path: root/cpukit/libi2c/README_libi2c (follow)
* Spelling and grammar fixes in source code comments (GCI 2018)Marçal Comajoan Cara2018-12-041-1/+1
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-111-4/+0
* 2008-01-22 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2008-01-221-16/+16
| | | | | * libi2c/README_libi2c: Correct spelling error. * score/src/threadclearstate.c: Improve comment.
* 2007-11-17 Till Straumann <strauman@slac.stanford.edu>Till Straumann2007-11-211-0/+22
| | | | | | | | | | | | | * libi2c/libi2c.c, libi2c/libi2c.h, libi2c/README_libi2c: Added checks so that use of 'stdio' is avoided (falling back to 'printk') before the system is up. Publish driver entry points so that the libi2c driver could be added to the applications 'device driver table'. This is not fully implemented yet, though, since in addition to initializing libi2c the low-level i2c bus drivers as well as high-level i2c device drivers need to be registered with the library. Updated README_libi2c accordingly.
* *** empty log message ***Thomas Doerfler2007-10-261-18/+185
* added documentation to libi2cThomas Doerfler2007-10-251-0/+178
