for details.
* libblock/src/nvdisk-sram.c, libi2c/libi2c.c,
libmisc/shell/main_msdosfmt.c: Eliminate use of GNU old-style field
designator extension as recommended by clang.
Coverity Id 125
Coverity Id 126
* libi2c/libi2c.c: Use strncpy and snprintf.
* libi2c/libi2c.c: Fix typo in va_end().
PR 1554/cpukit
Coverity Id 17
* libi2c/libi2c.c, score/src/objectextendinformation.c: Fix memory leak
on error.
* libi2c/libi2c.c: Fix warnings.
* libcsupport/include/rtems/libio_.h,
libcsupport/src/fs_null_handlers.c: Null handlers are now const.
* libi2c/libi2c.c, libi2c/libi2c.h: Documentation. Do not create
semaphores on the fly.
* cpukit/libblock/src/bdpart.c: Fixed format specifier.
* cpukit/libblock/include/rtems/bdbuf.h, rtems/include/rtems.h,
rtems/include/rtems/rtems/asr.h, rtems/include/rtems/rtems/attr.h,
rtems/include/rtems/rtems/barrier.h,
rtems/include/rtems/rtems/barriermp.h,
rtems/include/rtems/rtems/cache.h, rtems/include/rtems/rtems/clock.h,
rtems/include/rtems/rtems/config.h, rtems/include/rtems/rtems/dpmem.h,
rtems/include/rtems/rtems/event.h,
rtems/include/rtems/rtems/eventmp.h,
rtems/include/rtems/rtems/eventset.h,
rtems/include/rtems/rtems/intr.h, rtems/include/rtems/rtems/message.h,
rtems/include/rtems/rtems/modes.h, rtems/include/rtems/rtems/mp.h,
rtems/include/rtems/rtems/msgmp.h, rtems/include/rtems/rtems/object.h,
rtems/include/rtems/rtems/part.h, rtems/include/rtems/rtems/partmp.h,
rtems/include/rtems/rtems/region.h,
rtems/include/rtems/rtems/regionmp.h,
rtems/include/rtems/rtems/rtemsapi.h, rtems/include/rtems/rtems/sem.h,
rtems/include/rtems/rtems/semmp.h, rtems/include/rtems/rtems/signal.h,
rtems/include/rtems/rtems/signalmp.h,
rtems/include/rtems/rtems/status.h,
rtems/include/rtems/rtems/support.h,
rtems/include/rtems/rtems/taskmp.h, rtems/include/rtems/rtems/tasks.h,
rtems/include/rtems/rtems/timer.h, rtems/include/rtems/rtems/types.h,
rtems/inline/rtems/rtems/support.inl: Documentation.
* include/rtems/irq-extension.h: Documentation. Added API for
interrupt servers.
Add extern's.
PR 1326/cpukit
* libi2c/libi2c.c: Use int for return value when negative values
possible.
entry in the rtems_libi2c_tfr_mode_t structure:
idle_char. This character will be continuously transmitted in
read only functions.
* libi2c/libi2c.h: Fix typo.
* libi2c/README_libi2c: Correct spelling error.
* score/src/threadclearstate.c: Improve comment.
* libi2c/libi2c.c, libi2c/libi2c.h, libi2c/README_libi2c:
Added checks so that use of 'stdio' is avoided (falling
back to 'printk') before the system is up.
Publish driver entry points so that the libi2c driver could
be added to the applications 'device driver table'.
This is not fully implemented yet, though, since in addition to
initializing libi2c the low-level i2c bus drivers as well
as high-level i2c device drivers need to be registered
with the library.
Updated README_libi2c accordingly.
added IRQ support to MPC83xx i2c driver
added mpc83xx spi driver
* libi2c/libi2c.c, libi2c/libi2c.h: Add message about needing IMFS.
Fixed check of status when registering driver. Add use of strerror().
Added SLAC/Stanford Authorship Note / Copyright + Liability Disclaimer.
* libi2c/Makefile.am, libi2c/Makefile.in, libi2c/libi2c.c,
libi2c/libi2c.h: New files.
* Makefile.am, configure.ac, preinstall.am, wrapup/Makefile.am: added a
simple API/library for i2c devices and drivers for i2c 2-byte eeproms
and a ds1621 temperature sensor; API is documented in libi2c.h
