Dead code identified by Coverity (CID 1456674). The value of ret
at line 358 is always 0.
Dead code identified by Coverity (CID 1456678). The value of ret
at line 293 is always 0.
Use self-contained condition variables instead of Classic API barriers.
This simplifies the implementation and configuration.
Update #3840.
Update #3823.
Fix prototype.
Fix node size. Linfiles are dynamically turned into memfiles.
Update #3823.
Update #3818.
Update #3706.
This makes the @file documentation independent of the actual file name.
Update #3707.
Username: deuteriumoxide Email: jacobshin313@gmail.com
Update #3358.
Closes #3581.
Avoid the use of a constant register variable which is used in some
conditions. This gets rid of a clang -Wsometimes-uninitialized warning.
Update #3530.
Update #3533.
Add and use <machine/rtems-bsd-kernel-space.h> and
<machine/rtems-bsd-user-space.h> similar to the libbsd to avoid command
line defines and defines scattered throught the code base.
Simplify cpukit/libnetworking/Makefile.am.
Update #3375.
Update #3358.
The function rtems_rfs_buffer_sync() erroneously calls
rtems_disk_release(). This screws up the reference counting of the disk.
Close #3484.
This makes it easer to find files describing an upstream version, e.g.
via "find -name VERSION".
Update #3465.
Add README to document the corrspending Linux version and the update
procedure.
Close #3465.
->fail_addr and ->addr can be updated no matter the result of
parent->_erase(), we just need to remove the code doing the same thing
in mtd_erase_callback() to avoid adjusting those fields twice.
Note that this can be done because all MTD users have been converted to
not pass an erase_info->callback() and are thus only taking the
->addr_fail and ->addr fields into account after part_erase() has
returned.
While we're at it, get rid of the erase_info->mtd field which was only
needed to let mtd_erase_callback() get the partition device back.
Signed-off-by: Boris Brezillon <boris.brezillon@bootlin.com>
Reviewed-by: Richard Weinberger <richard@nod.at>
None of the mtd->_erase() implementations work in an asynchronous manner,
so let's simplify MTD users that call mtd_erase(). All they need to do
is check the value returned by mtd_erase() and assume that != 0 means
failure.
trivial fix to spelling mistake in JFFS2_ERROR message
Signed-off-by: Colin Ian King <colin.king@canonical.com>
[Brian: also fix 'an' -> 'a']
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
<linux/sched.h> into <linux/sched/signal.h>
Fix up affected files that include this signal functionality via sched.h.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: Mike Galbraith <efault@gmx.de>
Cc: Peter Zijlstra <peterz@infradead.org>
Cc: Thomas Gleixner <tglx@linutronix.de>
Cc: linux-kernel@vger.kernel.org
Signed-off-by: Ingo Molnar <mingo@kernel.org>
When CONFIG_JFFS2_FS_XATTR is off, jffs2_xattr_handlers is defined as
NULL. With sb->s_xattr == NULL, the generic_{get,set,remove}xattr
functions produce the same result as setting the {get,set,remove}xattr
inode operations to NULL, so there is no need for these macros.
Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com>
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
We always mixed in the parent pointer into the dentry name hash, but we
did it late at lookup time. It turns out that we can simplify that
lookup-time action by salting the hash with the parent pointer early
instead of late.
A few other users of our string hashes also wanted to mix in their own
pointers into the hash, and those are updated to use the same mechanism.
Hash users that don't have any particular initial salt can just use the
NULL pointer as a no-salt.
Cc: Vegard Nossum <vegard.nossum@oracle.com>
Cc: George Spelvin <linux@sciencehorizons.net>
Cc: Al Viro <viro@zeniv.linux.org.uk>
Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} macros were introduced *long* time
ago with promise that one day it will be possible to implement page
cache with bigger chunks than PAGE_SIZE.
This promise never materialized. And unlikely will.
We have many places where PAGE_CACHE_SIZE assumed to be equal to
PAGE_SIZE. And it's constant source of confusion on whether
PAGE_CACHE_* or PAGE_* constant should be used in a particular case,
especially on the border between fs and mm.
Global switching to PAGE_CACHE_SIZE != PAGE_SIZE would cause to much
breakage to be doable.
Let's stop pretending that pages in page cache are special. They are
not.
