path: root/cpukit/libmd (follow)
* libmd: Disable SHA modules for m32cSebastian Huber2015-03-052-0/+3
| | | | Close #2219.
* Add SHA256 and SHA512 supportSebastian Huber2014-11-206-2/+758
* libmd: Change MD5Update() prototypeSebastian Huber2013-10-312-2/+5
| | | | | This is in line with the FreeBSD and OpenSSL prototypes. It helps to avoid superfluous compiler warnings.
* libmd: New defines for FreeBSD compatibilitySebastian Huber2013-10-221-0/+3
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-113-6/+0
* Revert: Remove CVS IdsJoel Sherrill2012-05-071-0/+4
* Remove CVS-Ids.Ralf Corsépius2012-05-041-4/+0
* Remove all .cvsignore files.Joel Sherrill2012-02-011-2/+0
* 2010-09-13 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2010-09-131-0/+8
| | | | * libmd/md5.h: C++ compatibility.
* 2010-07-16 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2010-07-161-3/+0
| | | | * libmd/md4.c: Removed definition of TRUE and FALSE.
* 2010-06-14 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-06-141-2/+0
| | | | * libmd/md5.h: Revert Sebastian's patch.
* 2010-06-14 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2010-06-141-0/+2
| | | | * libmd/md5.h: Define MD5_DIGEST_SIZE.
* Add HAVE_CONFIG_H support to let files receive configure defines.Ralf Corsepius2010-03-282-0/+8
* #include <stdint.h> instead of <rtems/stdint.h>.Ralf Corsepius2008-12-112-2/+2
* Stop using old-style function-definitions.Ralf Corsepius2008-08-252-13/+13
* Add missing prototypes.Ralf Corsepius2008-08-022-14/+14
* 2007-06-12 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-06-121-0/+2
| | | | * libmd/.cvsignore: New file.
* New (moved out from pppd).Ralf Corsepius2007-06-126-0/+747
