path: root/cpukit/libmisc/ChangeLog (follow)
* 2002-07-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-201-0/+5
| | | | * capture/capture.c: include <string.h> for memset.
* 2002-07-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-011-0/+8
| | | | | | | | * capture/capture-cli.c, cpuuse/cpuuse.c, monitor/mon-monitor.c, monitor/mon-object.c, monitor/monitor.h: Corrected use of _Objects_Information_table now that it is a two dimensional array based upon API and class. In addition, in the monitor, corrected an error which occured when a target has 64 bit pointers.
* 2002-07-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-011-0/+6
| | | | | | * stackchk/check.c: Corrected use of _Objects_Information_table now that it is a two dimensional array based upon API and class.
* 2002-06-25 Thomas Doerfler <Thomas.Doerfler@imd-systems.de>Joel Sherrill2002-06-271-0/+12
| | | | | | | | | | | | * With the addition of serdbg, the standard polled I/O functions for gdbstub and/or printk are optionally routed to any termios-aware device driver, that supports polled mode. See libmisc/serdbg/README. * serdbg/Makefile.am, serdbg/README, serdbg/serdbg.c, serdbg/serdbg.h, serdbg/serdbgcnf.h, serdbg/serdbgio.c, serdbg/termios_printk.c, serdbg/termios_printk.h, serdbg/termios_printk_cnf.h, serdbg/.cvsignore: New files. * configure.ac, Makefile.am, wrapup/Makefile.am: Modified to reflect addition.
* 2002-06-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-261-1/+5
| | | | * wrapup/Makefile.am: Don't preinstall libmisc.a.
* 2002-05-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-05-241-0/+4
| | | | * coinfigure.ac, Makefile.am: Remove references to rootfs.
* 2002-05-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-05-171-0/+9
| | | | | | | | | * rootfs/.cvsignore: Remove. * rootfs/Makefile.am: Remove. * rootfs/mkrootfs.h: Remove. * rootfs/mkrootfs.c: Remove. * configure.ac: Remove rootfs and NETWORKING macros. * wrapup/Makefile.am: Remove rootfs and HAS_NETWORKING.
* 2002-05-16 Chris Johns <ccj@acm.org>Joel Sherrill2002-05-151-0/+9
| | | | | | | | | * Per PR194, added the Capture engine. * capture/Makefile.am, capture/README, capture/capture-cli.c, capture/capture-cli.h, capture/capture.c, capture/capture.h, capture/.cvsignore: New files. * Makefile.am, configure.ac, wrapup/Makefile.am: Modified to reflect addition.
* 2001-05-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-05-141-0/+5
| | | | | * dummy/Makefile.am, wrapup/Makefile.am: Fixed to generate a library of the same name.
* 2002-03-20 Chris Johns <ccj@acm.org>Joel Sherrill2002-05-011-0/+7
| | | | | | | * monitor/mon-command.c: Per PR192 the RTEMS monitor makes everything lowercase. The capture engine need to set triggers or watches on task with uppercase names. Also stop the monitor repeating command when enter is pressed.
* 2002-04-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-041-0/+4
| | | | * monitor/mon-monitor.c: Replace done with return (gcc3).
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-281-0/+19
| | | | | | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. * cpuuse/Makefile.am: Remove AUTOMAKE_OPTIONS. * devnull/Makefile.am: Remove AUTOMAKE_OPTIONS. * dummy/Makefile.am: Remove AUTOMAKE_OPTIONS. * dumpbuf/Makefile.am: Remove AUTOMAKE_OPTIONS. * monitor/Makefile.am: Remove AUTOMAKE_OPTIONS. * mw-fb/Makefile.am: Remove AUTOMAKE_OPTIONS. * rootfs/Makefile.am: Remove AUTOMAKE_OPTIONS. * rtmonuse/Makefile.am: Remove AUTOMAKE_OPTIONS. * shell/Makefile.am: Remove AUTOMAKE_OPTIONS. * stackchk/Makefile.am: Remove AUTOMAKE_OPTIONS. * untar/Makefile.am: Remove AUTOMAKE_OPTIONS. * wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2002-03-20 Chris Johns <ccj@acm.org>Joel Sherrill2002-03-201-0/+5
| | | | | * PR148. * monitor/mon-prmisc.c: Fixed to print task states correctly.