The changes are pretty straight-forward:
- <foo> << (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- <foo> >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} -> PAGE_{SIZE,SHIFT,MASK,ALIGN};
- page_cache_get() -> get_page();
- page_cache_release() -> put_page();
This patch contains automated changes generated with coccinelle using
script below. For some reason, coccinelle doesn't patch header files.
I've called spatch for them manually.
The only adjustment after coccinelle is revert of changes to
PAGE_CAHCE_ALIGN definition: we are going to drop it later.
There are few places in the code where coccinelle didn't reach. I'll
fix them manually in a separate patch. Comments and documentation also
will be addressed with the separate patch.
virtual patch
expression E;
- E << (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
expression E;
- E >> (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
- PAGE_CACHE_SHIFT
+ PAGE_SHIFT
- PAGE_CACHE_SIZE
+ PAGE_SIZE
- PAGE_CACHE_MASK
+ PAGE_MASK
expression E;
- PAGE_CACHE_ALIGN(E)
+ PAGE_ALIGN(E)
expression E;
- page_cache_get(E)
+ get_page(E)
expression E;
- page_cache_release(E)
+ put_page(E)
Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Acked-by: Michal Hocko <mhocko@suse.com>
We need to finish doing the CRC checks before we can allow writes to
happen, and we currently process the inodes in order. This means a call
to jffs2_get_ino_cache() for each possible inode# up to c->highest_ino.
There may be a lot of lookups which fail, if the inode# space is used
sparsely. And the inode# space is *often* used sparsely, if a file
system contains a lot of stuff that was put there in the original
image, followed by lots of creation and deletion of new files.
Instead of processing them numerically with a lookup each time, just
walk the hash buckets instead.
[fix locking typo reported by Dan Carpenter]
Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
When a directory is deleted, we don't take too much care about killing off
all the dirents that belong to it — on the basis that on remount, the scan
will conclude that the directory is dead anyway.
This doesn't work though, when the deleted directory contained a child
directory which was moved *out*. In the early stages of the fs build
we can then end up with an apparent hard link, with the child directory
appearing both in its true location, and as a child of the original
directory which are this stage of the mount process we don't *yet* know
is defunct.
To resolve this, take out the early special-casing of the "directories
shall not have hard links" rule in jffs2_build_inode_pass1(), and let the
normal nlink processing happen for directories as well as other inodes.
Then later in the build process we can set ic->pino_nlink to the parent
inode#, as is required for directories during normal operaton, instead
of the nlink. And complain only *then* about hard links which are still
in evidence even after killing off all the unreachable paths.
Reported-by: Liu Song <liu.song11@zte.com.cn>
Cc: stable@vger.kernel.org
With this fix, all code paths should now be obtaining the page lock before
f->sem.
Reported-by: Szabó Tamás <sztomi89@gmail.com>
Tested-by: Thomas Betker <thomas.betker@rohde-schwarz.com>
There are many locations that do
if (memory_was_allocated_by_vmalloc)
vfree(ptr);
else
kfree(ptr);
but kvfree() can handle both kmalloc()ed memory and vmalloc()ed memory
using is_vmalloc_addr(). Unless callers have special reasons, we can
replace this branch with kvfree(). Please check and reply if you found
problems.
Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Acked-by: Jan Kara <jack@suse.com>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Reviewed-by: Andreas Dilger <andreas.dilger@intel.com>
Acked-by: "Rafael J. Wysocki" <rjw@rjwysocki.net>
Acked-by: David Rientjes <rientjes@google.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Oleg Drokin <oleg.drokin@intel.com>
Cc: Boris Petkov <bp@suse.de>
Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
Need to free the memory allocated for 'fd' if failed to read all
of the remainder name.
Signed-off-by: Wei Fang <fangwei1@huawei.com>
Li Zefan reported an unbalanced locking issue, found by his
internal debugging feature on runtime. The particular case he was
looking at doesn't lead to a deadlock, as the structure that this lock
is embedded in is freed on error. But we should straighten out the error
handling.
Because several callers of jffs2_do_read_inode_internal() /
jffs2_do_read_inode() already handle the locking/unlocking and inode
clearing at their own level, let's just push any unlocks/clearing down
to the caller. This consistency is much easier to verify.
