path: root/cpukit/libgnat (follow)
* Remove superfluous <rtems/system.h> includesSebastian Huber2019-03-141-1/+0
* build: Merge libgnat/Makefile.amSebastian Huber2018-10-101-10/+0
* build: Remove EXTRA_DISTSebastian Huber2018-04-041-1/+0
| | | | | A "make dist" is not supported. So, it makes no sense to have pure "make dist" related stuff in the Makefile.am.
* ada: Add missing includeJan Sommer2015-10-301-0/+1
| | | | | Include stackimpl.h otherwise PTHREAD_MINIMUM_STACK_SIZE cannot be evaluated.
* PR766: Delete __RTEMS_INSIDE__Sebastian Huber2013-08-081-2/+0
* posix: Create pthread implementation headerSebastian Huber2013-07-221-1/+1
| | | | | | Move implementation specific parts of pthread.h and pthread.inl into new header file pthreadimpl.h. The pthread.h contains now only the application visible API.
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-113-10/+0
* Revert: Remove CVS IdsJoel Sherrill2012-05-071-0/+4
* Remove CVS-Ids.Ralf Corsépius2012-05-041-4/+0
* Remove all .cvsignore files.Joel Sherrill2012-02-011-2/+0
* 2010-03-27 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-03-271-0/+15
| | | | | * libgnat/ada_intrsupp.c, telnetd/check_passwd.c, telnetd/des.c, telnetd/genpw.c: Add include of config.h
* Whitespace removal.Ralf Corsepius2009-11-301-5/+5
* 2008-12-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-12-161-2/+7
| | | | | * libgnat/adasupp.c: Add helper method so Ada binding does not reference _TOD_Microseconds_per_tick.
* Use LIBGNAT.Ralf Corsepius2008-06-301-1/+1
* 2007-12-12 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-12-121-1/+3
| | | | | * libgnat/Makefile.am, wrapup/Makefile.am: Another attempt at the automake variables.
* 2007-12-12 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-12-121-2/+1
| | | | * libgnat/Makefile.am: Handle POSIX being disabled correctly.
* 2007-12-11 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2007-12-124-0/+180
* Makefile.am, configure.ac, posix/Makefile.am, wrapup/Makefile.am: Move Ada support code that is untestable from the Standard RTEMS Test Suite into its own directory. All code in score, posix, rtems, and sapi should be testable by the Standard RTEMS Test Suites. It was buried under POSIX before so this should be a clearer location anyway. * libgnat/.cvsignore, libgnat/Makefile.am, libgnat/ada_intrsupp.c, libgnat/adasupp.c: New files. * posix/src/ada_intrsupp.c, posix/src/adasupp.c: Removed.
