path: root/cpukit/libgnat (follow)
* 2008-12-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-12-161-2/+7
| | | | | * libgnat/adasupp.c: Add helper method so Ada binding does not reference _TOD_Microseconds_per_tick.
* Use LIBGNAT.Ralf Corsepius2008-06-301-1/+1
* 2007-12-12 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-12-121-1/+3
| | | | | * libgnat/Makefile.am, wrapup/Makefile.am: Another attempt at the automake variables.
* 2007-12-12 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-12-121-2/+1
| | | | * libgnat/Makefile.am: Handle POSIX being disabled correctly.
* 2007-12-11 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2007-12-124-0/+180
* Makefile.am, configure.ac, posix/Makefile.am, wrapup/Makefile.am: Move Ada support code that is untestable from the Standard RTEMS Test Suite into its own directory. All code in score, posix, rtems, and sapi should be testable by the Standard RTEMS Test Suites. It was buried under POSIX before so this should be a clearer location anyway. * libgnat/.cvsignore, libgnat/Makefile.am, libgnat/ada_intrsupp.c, libgnat/adasupp.c: New files. * posix/src/ada_intrsupp.c, posix/src/adasupp.c: Removed.