Reported-by: Li Zefan <lizefan@huawei.com>
Cc: David Woodhouse <dwmw2@infradead.org>
Cc: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
Cc: Andrew Morton <akpm@linux-foundation.org>
sm->offset maybe wrong but magic maybe right, the offset do not have CRC.
Badness at c00c7580 [verbose debug info unavailable]
NIP: c00c7580 LR: c00c718c CTR: 00000014
REGS: df07bb40 TRAP: 0700 Not tainted (2.6.34.13-WR4.3.0.0_standard)
MSR: 00029000 <EE,ME,CE> CR: 22084f84 XER: 00000000
TASK = df84d6e0[908] 'mount' THREAD: df07a000
GPR00: 00000001 df07bbf0 df84d6e0 00000000 00000001 00000000 df07bb58 00000041
GPR08: 00000041 c0638860 00000000 00000010 22084f88 100636c8 df814ff8 00000000
GPR16: df84d6e0 dfa558cc c05adb90 00000048 c0452d30 00000000 000240d0 000040d0
GPR24: 00000014 c05ae734 c05be2e0 00000000 00000001 00000000 00000000 c05ae730
NIP [c00c7580] __alloc_pages_nodemask+0x4d0/0x638
LR [c00c718c] __alloc_pages_nodemask+0xdc/0x638
Call Trace:
[df07bbf0] [c00c718c] __alloc_pages_nodemask+0xdc/0x638 (unreliable)
[df07bc90] [c00c7708] __get_free_pages+0x20/0x48
[df07bca0] [c00f4a40] __kmalloc+0x15c/0x1ec
[df07bcd0] [c01fc880] jffs2_scan_medium+0xa58/0x14d0
[df07bd70] [c01ff38c] jffs2_do_mount_fs+0x1f4/0x6b4
[df07bdb0] [c020144c] jffs2_do_fill_super+0xa8/0x260
[df07bdd0] [c020230c] jffs2_fill_super+0x104/0x184
[df07be00] [c0335814] get_sb_mtd_aux+0x9c/0xec
[df07be20] [c033596c] get_sb_mtd+0x84/0x1e8
[df07be60] [c0201ed0] jffs2_get_sb+0x1c/0x2c
[df07be70] [c0103898] vfs_kern_mount+0x78/0x1e8
[df07bea0] [c0103a58] do_kern_mount+0x40/0x100
[df07bec0] [c011fe90] do_mount+0x240/0x890
[df07bf10] [c0120570] sys_mount+0x90/0xd8
[df07bf40] [c00110d8] ret_from_syscall+0x0/0x4
=== Exception: c01 at 0xff61a34
LR = 0x100135f0
Instruction dump:
38800005 38600000 48010f41 4bfffe1c 4bfc2d15 4bfffe8c 72e90200 4082fc28
3d20c064 39298860 8809000d 68000001 <0f000000> 2f800000 419efc0c 38000001
mount: mounting /dev/mtdblock3 on /common failed: Input/output error
Signed-off-by: Chen Jie <chenjie6@huawei.com>
Cc: <stable@vger.kernel.org>
Remove the function pulledbits() that is not used anywhere.
This was partially found by using a static code analysis program called cppcheck.
Signed-off-by: Rickard Strandqvist <rickard_strandqvist@spectrumdigital.se>
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Cc: linux-mtd@lists.infradead.org
schedule_delayed_work() happening when the work is already pending is
a cheap no-op. Don't bother with ->wbuf_queued logics - it's both
broken (cancelling ->wbuf_dwork leaves it set, as spotted by Jeff Harris)
and pointless. It's cheaper to let schedule_delayed_work() handle that
case.
Reported-by: Jeff Harris <jefftharris@gmail.com>
Tested-by: Jeff Harris <jefftharris@gmail.com>
Now with 64bit bzImage and kexec tools, we support ramdisk that size is
bigger than 2g, as we could put it above 4G.
Found compressed initramfs image could not be decompressed properly. It
turns out that image length is int during decompress detection, and it
will become < 0 when length is more than 2G. Furthermore, during
decompressing len as int is used for inbuf count, that has problem too.
Change len to long, that should be ok as on 32 bit platform long is
32bits.
