* configure.in, rootfs/Makefile.am: Added conditional to make sure
rootfs does not get built with networking is disabled. Also
added include of compile.am to rootfs/Makefile.am.
* wrapup/Makefile.am: Added rootfs conditionally if networking enabled.
* Added support for populating the initial "root" filesystem
with information obtained via the DHCP response.
* rootfs: New directory.
* rootfs/.cvsignore, rootfs/Makefile.am, rootfs/mkrootfs.c,
rootfs/mkrootfs.h: New files.
* configure.in, Makefile.am: Modified to reflect addition.
* ChangeLog: Fixed some mistakes.
* devnull/devnull.c: Eliminate warning.
* shell/pty.c: Moved to libnetworking/rtems_telnetd.
* shell/Makefile.am, shell/README, shell/cmds.c, shell/shell.c,
shell/shell.h: Updates.
* monitor/mon-command.c: Add support for partial command matching.
The monitor used to have this functionality before it was overhauled
to support addition of user commands.
* shell/telnetd.c, shell/telnetd.h: Moved to
libnetworking/rtems_servers so the network stack to address network
depenendency.
* shell/Makefile.am: Modified to reflect above.
* shell/cmds.c: Removed code from inappropriate source.
* monitor/mon-prmisc.c: Correct print line.
* shell/Makefile.am: Added new file telnetd.c.
* shell/telnetd.c, shell/telnetd.h, shell/pty.c: New files.
* shell/shell.c, shell/cmds.c, shell/shell.h: Numerous improvments:
- The shell_init has a new parameter 'forever' because in
/dev/console you need that this process runs forever but in
tcp/ip not. (respawn?)
- A new task for every session opened trought tcp/ip telnet client.
(the chargen,daytime and more are possible of implementation but
I ask me if they are necesary)
- Exit from the session delete the task and when the client fails too.
- More cmds have been implemented. (very reduced version of these)
umask, chmod, id, whoami, rm, cat, ...
- A reduced line edit has been implemented.
Ctrl-C abort the input,
Ctrl-d in the first position gives EOF (logout).
'\b' and DEL makes the rubout operation.
I think that readline() for every session spents a lot of resources.
* shell/cmds.c, shell/shell.c: Remove fileno-hacks.
* monitor/mon-symbols.c: Remove #undef __STRICT_ANSI__.
* Added initial shell functionality.
* Makefile.am, configure.in, wrapup/Makefile.am:
* shell/.cvsignore, shell/Makefile.am, shell/README,
shell/cmds.c, shell/shell.c, shell/shell.h: New files.
* devnull/devnull.c (null_initialize): Added check to
ensure that the driver is only initialized once. Otherwise,
it will abort when the device /dev/null is present.
(null_write): Do not dereference a NULL pointer.
* monitor/mon-command.c: Use #if defined(RTEMS_UNIX).
* untar/Makefile.am, monitor/Makefile.am, dummy/Makefile.am,
devnull/Makefile.am, dumpbuf/Makefile.am, mw-fb/Makefile.am,
stackchk/Makefile.am, rtmonuse/Makefile.am, cpuuse/Makefile.am:
* devnull: New addition. Moved from libcpu/sh.
* devnull/devnull.c, devnull/devnull.h, devnull/.cvsignore,
devnull/Makefile.am: New files.
* Makefile.am, configure.in, wrapup/Makefile.am: Modified to reflect
addition of above.
* mw-fb/mw_uid.c: Removed unnecessary dependency on <bsp.h>.
* monitor/mon-driver.c: Accounted for addition of "_entry" to
fields in rtems_driver_address_table.
* cpuuse/Makefile.am, dummy/Makefile.am, dumpbuf/Makefile.am,
monitor/Makefile.am, rtmonuse/Makefile.am, stackchk/Makefile.am,
untar/Makefile.am, wrapup/Makefile.am, mw-fb/Makefile.am:
Include compile.am.
all APIs.
* mw-fb/.cvsignore: New file.
* Added generic Micro FrameBuffer interface for MicroWindows.
This interface allows MicroWindows to under RTEMS. A sample
driver has been developed for the pc386 BSP. See
pc386/fb_vga.c as a sample.
* Added Uniform Input Device interface for MicroWindows.
See PC386 bsp for sample drivers for mouse and keyboard (console).
* mw-bf: New directory.
* Makefile.am, configure.in, wrapup/Makefile.am: Account for mw-fb.
* mw-fb/Makefile.am: New file.
* mw-fb/mw_fb.c: New file.
* mw-fb/mw_fb.h: New file.
* mw-fb/mw_uid.c: New file.
* mw-fb/mw_uid.h: New file.
