Include stackimpl.h otherwise PTHREAD_MINIMUM_STACK_SIZE cannot be
evaluated.
Move implementation specific parts of pthread.h and pthread.inl into new
header file pthreadimpl.h. The pthread.h contains now only the
application visible API.
for details.
* libgnat/ada_intrsupp.c, telnetd/check_passwd.c, telnetd/des.c,
telnetd/genpw.c: Add include of config.h
* libgnat/adasupp.c: Add helper method so Ada binding does not
reference _TOD_Microseconds_per_tick.
* libgnat/Makefile.am, wrapup/Makefile.am: Another attempt at the
automake variables.
* libgnat/Makefile.am: Handle POSIX being disabled correctly.
* Makefile.am, configure.ac, posix/Makefile.am, wrapup/Makefile.am:
Move Ada support code that is untestable from the Standard RTEMS Test
Suite into its own directory. All code in score, posix, rtems, and
sapi should be testable by the Standard RTEMS Test Suites. It was
buried under POSIX before so this should be a clearer location
anyway.
* libgnat/.cvsignore, libgnat/Makefile.am, libgnat/ada_intrsupp.c,
libgnat/adasupp.c: New files.
* posix/src/ada_intrsupp.c, posix/src/adasupp.c: Removed.
