PR 1948/filesystem
* libfs/src/rfs/rtems-rfs-file-system.c,
libfs/src/rfs/rtems-rfs-file-system.h,
libfs/src/rfs/rtems-rfs-format.c, libfs/src/rfs/rtems-rfs-rtems.c:
Add support for mount passing an ASCIIZ string containing
configuration options. Remove the hardcoded dir string and
size. Fix comments.
* libblock/src/bdbuf.c: Fix state labels in trace output.
* libfs/src/imfs/imfs.h: Add IMFS_memfile_maximum_size.
* libfs/src/dosfs/msdos_file.c (msdos_file_datasync):
Remove unused var "rc".
* libfs/src/pipe/fifo.c: Conditionally use var "sc".
* libfs/src/rfs/rtems-rfs-file-system.c (rtems_rfs_fs_open):
Comment out unused vars "group", "group_base".
* libfs/src/devfs/devfs_mknod.c: Remove const cast.
* libfs/src/imfs/ioman.c: Remove const cast.
* libfs/src/devfs/devfs.h: Make device_name a const char*.
* sapi/include/rtems/io.h: Make device_name a const char*.
* libfs/src/imfs/memfile.c (memfile_ioctl): Remove unused var
"the_jnode".
PR 1877/cpukit
* libfs/src/imfs/imfs_mknod.c, libfs/src/imfs/memfile.c,
sapi/inline/rtems/rbtree.inl, score/include/rtems/score/rbtree.h,
score/inline/rtems/score/rbtree.inl, score/src/rbtree.c,
score/src/rbtreefind.c, score/src/rbtreeinsert.c: Add comparison
function for RBTrees.
* libfs/src/nfsclient/src/nfs.c: Fixed creation of directories.
* libfs/src/dosfs/fat_file.c, libmisc/monitor/monitor.h,
score/cpu/m68k/rtems/score/cpu.h: Remove stray spaces from unsigned32
to uint32_t conversion.
* libcsupport/include/rtems/libio_.h: Added
rtems_filesystem_is_root_location().
* libfs/src/imfs/imfs_directory.c, libfs/src/imfs/imfs_eval.c,
libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_eval.c: Use
PR 1775/filesystem
* libfs/src/nfsclient/src/nfs.c: NFSAddress NFS issue where read/write
problems when requested bytes greater than nfsStBlksize. Failure to
create files and symlinks.
PR 1827/filesystem
* libfs/src/rfs/rtems-rfs-rtems.c: Skip the parent (..) path value
when eval make moving up out of the RFS file system.
* include/rtems/bspIo.h, include/rtems/concat.h,
include/rtems/endian.h, include/rtems/fs.h, include/rtems/irq.h,
include/rtems/pci.h, include/rtems/userenv.h,
libblock/include/rtems/flashdisk.h,
libblock/include/rtems/nvdisk-sram.h,
libblock/include/rtems/nvdisk.h, libcsupport/include/clockdrv.h,
libcsupport/include/console.h, libcsupport/include/iosupp.h,
libcsupport/include/spurious.h,
libcsupport/include/motorola/mc68230.h,
libcsupport/include/rtems/assoc.h, libcsupport/include/rtems/error.h,
libcsupport/include/rtems/framebuffer.h,
libcsupport/include/rtems/gxx_wrappers.h,
libcsupport/include/rtems/libcsupport.h,
libcsupport/include/rtems/libio_.h,
libcsupport/include/rtems/malloc.h,
libcsupport/include/rtems/termiostypes.h,
libcsupport/include/sys/statvfs.h, libcsupport/include/sys/termios.h,
libcsupport/include/sys/utsname.h, libcsupport/include/zilog/z8036.h,
libcsupport/include/zilog/z8530.h, libcsupport/include/zilog/z8536.h,
libfs/src/imfs/imfs.h, libfs/src/pipe/pipe.h,
libmisc/capture/capture-cli.h, libmisc/capture/capture.h,
libmisc/cpuuse/cpuuse.h, libmisc/devnull/devnull.h,
libmisc/devnull/devzero.h, libmisc/dumpbuf/dumpbuf.h,
libmisc/fb/fb.h, libmisc/fb/mw_uid.h, libmisc/mouse/mouse_parser.h,
libmisc/shell/shellconfig.h, libmisc/stringto/stringto.h,
libmisc/untar/untar.h, libnetworking/memory.h, posix/include/aio.h,
posix/include/mqueue.h, posix/include/semaphore.h,
posix/include/rtems/posix/aio_misc.h,
posix/include/rtems/posix/barrier.h,
posix/include/rtems/posix/cond.h, posix/include/rtems/posix/config.h,
posix/include/rtems/posix/key.h, posix/include/rtems/posix/mqueue.h,
posix/include/rtems/posix/mutex.h,
posix/include/rtems/posix/posixapi.h,
posix/include/rtems/posix/ptimer.h,
posix/include/rtems/posix/rwlock.h,
posix/include/rtems/posix/sigset.h,
posix/include/rtems/posix/spinlock.h,
posix/inline/rtems/posix/barrier.inl,
posix/inline/rtems/posix/rwlock.inl,
posix/inline/rtems/posix/spinlock.inl,
posix/inline/rtems/posix/timer.inl, rtems/mainpage.h,
rtems/include/rtems/rtems/barrier.h,
rtems/include/rtems/rtems/object.h,
rtems/include/rtems/rtems/timer.h,
rtems/inline/rtems/rtems/barrier.inl,
rtems/inline/rtems/rtems/timer.inl,
rtems/src/semtranslatereturncode.c, sapi/include/rtems/config.h,
sapi/include/rtems/fatal.h, sapi/include/rtems/mptables.h,
score/inline/rtems/score/object.inl,
score/inline/rtems/score/priority.inl: Add @file Doxygen directives
and descriptions to files which originated with RTEMS. This improves
the file list page generated by Doxygen.
