path: root/cpukit/libfs (follow)
* cpukit: occured -> occurredSebastian Huber2021-07-169-41/+41
* Change filesystem utime_h handler to utimens_hRyan Long2021-05-2811-131/+197
| | | | | | | Also updated licenses. Closes #4400 Updates #3899
* cpukit/libfs: Remove nfsclientVijay Kumar Banerjee2021-04-0716-10797/+0
| | | | Update #3850
* cpukit: Move ftpfs from libnetworking to libfsVijay Kumar Banerjee2021-04-072-0/+2496
| | | | Update #3850
* dosfs: Use peek supportChristian Mauderer2021-03-263-5/+31
| | | | | | This speeds up reading fragmented files. Fix #3689
* dosfs: Fix Doxygen group placementSebastian Huber2020-12-0210-25/+27
| | | | Update #3706.
* libfs: Fix Doxygen group placementSebastian Huber2020-12-026-6/+6
| | | | Update #3706.
* nfsclient: Rework Doxygen groupsSebastian Huber2020-12-028-16/+19
| | | | Update #3706.
* libfs/rfs: Check search bit map end on last bitChris Johns2020-10-171-2/+15
| | | | | | | - Do not write past the last location of the search bit map whe nit is being created. Closes #4148
* dosfs: Fix memory leak on failed mounts.Christian Mauderer2020-08-041-0/+5
| | | | | | | | | | | | | | | | | | | | Currently if mount fails, a converter isn't destroyed. We have to take care of two cases: 1. The user doesn't provide a converter. In this case mounting a dosfs creates a default converter. This patch makes sure that the converter is destroyed again if mount failes for this case. 2. The user provides a converter. In this case it's not sure that the dosfs specific routines are reached because mount can fail before that. Therefore the user has to destroy the converter himself again. This patch adds a documentation for that and implements it in the media server. Closes #4042.
* rtems: Remove deprecated rtems_io_lookup_name()Sebastian Huber2020-07-141-21/+0
| | | | Close #3420.
* doxygen: Switch @brief and @ingroupSebastian Huber2020-04-2898-98/+196
| | | | This order change fixes the Latex documentation build via Doxygen.
* Canonicalize config.h includeSebastian Huber2020-04-16109-169/+169
* imfs: Replace devfs with an IMFS specializationSebastian Huber2020-03-0911-485/+163
| | | | | | | | | | | | | | | | Add a simplified path evaluation function IMFS_eval_path_devfs() for a device only IMFS configuration. The code size can be further reduced by the application if it disables the support for legacy IO drivers via: #define CONFIGURE_IMFS_DISABLE_MKNOD #define CONFIGURE_IMFS_DISABLE_MKNOD_DEVICE Obsolete CONFIGURE_MAXIMUM_DEVICES. Remove BSP_MAXIMUM_DEVICES. Update #3894. Update #3898.
* imfs: Simplify code generationSebastian Huber2020-03-091-11/+17
| | | | Update #3894.
* imfs: Remove unused handlersSebastian Huber2020-03-091-6/+1
| | | | Update #3894.
* imfs: Constify imfs_memfile_bytes_per_blockSebastian Huber2020-03-092-37/+0
| | | | | | | | The CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK value is validated by <rtems/confdefs/libio.h>. Changing this value during runtime could lead to memory corruption. Update #3894.
* imfs: Use _IMFS_get_time()Sebastian Huber2020-03-091-6/+5
| | | | Update #3894.
* imfs: Add IMFS_add_node()Sebastian Huber2020-03-043-5/+162
| | | | Update #3894.
* imfs: Simplify IMFS_create_node()Sebastian Huber2020-03-041-3/+4
| | | | Update #3894.
* imfs: Remove IMFS_NODE_FLAG_NAME_ALLOCATEDSebastian Huber2020-03-042-14/+39
| | | | | | | | Remove IMFS_NODE_FLAG_NAME_ALLOCATED and instead replace the node control in rename operations. This avoids a special case in the general node destruction which pulled in free(). Update #3894.
* cpukit/libfs: remove more dead code from pipe/fifo.cGedare Bloom2020-01-031-2/+0
| | | | | Dead code identified by Coverity (CID 1456674). The value of ret at line 358 is always 0.
* cpukit/libfs: remove dead code from pipe/fifo.cGedare Bloom2020-01-031-2/+0
| | | | | Dead code identified by Coverity (CID 1456678). The value of ret at line 293 is always 0.
* pipe: Use condition variablesSebastian Huber2019-12-111-49/+17
| | | | | | | Use self-contained condition variables instead of Classic API barriers. This simplifies the implementation and configuration. Update #3840.
