* libi2c/libi2c.h: Fix typo.
* libi2c/README_libi2c: Correct spelling error.
* score/src/threadclearstate.c: Improve comment.
* libi2c/libi2c.c, libi2c/libi2c.h, libi2c/README_libi2c:
Added checks so that use of 'stdio' is avoided (falling
back to 'printk') before the system is up.
Publish driver entry points so that the libi2c driver could
be added to the applications 'device driver table'.
This is not fully implemented yet, though, since in addition to
initializing libi2c the low-level i2c bus drivers as well
as high-level i2c device drivers need to be registered
with the library.
Updated README_libi2c accordingly.
added IRQ support to MPC83xx i2c driver
added mpc83xx spi driver
* libi2c/libi2c.c, libi2c/libi2c.h: Add message about needing IMFS.
Fixed check of status when registering driver. Add use of strerror().
Added SLAC/Stanford Authorship Note / Copyright + Liability Disclaimer.
* libi2c/Makefile.am, libi2c/Makefile.in, libi2c/libi2c.c,
libi2c/libi2c.h: New files.
* Makefile.am, configure.ac, preinstall.am, wrapup/Makefile.am: added a
simple API/library for i2c devices and drivers for i2c 2-byte eeproms
and a ds1621 temperature sensor; API is documented in libi2c.h