Tested with following compressed initramfs image as root with kexec.
gzip, bzip2, xz, lzma, lzop, lz4.
run time for populate_rootfs():
size name Nehalem-EX Westmere-EX Ivybridge-EX
9034400256 root_img : 26s 24s 30s
3561095057 root_img.lz4 : 28s 27s 27s
3459554629 root_img.lzo : 29s 29s 28s
3219399480 root_img.gz : 64s 62s 49s
2251594592 root_img.xz : 262s 260s 183s
2226366598 root_img.lzma: 386s 376s 277s
2901482513 root_img.bz2 : 635s 599s
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Cc: "H. Peter Anvin" <hpa@zytor.com>
Cc: Ingo Molnar <mingo@elte.hu>
Cc: Rashika Kheria <rashika.kheria@gmail.com>
Cc: Josh Triplett <josh@joshtriplett.org>
Cc: Kyungsik Lee <kyungsik.lee@lge.com>
Cc: P J P <ppandit@redhat.com>
Cc: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp>
Cc: "Daniel M. Weeks" <dan@danweeks.net>
Cc: Alexandre Courbot <acourbot@nvidia.com>
Cc: Jan Beulich <JBeulich@suse.com>
mounting JFFS2 partition sometimes crashes with this call trace:
[ 1322.240000] Kernel bug detected[#1]:
[ 1322.244000] Cpu 2
[ 1322.244000] $ 0 : 0000000000000000 0000000000000018 000000003ff00070 0000000000000001
[ 1322.252000] $ 4 : 0000000000000000 c0000000f3980150 0000000000000000 0000000000010000
[ 1322.260000] $ 8 : ffffffffc09cd5f8 0000000000000001 0000000000000088 c0000000ed300de8
[ 1322.268000] $12 : e5e19d9c5f613a45 ffffffffc046d464 0000000000000000 66227ba5ea67b74e
[ 1322.276000] $16 : c0000000f1769c00 c0000000ed1e0200 c0000000f3980150 0000000000000000
[ 1322.284000] $20 : c0000000f3a80000 00000000fffffffc c0000000ed2cfbd8 c0000000f39818f0
[ 1322.292000] $24 : 0000000000000004 0000000000000000
[ 1322.300000] $28 : c0000000ed2c0000 c0000000ed2cfab8 0000000000010000 ffffffffc039c0b0
[ 1322.308000] Hi : 000000000000023c
[ 1322.312000] Lo : 000000000003f802
[ 1322.316000] epc : ffffffffc039a9f8 check_tn_node+0x88/0x3b0
[ 1322.320000] Not tainted
[ 1322.324000] ra : ffffffffc039c0b0 jffs2_do_read_inode_internal+0x1250/0x1e48
[ 1322.332000] Status: 5400f8e3 KX SX UX KERNEL EXL IE
[ 1322.336000] Cause : 00800034
[ 1322.340000] PrId : 000c1004 (Netlogic XLP)
[ 1322.344000] Modules linked in:
[ 1322.348000] Process jffs2_gcd_mtd7 (pid: 264, threadinfo=c0000000ed2c0000, task=c0000000f0e68dd8, tls=0000000000000000)
[ 1322.356000] Stack : c0000000f1769e30 c0000000ed010780 c0000000ed010780 c0000000ed300000
c0000000f1769c00 c0000000f3980150 c0000000f3a80000 00000000fffffffc
c0000000ed2cfbd8 ffffffffc039c0b0 ffffffffc09c6340 0000000000001000
0000000000000dec ffffffffc016c9d8 c0000000f39805a0 c0000000f3980180
0000008600000000 0000000000000000 0000000000000000 0000000000000000
0001000000000dec c0000000f1769d98 c0000000ed2cfb18 0000000000010000
0000000000010000 0000000000000044 c0000000f3a80000 c0000000f1769c00
c0000000f3d207a8 c0000000f1769d98 c0000000f1769de0 ffffffffc076f9c0
0000000000000009 0000000000000000 0000000000000000 ffffffffc039cf90
0000000000000017 ffffffffc013fbdc 0000000000000001 000000010003e61c
[ 1322.424000] Call Trace:
[ 1322.428000] [<ffffffffc039a9f8>] check_tn_node+0x88/0x3b0
[ 1322.432000] [<ffffffffc039c0b0>] jffs2_do_read_inode_internal+0x1250/0x1e48
[ 1322.440000] [<ffffffffc039cf90>] jffs2_do_crccheck_inode+0x70/0xd0
[ 1322.448000] [<ffffffffc03a1b80>] jffs2_garbage_collect_pass+0x160/0x870
[ 1322.452000] [<ffffffffc03a392c>] jffs2_garbage_collect_thread+0xdc/0x1f0
[ 1322.460000] [<ffffffffc01541c8>] kthread+0xb8/0xc0
[ 1322.464000] [<ffffffffc0106d18>] kernel_thread_helper+0x10/0x18
[ 1322.472000]
[ 1322.472000]
Code: 67bd0050 94a4002c 2c830001 <00038036> de050218 2403fffc 0080a82d 00431824 24630044
[ 1322.480000] ---[ end trace b052bb90e97dfbf5 ]---
The variable csize in structure jffs2_tmp_dnode_info is of type uint16_t, but it
is used to hold the compressed data length(csize) which is declared as uint32_t.