* untar: Unify untar supportSebastian Huber2019-11-251-142/+55
| | | | Update #3823.
* imfs: Fix IMFS_make_linearfile()Sebastian Huber2019-11-211-2/+2
| | | | | | | | Fix prototype. Fix node size. Linfiles are dynamically turned into memfiles. Update #3823.
* imfs: Add IMFS_make_linfile()Sebastian Huber2019-11-194-20/+105
| | | | Update #3818.
* dosfs: Fix format with media block sizes > 512Sebastian Huber2019-10-011-47/+46
* doxygen: Added groups to IO libraryAndreas Dachsberger2019-04-023-3/+3
| | | | Update #3706.
* libfs/src/pipe/fifo.c: Fix warning.Joel Sherrill2019-03-251-2/+0
* fifo.c: Eliminate logically dead code (Coverity 1437635)Joel Sherrill2019-03-141-8/+5
* Remove explicit file names from @fileSebastian Huber2019-02-281-1/+1
| | | | | | This makes the @file documentation independent of the actual file name. Update #3707.
* fs: Add struct dirent::d_type supportSebastian Huber2019-02-055-4/+29
* Fix format warnings due to ino_t changesSebastian Huber2019-01-101-1/+2
* Spelling and grammar fixes in source code comments (GCI 2018)Marçal Comajoan Cara2018-12-042-2/+2
* 5 spelling errors for a Google Code-In task.Jacob Shin2018-12-021-1/+1
| | | | Username: deuteriumoxide Email: jacobshin313@gmail.com
* dosfs: Fix device identifierSebastian Huber2018-11-271-1/+1
| | | | Update #3358.
* pipe/fifo.c: Remove dead code (CID 1437649)Joel Sherrill2018-11-221-1/+0
| | | | Closes #3581.
* build: Merge libfs/Makefile.amSebastian Huber2018-10-102-176/+0
* jffs2: Avoid use of constant register variableSebastian Huber2018-10-051-0/+12
| | | | | Avoid the use of a constant register variable which is used in some conditions. This gets rid of a clang -Wsometimes-uninitialized warning.
* Remove superfluous pipe_create()Sebastian Huber2018-10-041-1/+4
* Use rtems_task_exit()Sebastian Huber2018-10-021-1/+1
| | | | | Update #3530. Update #3533.
* network: Use kernel/user space header filesSebastian Huber2018-09-101-1/+0
| | | | | | | | | | Add and use <machine/rtems-bsd-kernel-space.h> and <machine/rtems-bsd-user-space.h> similar to the libbsd to avoid command line defines and defines scattered throught the code base. Simplify cpukit/libnetworking/Makefile.am. Update #3375.
* nfsclient: Fix unused variable warningSebastian Huber2018-09-071-1/+0
* dosfs: Avoid deprecated routineSebastian Huber2018-08-074-2/+5
| | | | Update #3358.
* rfs: Remove erroneous call of rtems_disk_release()Sebastian Huber2018-08-071-1/+0
| | | | | | | The function rtems_rfs_buffer_sync() erroneously calls rtems_disk_release(). This screws up the reference counting of the disk. Close #3484.
* jffs2: Rename README to VERSIONSebastian Huber2018-07-191-0/+0
| | | | | | | This makes it easer to find files describing an upstream version, e.g. via "find -name VERSION". Update #3465.
* jffs2: Add READMESebastian Huber2018-07-161-0/+35
| | | | | | | Add README to document the corrspending Linux version and the update procedure. Close #3465.
* mtd: Unconditionally update ->fail_addr and ->addr in part_erase()Boris Brezillon2018-07-161-1/+0
| | | | | | | | | | | | | | | | | ->fail_addr and ->addr can be updated no matter the result of parent->_erase(), we just need to remove the code doing the same thing in mtd_erase_callback() to avoid adjusting those fields twice. Note that this can be done because all MTD users have been converted to not pass an erase_info->callback() and are thus only taking the ->addr_fail and ->addr fields into account after part_erase() has returned. While we're at it, get rid of the erase_info->mtd field which was only needed to let mtd_erase_callback() get the partition device back. Signed-off-by: Boris Brezillon <boris.brezillon@bootlin.com> Reviewed-by: Richard Weinberger <richard@nod.at>
* mtd: Stop assuming mtd_erase() is asynchronousBoris Brezillon2018-07-161-31/+5
| | | | | | | | | | None of the mtd->_erase() implementations work in an asynchronous manner, so let's simplify MTD users that call mtd_erase(). All they need to do is check the value returned by mtd_erase() and assume that != 0 means failure. Signed-off-by: Boris Brezillon <boris.brezillon@bootlin.com> Reviewed-by: Richard Weinberger <richard@nod.at>
