* coinfigure.ac, Makefile.am: Remove references to rootfs.
* rootfs/.cvsignore: Remove.
* rootfs/Makefile.am: Remove.
* rootfs/mkrootfs.h: Remove.
* rootfs/mkrootfs.c: Remove.
* configure.ac: Remove rootfs and NETWORKING macros.
* wrapup/Makefile.am: Remove rootfs and HAS_NETWORKING.
* Per PR194, added the Capture engine.
* capture/Makefile.am, capture/README, capture/capture-cli.c,
capture/capture-cli.h, capture/capture.c, capture/capture.h,
capture/.cvsignore: New files.
* Makefile.am, configure.ac, wrapup/Makefile.am: Modified to
reflect addition.
* dummy/Makefile.am, wrapup/Makefile.am: Fixed to generate
a library of the same name.
* monitor/mon-command.c: Per PR192 the RTEMS monitor makes everything
lowercase. The capture engine need to set triggers or watches on task
with uppercase names.
Also stop the monitor repeating command when enter is pressed.
* monitor/mon-monitor.c: Replace done with return (gcc3).
* devnull/Makefile.am: Remove AUTOMAKE_OPTIONS.
* dummy/Makefile.am: Remove AUTOMAKE_OPTIONS.
* dumpbuf/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mw-fb/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rootfs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shell/Makefile.am: Remove AUTOMAKE_OPTIONS.
* untar/Makefile.am: Remove AUTOMAKE_OPTIONS.
* PR148.
* monitor/mon-prmisc.c: Fixed to print task states correctly.
* shell/shell.c: Remove #undef __STRICT_ANSI__.
* rootfs/Makefile.am: Use include_rtems_HEADERS instead of H_FILES.
* mw-fb/mw_uid.c: Apply rtems_set_errno_and_return_minus_one.
* rootfs/mkrootfs.c, rootfs/mkrootfs.h: Fixed typo.
* configure.in: Remove.
* dummy/dummy.c: Now a useful configuration that starts main().
* wrapup/Makefile.am: Include a base level configuration in
RTEMS library.
* untar/Makefile.am: Use 'PREINSTALL_FILES ='.
* monitor/Makefile.am: Use 'PREINSTALL_FILES ='.
* shell/Makefile.am: Use 'PREINSTALL_FILES ='.
* devnull/Makefile.am: Use 'PREINSTALL_FILES ='.
* dumpbuf/Makefile.am: Use 'PREINSTALL_FILES ='.
* mw-fb/Makefile.am: Use 'PREINSTALL_FILES ='.
* stackchk/Makefile.am: Use 'PREINSTALL_FILES ='.
* rtmonuse/Makefile.am: Use 'PREINSTALL_FILES ='.
* cpuuse/Makefile.am: Use 'PREINSTALL_FILES ='.
* rootfs/Makefile.am: Use 'PREINSTALL_FILES ='.
* ChangeLog: Fixed typo in date.
* configure.in, rootfs/Makefile.am: Added conditional to make sure
rootfs does not get built with networking is disabled. Also
added include of compile.am to rootfs/Makefile.am.
* wrapup/Makefile.am: Added rootfs conditionally if networking enabled.
* Added support for populating the initial "root" filesystem
with information obtained via the DHCP response.
* rootfs: New directory.
* rootfs/.cvsignore, rootfs/Makefile.am, rootfs/mkrootfs.c,
rootfs/mkrootfs.h: New files.
* configure.in, Makefile.am: Modified to reflect addition.
* ChangeLog: Fixed some mistakes.
* devnull/devnull.c: Eliminate warning.
* shell/pty.c: Moved to libnetworking/rtems_telnetd.
* shell/Makefile.am, shell/README, shell/cmds.c, shell/shell.c,
shell/shell.h: Updates.
* monitor/mon-command.c: Add support for partial command matching.
The monitor used to have this functionality before it was overhauled
to support addition of user commands.
* shell/telnetd.c, shell/telnetd.h: Moved to
libnetworking/rtems_servers so the network stack to address network
depenendency.
* shell/Makefile.am: Modified to reflect above.
* shell/cmds.c: Removed code from inappropriate source.
* monitor/mon-prmisc.c: Correct print line.
* shell/Makefile.am: Added new file telnetd.c.
* shell/telnetd.c, shell/telnetd.h, shell/pty.c: New files.
* shell/shell.c, shell/cmds.c, shell/shell.h: Numerous improvments:
- The shell_init has a new parameter 'forever' because in
/dev/console you need that this process runs forever but in
tcp/ip not. (respawn?)
- A new task for every session opened trought tcp/ip telnet client.
(the chargen,daytime and more are possible of implementation but
I ask me if they are necesary)
- Exit from the session delete the task and when the client fails too.
- More cmds have been implemented. (very reduced version of these)
umask, chmod, id, whoami, rm, cat, ...
- A reduced line edit has been implemented.
Ctrl-C abort the input,
Ctrl-d in the first position gives EOF (logout).
'\b' and DEL makes the rubout operation.
I think that readline() for every session spents a lot of resources.
* shell/cmds.c, shell/shell.c: Remove fileno-hacks.
* monitor/mon-symbols.c: Remove #undef __STRICT_ANSI__.
* Added initial shell functionality.
* Makefile.am, configure.in, wrapup/Makefile.am:
* shell/.cvsignore, shell/Makefile.am, shell/README,
shell/cmds.c, shell/shell.c, shell/shell.h: New files.
* devnull/devnull.c (null_initialize): Added check to
ensure that the driver is only initialized once. Otherwise,
it will abort when the device /dev/null is present.
(null_write): Do not dereference a NULL pointer.
* monitor/mon-command.c: Use #if defined(RTEMS_UNIX).
* untar/Makefile.am, monitor/Makefile.am, dummy/Makefile.am,
devnull/Makefile.am, dumpbuf/Makefile.am, mw-fb/Makefile.am,
stackchk/Makefile.am, rtmonuse/Makefile.am, cpuuse/Makefile.am:
* devnull: New addition. Moved from libcpu/sh.
* devnull/devnull.c, devnull/devnull.h, devnull/.cvsignore,
devnull/Makefile.am: New files.
* Makefile.am, configure.in, wrapup/Makefile.am: Modified to reflect
addition of above.
* mw-fb/mw_uid.c: Removed unnecessary dependency on <bsp.h>.
