* | Use LIBGNAT. | Ralf Corsepius | 2008-06-30 | 1 | -1/+1 |
* | 2007-12-12 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-12-12 | 1 | -1/+3 |
| | | | | | * libgnat/Makefile.am, wrapup/Makefile.am: Another attempt at the automake variables. | ||||
* | 2007-12-12 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-12-12 | 1 | -2/+1 |
| | | | | * libgnat/Makefile.am: Handle POSIX being disabled correctly. | ||||
* | 2007-12-11 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2007-12-12 | 4 | -0/+180 |
* Makefile.am, configure.ac, posix/Makefile.am, wrapup/Makefile.am: Move Ada support code that is untestable from the Standard RTEMS Test Suite into its own directory. All code in score, posix, rtems, and sapi should be testable by the Standard RTEMS Test Suites. It was buried under POSIX before so this should be a clearer location anyway. * libgnat/.cvsignore, libgnat/Makefile.am, libgnat/ada_intrsupp.c, libgnat/adasupp.c: New files. * posix/src/ada_intrsupp.c, posix/src/adasupp.c: Removed. |