So, when the value of csize exceeds 16bits, it gets truncated when assigned to
tn->csize. This is causing a kernel BUG.
Changing the definition of csize in jffs2_tmp_dnode_info to uint32_t fixes the issue.
Signed-off-by: Ajesh Kunhipurayil Vijayan <ajesh@broadcom.com>
Signed-off-by: Kamlakant Patel <kamlakant.patel@broadcom.com>
Creating a large file on a JFFS2 partition sometimes crashes with this call
trace:
[ 306.476000] CPU 13 Unable to handle kernel paging request at virtual address c0000000dfff8002, epc == ffffffffc03a80a8, ra == ffffffffc03a8044
[ 306.488000] Oops[#1]:
[ 306.488000] Cpu 13
[ 306.492000] $ 0 : 0000000000000000 0000000000000000 0000000000008008 0000000000008007
[ 306.500000] $ 4 : c0000000dfff8002 000000000000009f c0000000e0007cde c0000000ee95fa58
[ 306.508000] $ 8 : 0000000000000001 0000000000008008 0000000000010000 ffffffffffff8002
[ 306.516000] $12 : 0000000000007fa9 000000000000ff0e 000000000000ff0f 80e55930aebb92bb
[ 306.524000] $16 : c0000000e0000000 c0000000ee95fa5c c0000000efc80000 ffffffffc09edd70
[ 306.532000] $20 : ffffffffc2b60000 c0000000ee95fa58 0000000000000000 c0000000efc80000
[ 306.540000] $24 : 0000000000000000 0000000000000004
[ 306.548000] $28 : c0000000ee950000 c0000000ee95f738 0000000000000000 ffffffffc03a8044
[ 306.556000] Hi : 00000000000574a5
[ 306.560000] Lo : 6193b7a7e903d8c9
[ 306.564000] epc : ffffffffc03a80a8 jffs2_rtime_compress+0x98/0x198
[ 306.568000] Tainted: G W
[ 306.572000] ra : ffffffffc03a8044 jffs2_rtime_compress+0x34/0x198
[ 306.580000] Status: 5000f8e3 KX SX UX KERNEL EXL IE
[ 306.584000] Cause : 00800008
[ 306.588000] BadVA : c0000000dfff8002
[ 306.592000] PrId : 000c1100 (Netlogic XLP)
[ 306.596000] Modules linked in:
[ 306.596000] Process dd (pid: 170, threadinfo=c0000000ee950000, task=c0000000ee6e0858, tls=0000000000c47490)
[ 306.608000] Stack : 7c547f377ddc7ee4 7ffc7f967f5d7fae 7f617f507fc37ff4 7e7d7f817f487f5f
7d8e7fec7ee87eb3 7e977ff27eec7f9e 7d677ec67f917f67 7f3d7e457f017ed7
7fd37f517f867eb2 7fed7fd17ca57e1d 7e5f7fe87f257f77 7fd77f0d7ede7fdb
7fba7fef7e197f99 7fde7fe07ee37eb5 7f5c7f8c7fc67f65 7f457fb87f847e93
7f737f3e7d137cd9 7f8e7e9c7fc47d25 7dbb7fac7fb67e52 7ff17f627da97f64
7f6b7df77ffa7ec5 80057ef17f357fb3 7f767fa27dfc7fd5 7fe37e8e7fd07e53
7e227fcf7efb7fa1 7f547e787fa87fcc 7fcb7fc57f5a7ffb 7fc07f6c7ea97e80
7e2d7ed17e587ee0 7fb17f9d7feb7f31 7f607e797e887faa 7f757fdd7c607ff3
7e877e657ef37fbd 7ec17fd67fe67ff7 7ff67f797ff87dc4 7eef7f3a7c337fa6
7fe57fc97ed87f4b 7ebe7f097f0b8003 7fe97e2a7d997cba 7f587f987f3c7fa9
[ 306.676000] Call Trace:
[ 306.680000] [<ffffffffc03a80a8>] jffs2_rtime_compress+0x98/0x198