PR 1812/filesystem
* libfs/src/imfs/imfs_stat.c: stat() implementation for IMFS did not
set st_blksize field. Set it based upon user configuration.
* libfs/Makefile.am: Unconditionally descend into src/nfsclient.
Include subdirs.am.
PR 1774/filesystem
* libfs/src/imfs/imfs_eval.c: Updated to fix regressions found in
the testsuite.
PR 1774/filesystem
* libfs/src/imfs/imfs_eval.c: Fix the IMFS eval and eval for make
handlers to not inspect a mounted file sytems path.
* libfs/src/pipe/fifo.c: Fixed integer type.
PR 1701/filesystems
* libfs/src/imfs/memfile.c: Fix sense of assert.
* libfs/src/dosfs/msdos_format.c: Address Coverity issue 183 which was
where an expression evaluated to a constant and issue 185 which was a
potential (although unlikely in expected usage) time-of-check,
time-of-use race condition.
* libfs/src/rfs/rtems-rfs-rtems-file.c,
libfs/src/rfs/rtems-rfs-rtems.c, libfs/src/rfs/rtems-rfs-rtems.h:
The fix to the removal of file_info from iop was broken. The
node_access field must be the inode number in the RFS because the
file system ops provides no way to tell is a stat call is the
result of stat, fstat, or lstat. The solution is to move the file
handle to node_access_2 which is also shared with doff but these
do not overlap.
PR 1757/filesystem
* libfs/src/rfs/rtems-rfs-block-pos.h: Fix the bug in equal
compare.
PR 1763/shell
* libmisc/shell/hexdump-conv.c: Remove debug hacks.
PR 1757/filesystem
* libfs/src/rfs/rtems-rfs-block-pos.h,
libfs/src/rfs/rtems-rfs-block.h, libfs/src/rfs/rtems-rfs-file.c,
libfs/src/rfs/rtems-rfs-rtems-file.c: Set the file size in
iop-size when a file is open. Fix lseek to end of file then write
for sizes less than half the file system block size.
* libfs/src/rfs/rtems-rfs-rtems-dev.c,
libfs/src/rfs/rtems-rfs-rtems-dir.c,
Fix the fstat and fchmod calls due to the change in the iop struct
where pathinfo went away. The node_access field in pathinfo was
overloaded.
* libfs/src/imfs/deviceerrno.c: Add RTEMS_INVALID_CLOCK,
RTEMS_INVALID_NODE, and RTEMS_NOT_CONFIGURED.
* libcsupport/src/mknod.c, libfs/src/rfs/rtems-rfs-inode.c: PR
1749. Fix the incorrect handling of the file type in the mode
value to reject invalid types as per the standard.
* libfs/src/dosfs/msdos_misc.c: Don't include <strings.h>.
* libfs/src/rfs/rtems-rfs-rtems.c: Fix bug where the eval path did
not close an inode.
* libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_readlink.c: readlink
filesystem entry should return ssize_t.
* libfs/src/nfsclient/src/nfs.c: readlink filesystem entry should
return ssize_t.
* libfs/src/dosfs/msdos_conv.c: Fixed convertion of half seconds to
seconds.
* libfs/src/dosfs/msdos_misc.c: Create short file names acceptable for
Windows.
* libfs/src/dosfs/msdos.h, libfs/src/dosfs/msdos_misc.c,
libfs/src/dosfs/msdos_create.c: Create valid create and modfied date
and time.