* 2002-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-301-0/+4
| | | | * shell/shell.c: Remove #undef __STRICT_ANSI__.
* 2002-01-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-081-0/+4
| | | | * rootfs/Makefile.am: Use include_rtems_HEADERS instead of H_FILES.
* 2002-01-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-041-0/+4
| | | | * mw-fb/mw_uid.c: Apply rtems_set_errno_and_return_minus_one.
* 2001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-121-0/+4
| | | | * rootfs/mkrootfs.c, rootfs/mkrootfs.h: Fixed typo.
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-111-0/+6
* 2001-09-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-09-281-0/+6
| | | | | | * dummy/dummy.c: Now a useful configuration that starts main(). * wrapup/Makefile.am: Include a base level configuration in RTEMS library.
* 2001-09-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-281-0/+13
| | | | | | | | | | | | | * untar/Makefile.am: Use 'PREINSTALL_FILES ='. * monitor/Makefile.am: Use 'PREINSTALL_FILES ='. * shell/Makefile.am: Use 'PREINSTALL_FILES ='. * devnull/Makefile.am: Use 'PREINSTALL_FILES ='. * dumpbuf/Makefile.am: Use 'PREINSTALL_FILES ='. * mw-fb/Makefile.am: Use 'PREINSTALL_FILES ='. * stackchk/Makefile.am: Use 'PREINSTALL_FILES ='. * rtmonuse/Makefile.am: Use 'PREINSTALL_FILES ='. * cpuuse/Makefile.am: Use 'PREINSTALL_FILES ='. * rootfs/Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-09-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-09-271-1/+5
| | | | * ChangeLog: Fixed typo in date.
* 2001-09-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-09-211-0/+7
| | | | | | | * configure.in, rootfs/Makefile.am: Added conditional to make sure rootfs does not get built with networking is disabled. Also added include of compile.am to rootfs/Makefile.am. * wrapup/Makefile.am: Added rootfs conditionally if networking enabled.
* 2001-09-19 Chris Johns <ccj@acm.org>Joel Sherrill2001-09-191-0/+9
| | | | | | | | | * Added support for populating the initial "root" filesystem with information obtained via the DHCP response. * rootfs: New directory. * rootfs/.cvsignore, rootfs/Makefile.am, rootfs/mkrootfs.c, rootfs/mkrootfs.h: New files. * configure.in, Makefile.am: Modified to reflect addition.
* 2001-09-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-09-141-0/+40
| | | | * ChangeLog: Fixed some mistakes.
* 2001-09-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-09-131-0/+4
| | | | * devnull/devnull.c: Eliminate warning.
* 2001-08-09 Fernando-Ruiz Casas <correo@fernando-ruiz.com>Joel Sherrill2001-08-091-0/+4
| | | | * shell/pty.c: Moved to libnetworking/rtems_telnetd.
* 2001-08-09 Fernando-Ruiz Casas <correo@fernando-ruiz.com>Joel Sherrill2001-08-091-0/+5
| | | | | * shell/Makefile.am, shell/README, shell/cmds.c, shell/shell.c, shell/shell.h: Updates.
* 2001-08-09 Keith Outwater <vac4050@cae597.rsc.raytheon.com>Joel Sherrill2001-08-091-0/+6
| | | | | | * monitor/mon-command.c: Add support for partial command matching. The monitor used to have this functionality before it was overhauled to support addition of user commands.
* 2001-06-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-06-141-0/+7
| | | | | | | * shell/telnetd.c, shell/telnetd.h: Moved to libnetworking/rtems_servers so the network stack to address network depenendency. * shell/Makefile.am: Modified to reflect above.
* 2001-05-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-05-251-0/+4
| | | | * shell/cmds.c: Removed code from inappropriate source.
