Update #3850
Update #3850
This speeds up reading fragmented files.
Fix #3689
Update #3706.
Update #3706.
Update #3706.
- Do not write past the last location of the search bit map
whe nit is being created.
Closes #4148
Currently if mount fails, a converter isn't destroyed. We have to take
care of two cases:
1. The user doesn't provide a converter.
In this case mounting a dosfs creates a default converter. This patch
makes sure that the converter is destroyed again if mount failes for
this case.
2. The user provides a converter.
In this case it's not sure that the dosfs specific routines are reached
because mount can fail before that. Therefore the user has to destroy
the converter himself again. This patch adds a documentation for that
and implements it in the media server.
Closes #4042.
Close #3420.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Add a simplified path evaluation function IMFS_eval_path_devfs() for a
device only IMFS configuration.
The code size can be further reduced by the application if it disables
the support for legacy IO drivers via:
#define CONFIGURE_IMFS_DISABLE_MKNOD
#define CONFIGURE_IMFS_DISABLE_MKNOD_DEVICE
Obsolete CONFIGURE_MAXIMUM_DEVICES. Remove BSP_MAXIMUM_DEVICES.
Update #3894.
Update #3898.
Update #3894.
Update #3894.
The CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK value is validated by
<rtems/confdefs/libio.h>. Changing this value during runtime could lead
to memory corruption.
Update #3894.
Update #3894.
Update #3894.
Update #3894.
Remove IMFS_NODE_FLAG_NAME_ALLOCATED and instead replace the node
control in rename operations. This avoids a special case in the general
node destruction which pulled in free().
Update #3894.
Dead code identified by Coverity (CID 1456674). The value of ret
at line 358 is always 0.
Dead code identified by Coverity (CID 1456678). The value of ret
at line 293 is always 0.
Use self-contained condition variables instead of Classic API barriers.
This simplifies the implementation and configuration.
Update #3840.
Update #3823.
Fix prototype.
Fix node size. Linfiles are dynamically turned into memfiles.
Update #3823.
Update #3818.
Update #3706.
This makes the @file documentation independent of the actual file name.
Update #3707.
Username: deuteriumoxide Email: jacobshin313@gmail.com
Update #3358.
Closes #3581.
Avoid the use of a constant register variable which is used in some
conditions. This gets rid of a clang -Wsometimes-uninitialized warning.
Update #3530.
Update #3533.
Add and use <machine/rtems-bsd-kernel-space.h> and
<machine/rtems-bsd-user-space.h> similar to the libbsd to avoid command
line defines and defines scattered throught the code base.
Simplify cpukit/libnetworking/Makefile.am.
Update #3375.
Update #3358.
The function rtems_rfs_buffer_sync() erroneously calls
rtems_disk_release(). This screws up the reference counting of the disk.
Close #3484.
This makes it easer to find files describing an upstream version, e.g.
via "find -name VERSION".
Update #3465.
Add README to document the corrspending Linux version and the update
procedure.
Close #3465.
->fail_addr and ->addr can be updated no matter the result of
parent->_erase(), we just need to remove the code doing the same thing
in mtd_erase_callback() to avoid adjusting those fields twice.
Note that this can be done because all MTD users have been converted to
not pass an erase_info->callback() and are thus only taking the
->addr_fail and ->addr fields into account after part_erase() has
returned.
While we're at it, get rid of the erase_info->mtd field which was only
needed to let mtd_erase_callback() get the partition device back.
Signed-off-by: Boris Brezillon <boris.brezillon@bootlin.com>
Reviewed-by: Richard Weinberger <richard@nod.at>
None of the mtd->_erase() implementations work in an asynchronous manner,
so let's simplify MTD users that call mtd_erase(). All they need to do
is check the value returned by mtd_erase() and assume that != 0 means
failure.
trivial fix to spelling mistake in JFFS2_ERROR message
Signed-off-by: Colin Ian King <colin.king@canonical.com>
[Brian: also fix 'an' -> 'a']
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
<linux/sched.h> into <linux/sched/signal.h>
Fix up affected files that include this signal functionality via sched.h.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: Mike Galbraith <efault@gmx.de>
Cc: Peter Zijlstra <peterz@infradead.org>
Cc: Thomas Gleixner <tglx@linutronix.de>
Cc: linux-kernel@vger.kernel.org
Signed-off-by: Ingo Molnar <mingo@kernel.org>