[ 306.684000] [<ffffffffc0394f10>] jffs2_selected_compress+0x110/0x230
[ 306.692000] [<ffffffffc039508c>] jffs2_compress+0x5c/0x388
[ 306.696000] [<ffffffffc039dc58>] jffs2_write_inode_range+0xd8/0x388
[ 306.704000] [<ffffffffc03971bc>] jffs2_write_end+0x16c/0x2d0
[ 306.708000] [<ffffffffc01d3d90>] generic_file_buffered_write+0xf8/0x2b8
[ 306.716000] [<ffffffffc01d4e7c>] __generic_file_aio_write+0x1ac/0x350
[ 306.720000] [<ffffffffc01d50a0>] generic_file_aio_write+0x80/0x168
[ 306.728000] [<ffffffffc021f7dc>] do_sync_write+0x94/0xf8
[ 306.732000] [<ffffffffc021ff6c>] vfs_write+0xa4/0x1a0
[ 306.736000] [<ffffffffc02202e8>] SyS_write+0x50/0x90
[ 306.744000] [<ffffffffc0116cc0>] handle_sys+0x180/0x1a0
[ 306.748000]
[ 306.748000]
Code: 020b202d 0205282d 90a50000 <90840000> 14a40038 00000000 0060602d 0000282d 016c5823
[ 306.760000] ---[ end trace 79dd088435be02d0 ]---
Segmentation fault
This crash is caused because the 'positions' is declared as an array of signed
short. The value of position is in the range 0..65535, and will be converted
to a negative number when the position is greater than 32767 and causes a
corruption and crash. Changing the definition to 'unsigned short' fixes this
issue
Signed-off-by: Jayachandran C <jchandra@broadcom.com>
We triggered soft-lockup under stress test on 2.6.34 kernel.
BUG: soft lockup - CPU#1 stuck for 60009ms! [lockf2.test:14488]
[<bf09a4d4>] (jffs2_do_reserve_space+0x420/0x440 [jffs2])
[<bf09a528>] (jffs2_reserve_space_gc+0x34/0x78 [jffs2])
[<bf0a1350>] (jffs2_garbage_collect_dnode.isra.3+0x264/0x478 [jffs2])
[<bf0a2078>] (jffs2_garbage_collect_pass+0x9c0/0xe4c [jffs2])
[<bf09a670>] (jffs2_reserve_space+0x104/0x2a8 [jffs2])
[<bf09dc48>] (jffs2_write_inode_range+0x5c/0x4d4 [jffs2])
[<bf097d8c>] (jffs2_write_end+0x198/0x2c0 [jffs2])
[<c00e00a4>] (generic_file_buffered_write+0x158/0x200)
[<c00e14f4>] (__generic_file_aio_write+0x3a4/0x414)
[<c00e15c0>] (generic_file_aio_write+0x5c/0xbc)
[<c012334c>] (do_sync_write+0x98/0xd4)
[<c0123a84>] (vfs_write+0xa8/0x150)
[<c0123d74>] (sys_write+0x3c/0xc0)]
Fix this by adding a cond_resched() in the while loop.
[akpm@linux-foundation.org: don't initialize `ret']
Signed-off-by: Li Zefan <lizefan@huawei.com>
@wait is a local variable, so if we don't remove it from the wait queue
list, later wake_up() may end up accessing invalid memory.
This was spotted by eyes.
Also don't bother to set up a .get_acl method for symlinks as we do not
support access control (ACLs or even mode bits) for symlinks in Linux.
Signed-off-by: Christoph Hellwig <hch@lst.de>