* 2000-05-24 Fernando Ruiz Casas <fernando.ruiz@ctv.es>Joel Sherrill2001-05-241-0/+21
| | | | | | | | | | | | | | | | | | | | | * monitor/mon-prmisc.c: Correct print line. * shell/Makefile.am: Added new file telnetd.c. * shell/telnetd.c, shell/telnetd.h, shell/pty.c: New files. * shell/shell.c, shell/cmds.c, shell/shell.h: Numerous improvments: - The shell_init has a new parameter 'forever' because in /dev/console you need that this process runs forever but in tcp/ip not. (respawn?) - A new task for every session opened trought tcp/ip telnet client. (the chargen,daytime and more are possible of implementation but I ask me if they are necesary) - Exit from the session delete the task and when the client fails too. - More cmds have been implemented. (very reduced version of these) umask, chmod, id, whoami, rm, cat, ... - A reduced line edit has been implemented. Ctrl-C abort the input, Ctrl-d in the first position gives EOF (logout). '\b' and DEL makes the rubout operation. I think that readline() for every session spents a lot of resources.
* 2001-04-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-071-1/+7
| | | | | * shell/cmds.c, shell/shell.c: Remove fileno-hacks. * monitor/mon-symbols.c: Remove #undef __STRICT_ANSI__.
* 2001-04-20 Correo Fernando-ruiz <correo@fernando-ruiz.com>Joel Sherrill2001-04-201-0/+6
| | | | | | | * Added initial shell functionality. * Makefile.am, configure.in, wrapup/Makefile.am: * shell/.cvsignore, shell/Makefile.am, shell/README, shell/cmds.c, shell/shell.c, shell/shell.h: New files.
* 2001-04-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-04-201-0/+7
| | | | | | | * devnull/devnull.c (null_initialize): Added check to ensure that the driver is only initialized once. Otherwise, it will abort when the device /dev/null is present. (null_write): Do not dereference a NULL pointer.
* 2001-02-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-121-0/+4
| | | | * monitor/mon-command.c: Use #if defined(RTEMS_UNIX).
* 2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-051-0/+7
| | | | | | | * untar/Makefile.am, monitor/Makefile.am, dummy/Makefile.am, devnull/Makefile.am, dumpbuf/Makefile.am, mw-fb/Makefile.am, stackchk/Makefile.am, rtmonuse/Makefile.am, cpuuse/Makefile.am: Apply include_*HEADERS instead of H_FILES.
* 2001-01-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-051-0/+8
| | | | | | | | * devnull: New addition. Moved from libcpu/sh. * devnull/devnull.c, devnull/devnull.h, devnull/.cvsignore, devnull/Makefile.am: New files. * Makefile.am, configure.in, wrapup/Makefile.am: Modified to reflect addition of above.
* 2000-11-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-301-0/+4
| | | | * mw-fb/mw_uid.c: Removed unnecessary dependency on <bsp.h>.
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-091-0/+4
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-021-0/+4
* 2000-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-251-0/+5
* 2000-09-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-281-0/+5
| | | | | * monitor/mon-driver.c: Accounted for addition of "_entry" to fields in rtems_driver_address_table.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-051-0/+7
| | | | | | | * cpuuse/Makefile.am, dummy/Makefile.am, dumpbuf/Makefile.am, monitor/Makefile.am, rtmonuse/Makefile.am, stackchk/Makefile.am, untar/Makefile.am, wrapup/Makefile.am, mw-fb/Makefile.am: Include compile.am.
* 2000-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-08-301-0/+6
| | | | | | * Many files: Moved posix/include/rtems/posix/seterr.h to score/include/rtems/seterr.h so it would be available within all APIs.
* 2000-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-08-301-0/+4
| | | | * mw-fb/.cvsignore: New file.
* 2000-08-26 Rosimildo da Silva <rdasilva@connecttel.com>Joel Sherrill2000-08-301-0/+16
| | | | | | | | | | | | | | | | * Added generic Micro FrameBuffer interface for MicroWindows. This interface allows MicroWindows to under RTEMS. A sample driver has been developed for the pc386 BSP. See pc386/fb_vga.c as a sample. * Added Uniform Input Device interface for MicroWindows. See PC386 bsp for sample drivers for mouse and keyboard (console). * mw-bf: New directory. * Makefile.am, configure.in, wrapup/Makefile.am: Account for mw-fb. * mw-fb/Makefile.am: New file. * mw-fb/mw_fb.c: New file. * mw-fb/mw_fb.h: New file. * mw-fb/mw_uid.c: New file. * mw-fb/mw_uid.h: New file.
