path: root/cpukit/libfs (follow)
* 2003-08-05 <djc915@mail.usask.ca>Jennifer Averett2003-08-052-7/+9
| | | | | PR 443/filesystem * src/imfs/deviceio.c: deviceio.c mishandles return codes
* 2003-08-05 Thomas Doerfler <Thomas.Doerfler@imd-systems.de>Jennifer Averett2003-08-051-0/+5
| | | | | PR 440/filesystem * src/dosfs/fat_fat_operations.c: Improve write data speed for DOSFS FAT12/FAT16 systems
* 2003-08-05 Thomas Doerfler <Thomas.Doerfler@imd-systems.de>Jennifer Averett2003-08-051-13/+17
| | | | | PR 439/filesystem * src/dosfs/fat_fat_operations.c: Improve write data speed for DOSFS FAT12/FAT16 systems
* Fixed Change log comments.Jennifer Averett2003-08-051-6/+6
| | | | | PR 439/filesystem *src/dosfs/fat_file.c: flush temporary buffer when closing files
* 2003-08-04 Thomas Doerfler <Thomas.Doerfler@imd-systems.de>Jennifer Averett2003-08-051-0/+9
| | | | | | | | | PR 441/filesystem *src/dosfs/msdos.h: add rename support to DOSFS *src/dosfs/msdos_create.c: add rename support to DOSFS *src/dosfs/msdos_file.c: add rename support to DOSFS *src/dosfs/msdos_init.c: add rename support to DOSFS *src/dosfs/msdos_mknod.c: add rename support to DOSFS
* 2003-08-04 Thomas Doerfler <Thomas.Doerfler@imd-systems.de>Jennifer Averett2003-08-054-7/+159
* 2003-07-24 Jennifer Averett <jennifer.averett@OARcorp.com>Joel Sherrill2003-07-241-0/+7
| | | | | | | PR 434/filesystem * src/imfs/imfs_init.c: Modified to return error code * src/imfs/miniimfs_init.c: Modified to return error code * src/imfs/imfs_initsup.c: Modified to set error upon memory failure.
* 2003-07-24 jennifer averett <jennifer.averett@OARcorp.com>Jennifer Averett2003-07-243-5/+4
* 2003-07-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-07-161-1/+7
| | | | * ChangeLog: Correct format.
* PR431. MSDOS Volume semaphore timeout is now NO TIMEOUT. MSDOS volume ↵Chris Johns2003-07-141-0/+4
| | | | opertations will wait for ever.
* MSDOS Volume semaphore timeout is now NO TIMEOUT. MSDOS volume opertations ↵Chris Johns2003-07-141-2/+3
| | | | will wait for ever.
* CleanupRalf Corsepius2003-07-081-13/+0
* 2003-07-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-088-58/+43
| | | | | | | | | | | | * configure.ac: Remove (Merged-in into ../configure.ac) * Makefile.am, src/Makefile.am, src/dosfs/Makefile.am, src/imfs/Makefile.am: Reflect having merged configure.ac into ../configure.ac. * src/dosfs/config.h: New. * src/dosfs/Makefile.am: Add config.h. * src/imfsfs/config.h: New. * src/imfs/Makefile.am: Add config.h. Remove COMMON_C_FILES, DOC_FILES (Unused).
* 2003-07-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-085-0/+23
| | | | | | | * src/dosfs/fat.c: include config-header "config.h". * src/dosfs/fat_fat_operations.c: Ditto. * src/dosfs/fat_file.c: Ditto. * src/dosfs/msdos_conv.c: Ditto.
* Fixed formatting.Joel Sherrill2003-07-021-0/+1
* Patch from Victor V. Vengerov <vvv@oktet.ru> to remove Linux code.Chris Johns2003-07-027-167/+318
* Comments have been updated.Chris Johns2003-07-022-3/+2
* 2003-06-10 Phil Torre <ptorre@zetron.com>Joel Sherrill2003-06-103-7/+19
| | | | | | PR 411/filesystem * src/imfs/imfs_unlink.c: Fix bug where renaming a memfile and then unlinking it causes a memory leak.
* 2003-03-25 Thomas Doerfler <Thomas.Doerfler@imd-systems.de>Joel Sherrill2003-03-258-19/+138
| | | | | | | | | | | PR 367/filesystem * src/dosfs/Makefile.am, src/dosfs/fat.c, src/dosfs/fat.h, src/dosfs/fat_fat_operations.c, src/dosfs/fat_file.c, src/dosfs/msdos.h, src/dosfs/msdos_dir.c: Some bugs were still present in the DOSFS implementation: - FAT12 did not work properly on Big-Endian machines - Some synchronization and error handling problems were present - Some legal codings for EOC were not recognized
* Merger from rtems-4-6-branch.Ralf Corsepius2003-03-112-1/+4
* 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-02-112-1/+5
| | | | * configure.ac: AM_INIT_AUTOMAKE([1.7.2]).
| | | | * configure.ac: AC_PREREQ(2.57).
* 2003-02-03 Steven Johnson <sjohnson@neurizon.net>Joel Sherrill2003-02-032-9/+12
| | | | | | PR 338/filesystem * src/imfs/ioman.c: Fix reentrancy problem with rtems_io_lookup_name() (API change).
* 2003-01-03 Eugeny S. Mints <Eugeny.Mints@oktet.ru>Joel Sherrill2003-01-032-1/+6
| | | | | * src/dosfs/msdos_initsupp.c: Specify inherited priority as 0 since this is a FIFO queuing semaphore.
