Updates #6442
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Close #2219.
This is in line with the FreeBSD and OpenSSL prototypes. It helps to
avoid superfluous compiler warnings.
for details.
* libmd/md5.h: C++ compatibility.
* libmd/md4.c: Removed definition of TRUE and FALSE.
* libmd/md5.h: Revert Sebastian's patch.
* libmd/md5.h: Define MD5_DIGEST_SIZE.
* libmd/.cvsignore: New file.