* libfs/src/dosfs/fat_file.c, libfs/src/imfs/imfs_debug.c,
libfs/src/imfs/imfs_directory.c, libfs/src/imfs/imfs_getchild.c,
posix/src/killinfo.c, score/inline/rtems/score/schedulerpriority.inl,
score/inline/rtems/score/watchdog.inl, score/src/apiext.c,
score/src/chain.c, score/src/coremsgflushsupp.c,
score/src/coremsginsert.c, score/src/objectshrinkinformation.c,
score/src/schedulerpriorityyield.c,
score/src/threadqdequeuepriority.c,
score/src/threadqenqueuepriority.c,
score/src/threadqextractpriority.c, score/src/threadqfirstfifo.c,
score/src/threadqfirstpriority.c, score/src/threadyieldprocessor.c,
score/src/userextthreadbegin.c, score/src/userextthreadcreate.c,
score/src/userextthreaddelete.c, score/src/userextthreadrestart.c,
score/src/userextthreadstart.c, score/src/userextthreadswitch.c,
score/src/watchdogreportchain.c: Avoid chain API violations.
* libfs/src/rfs/rtems-rfs-rtems-file.c: Add missing unlock in
write. Return the error code in close.
* libfs/src/rfs/rtems-rfs-trace.c,
libfs/src/rfs/rtems-rfs-trace.h: Add inode-delete.
* libfs/src/rfs/rtems-rfs-shell.c: Fix formatting.
* libfs/src/rfs/rtems-rfs-rtems-dir.c: Use ssize_t. Fix spelling.
* libfs/src/rfs/rtems-rfs-block.c: Fix rtems_rfs_block_get_bpos to
return the position correctly. A bpos does not have any special
processing. Do no reset the buffer handle when shrinking
indirectly.
* libfs/src/rfs/rtems-rfs-inode.c: Add trace.
* libfs/src/rfs/rtems-rfs-format.c: Fix comments.
* libfs/src/rfs/rtems-rfs-group.c: Limit the inodes to the blocks
in a group so the accounting works.
* libfs/src/rfs/rtems-rfs-dir.c: PR 1705. Fix handling the offsets
when deleting an entry.
* libfs/src/rfs/rtems-rfs-buffer.h: Remove
rtems_rfs_buffer_handle_reset. It is not needed and dangerous.
* libfs/src/defaults/default_close.c: Return 0 instead of an error
status.
* libfs/src/pipe/pipe.c: Remove unreachable line flagged by Coverity as
dead code.
PR 1693/filesystem
* libfs/src/imfs/memfile.c: IMFS_memfile_get_block_pointer() was
checking incorrect pointer and thus had dead code.
PR 1692/filesystem
* libcsupport/include/rtems/libio.h, libfs/src/devfs/devfs_eval.c,
libfs/src/imfs/imfs_eval.c: Fix implementation and use of
rtems_libio_is_valid_perms().
* libfs/src/defaults/default_evalpath.c,
libfs/src/defaults/default_evaluate_link.c: Removed superfluous
assignment.
* libfs/src/defaults/default_evaluate_link.c: Remove assignment.
* libfs/src/rfs/rtems-rfs-file.c: Check then load the inode is not
present on the close.
* libfs/src/rfs/rtems-rfs-format.c: Initialise the buffer chain.
* libfs/src/imfs/imfs_fcntl.c: Removed file.
* libfs/Makefile.am: Reflect change from above.
* libfs/src/defaults/default_fcntl.c: Return 0 instead of -1 and errno.
* libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_fifo.c,
libfs/src/imfs/imfs_handlers_directory.c,
libfs/src/imfs/imfs_handlers_memfile.c, libfs/src/nfsclient/src/nfs.c,
libfs/src/rfs/rtems-rfs-rtems-file.c, libfs/src/rfs/rtems-rfs-rtems.c,
libfs/src/rfs/rtems-rfs-rtems.h: Use default file system handlers.
* libblock/src/flashdisk.c, libblock/src/nvdisk.c,
libcsupport/src/ioctl.c, libfs/src/dosfs/fat_file.c: Add va_end().
CID 99
CID 100
CID 101
CID 102
* libfs/src/dosfs/fat_file.c, libfs/src/dosfs/msdos.h,
libfs/src/dosfs/msdos_misc.c: Resolve invalid use of const identified
by Coverity scanner.
PR 1677/filesystem
* libfs/src/imfs/imfs_creat.c: Fix creating of a file. Lost in the
change from a switch statement.
* libfs/src/imfs/imfs_eval.c: Add the missing ';' for the debug
case.
PR 1660/filesystem
* libfs/src/pipe/fifo.c, libfs/src/pipe/pipe.h: Changed
int pipe_release to void pipe_release.
* libfs/src/imfs/imfs_fifo.c: Corresponding change to
IMFS_fifo_close since pipe_release does not return any error.
* libfs/src/imfs/imfs_initsupp.c: Changes to improve
IMFS_determine_bytes_per_block
* libfs/src/imfs/imfs.h: Fix typo.