* 2002-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-123-8/+7
| | | | | * src/imfs/Makefile.am: Eliminate C_O_FILES. * src/dosfs/Makefile.am: Ditto.
* 2002-12-02 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-12-023-15/+20
| | | | | * src/dosfs/fat.h, src/dosfs/msdos.h: Added casts to remove warnings on 16 bit targets like the h8300.
* 2002-11-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-192-1/+5
| | | | * configure.ac: Cosmetical fixes.
| | | | * configure.ac: Fix package name.
* 2002-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-252-1/+5
| | | | * configure.ac: Add nostdinc to AM_INIT_AUTOMAKE.
* 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-212-4/+10
| | | | | | * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache.
* 2002-10-02 Jennifer Averett <jennifer@OARcorp.com>Joel Sherrill2002-10-022-2/+16
| | | | | | * src/imfs/memfile.c: Fixed case where last close of unlinked file did not remove the resources associated with that file. Reported by Till Straumann <strauman@slac.stanford.edu> on the mailing list.
* 2002-09-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-09-147-18/+34
| | | | | | | | * src/dosfs/fat.c, src/imfs/deviceio.c, src/imfs/imfs.h, src/imfs/imfs_directory.c, src/imfs/imfs_fchmod.c, src/imfs/memfile.c: Eliminated warnings. A lot of this focus was on changing read and write entry points to return ssize_t as read(2) and write(2) now do.
* 2002-07-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-315-61/+6
| | | | | | | * wrapup/Makefile.am: Remove. * wrapup/.cvsignore: Remove. * Makefile.am: Remove wrapup SUBDIR. * configure.ac: Remove wrapup/Makefile.
* 2002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-223-2/+7
| | | | | * src/dosfs/Makefile.am: Use .$(OBJEXT) instead of .o. * src/src/imfs/Makefile.am: Ditto.
* 2002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-224-14/+14
| | | | | | | | * src/dosfs/Makefile.am: Use AM_CPPFLAGS instead of INCLUDES and AM_CFLAGS. Eliminate LIBNAME. * src/imfs/Makefile.am: Use AM_CPPFLAGS instead of INCLUDES and AM_CFLAGS. Eliminate LIBNAME. * wrapup/Makefile.am: Eliminate LIBNAME.
* 2002-07-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-052-1/+5
| | | | * configure.ac: RTEMS_TOP(../..).
* 2002-07-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-012-2/+4
| | | | * configure.ac: Remove RTEMS_PROJECT_ROOT.
* 2002-06-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-272-1/+7
| | | | | * configure.ac: Use AC_CONFIG_AUX_DIR(../..). Add AC_PROG_RANLIB.
* 2002-06-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-262-7/+5
| | | | * wrapup/Makefile.am: Don't preinstall libfs.a.
* 2002-06-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-176-17/+26
| | | | | | | | | * src/dosfs/Makefile.am: Include $(top_srcdir)/../automake/*.am. * src/Makefile.am: Include $(top_srcdir)/../automake/*.am. * src/imfs/Makefile.am: Include $(top_srcdir)/../automake/*.am. * Makefile.am: Include $(top_srcdir)/../automake/*.am. Use ../aclocal. * wrapup/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* 2002-05-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-05-287-22/+30
| | | | | | | | | | Move from c/src/libfs to c/src/exec/libfs * configure.ac: Reflect move. * Makefile.am: Ditto. * src/Makefile.am: Ditto. * src/dosfs/Makefile.am: Ditto. * src/imfs/Makefile.am: Ditto. * wrapup/Makefile.am: Ditto.
* 2002-04-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-086-0/+14
| | | | | | | | * src/imfs/imfs_getchild.c: include <string.h>. * src/imfs/imfs_gtkn.c: Include <string.h>. * src/imfs/ioman.c: Include <string.h>. * src/imfs/linearfile.c: Include <string.h>. * src/imfs/memfile.c: Include <string.h>.
* 2001-04-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-04-042-2/+6
| | | | | * src/dosfs/Makefile.am: Per PR129 do not install as many files to the $(includedir).
* 2002-04-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-042-3/+7
| | | | | * src/dosfs/fat.h: Include <string.h>. Remove DBG1 and DBG2 (unused).
* 2002-04-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-041-0/+6
| | | | | * Per PR169. * src/dosfs/config.h.in, src/dosfs/stamp-h2.in: Removed from CVS.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-283-4/+9
| | | | | | * src/dosfs/fat_file.c: Remove bsp.h. fat_file_write(.. const char*buf ..). * src/dosfs/fat_file.h: fat_file_write(.. const char*buf ..).
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-287-7/+13
| | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * src/dosfs/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/imfs/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2002-03-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-205-5/+20
| | | | | | | | | | | | | Addressing PR 140. * src/dosfs/config.h.in: Removed. * src/dosfs/stamp-h2.in: Removed. * .cvsignore: Add config.h*, stamp-h*. * configure.ac: Remove AC_SRC_DIR(.../dosfs.h). Remove AM_CONFIG_HEADER(src/dosfs/config.h). Remove AM_CONFIG_HEADER(src/imfs/config.h). Add AM_CONFIG_HEADER(config.h). * src/dosfs/Makefile.am: INCLUDES = -I../.. . * src/imfs/Makefile.am: INCLUDES = -I../.. .
