* | score: Add and use _Objects_Put() | Sebastian Huber | 2013-06-07 | 1 | -8/+10 |
| | | | | | | Add and use _Objects_Put_without_thread_dispatch(). These two functions pair with the _Objects_Get() function. This helps to introduce object specific SMP locks to avoid lock contention. | ||||
* | dosfs: Documentation | Sebastian Huber | 2013-06-07 | 1 | -0/+8 |
* | nfsclient: Add rpcSetXIDs() | Sebastian Huber | 2013-06-05 | 2 | -0/+30 |
* | nfsclient: Fix warnings | Sebastian Huber | 2013-06-05 | 2 | -8/+3 |
* | nfsclient: Delete superfluous mask operation | Sebastian Huber | 2013-06-05 | 1 | -1/+1 |
* | nfsclient: Delete superfluous assignment | Sebastian Huber | 2013-06-05 | 1 | -1/+0 |
* | dosfs: Documentation | Ralf Kirchner | 2013-06-03 | 1 | -6/+97 |
* | dosfs: UTF-8 Support: Multibyte conversions | Ralf Kirchner | 2013-06-03 | 4 | -10/+340 |
| | | | | | | | | | | | | Add optional conversion methods for multibyte strings. With these conversions which make use of iconv and utf8proc it becomes possible to use strings from any language (Czech, Chinese, Arabian, Hebrew, Corean, ...) for file names and directory names. NOTE: Iconv support must be activated during the build of the tool chain for these conversion methods (options --enable-newlib-iconv --enable-newlib-iconv-encodings=[ENCODINGS_YOU_WANT]). Alternatively you can provide your own conversion methods. | ||||
* | dosfs: UTF-8 Support: UI, backwards compatibility | Ralf Kirchner | 2013-06-03 | 11 | -560/+1781 |
| | | | | | | | | | User interface and backwards compatibility for UTF-8 support in the FAT file system. Purpose of UTF-8 support is to permit file names and directory names with characters from all kinds of languages (Czech, Chinese, Arabian, Hebrew, Korean, ...). This commit does not yet support multibyte characters. It only contains the user interface and the backwards compatibility. | ||||
* | dosfs: Add RTEMS_DOSFS_SEMAPHORES_PER_INSTANCE | Ralf Kirchner | 2013-05-24 | 1 | -0/+7 |
* | dosfs: Fix typo | Ralf Kirchner | 2013-05-24 | 1 | -1/+1 |
* | dosfs: Add statvfs() support | Andrei Mozzhuhin | 2013-05-16 | 4 | -2/+80 |
* | libfs: Always use geteuid() and getegid() | Sebastian Huber | 2013-03-22 | 2 | -12/+2 |
| | | | | The two functions are independent of the POSIX API. | ||||
* | IMFS: Fix NULL pointer access | Sebastian Huber | 2013-03-18 | 1 | -9/+10 |
* | dosfs: PR2091: Fix warning | Andreas Heinig | 2013-02-27 | 1 | -2/+2 |
* | IMFS: PR2093: Fix warning | Sebastian Huber | 2013-02-27 | 1 | -3/+2 |
* | dosfs: PR2092: Delete unused function | Andreas Heinig | 2013-02-27 | 1 | -32/+0 |
* | dosfs: Fix file length update | Sebastian Huber | 2013-02-20 | 1 | -2/+3 |
* | dosfs: Start scan with a valid data cluster | Sebastian Huber | 2013-02-15 | 1 | -26/+16 |
| | | | | | Simpify the loop. Set last cluster to an undefined value in case no free cluster exists. | ||||
* | dosfs: Fix file extend | Sebastian Huber | 2013-02-15 | 1 | -23/+24 |
| | | | | | | Only append a valid cluster chain (cluster added > 0), otherwise we overwrite the root directory cluster (cluster 0) of a FAT12 or FAT16 with arbitrary data. | ||||
* | dosfs: Ensure valid data cluster count | Sebastian Huber | 2013-02-15 | 1 | -1/+6 |
* | dosfs: Always release the buffers | Sebastian Huber | 2013-01-30 | 1 | -22/+23 |
| | | | | | Release the buffers also if this is not the last reference to the file object since otherwise we may hold modified data indefinitely. | ||||
* | cpukit: Fix many Doxygen warnings | Joel Sherrill | 2013-01-10 | 1 | -2/+1 |
* | devfs: Doxygen Warning Removal and Cleanup | Joel Sherrill | 2013-01-10 | 1 | -41/+56 |
* | cpukit: Use Consistent Beginning of Doxygen Group Notation | Joel Sherrill | 2013-01-10 | 1 | -1/+1 |
| | | | | | This is the result of a sed script which converts all uses of @{ into a consistent form. | ||||
* | cpukit: Add EOL on files missing EOL at EOF | Joel Sherrill | 2013-01-10 | 2 | -2/+2 |
* | rfs: Doxygen group cannot have a dash in it | Joel Sherrill | 2013-01-10 | 21 | -21/+21 |
| | | | | Change rtems-rfs to rtems_rfs | ||||
* | cpukit: Doxygen group fixes and many warnings addressed | Joel Sherrill | 2013-01-10 | 22 | -89/+94 |
| | | | | | | | The output of the modules.html is much improved. Most filesystem and POSIX API related groups are properly nested. Some formatting issues were addressed as were multiple inconsistencies. | ||||
* | IMFS: Documentation | Sebastian Huber | 2013-01-09 | 1 | -23/+36 |
* | nfsclient: Return an error status in nfsInit() | Sebastian Huber | 2013-01-09 | 2 | -50/+84 |
| | | | | | Avoid assert() and use proper cleanup if nfsInit() fails to allocate a resource. | ||||
* | libfs: Doxygen Clean Up Task #1 | Alex Ivanov | 2013-01-08 | 19 | -482/+666 |
| | | | | | | http://www.google-melange.com/gci/task/view/google/gci2012/8120204 Patch committed with fixes for whitespace issues. | ||||
* | libfs: Doxygen Clean Up Task #2 | Mathew Kallada | 2013-01-04 | 9 | -94/+195 |
| | | | | | | There were minor conflicts and the modifications that were in the repo were favored over the modifications in the submitted patch. | ||||
* | Header File Doxygen Enhancement Task #1 | Alex Ivanov | 2012-12-28 | 2 | -12/+17 |
* | Header File Doxygen Enhancement Task #2 | Mathew Kallada | 2012-12-28 | 2 | -14/+17 |
* | libfs: Doxygen Enhancement Task #4 | Ayush Awasthi | 2012-12-28 | 20 | -0/+140 |
* | libfs: Doxygen Enhancement Task #5 | Mathew Kallada | 2012-12-28 | 23 | -106/+240 |
* | libfs: Doxygen Enhancement Task #3 | Alex Ivanov | 2012-12-28 | 20 | -106/+146 |
* | IMFS: Documentation | Sebastian Huber | 2012-12-21 | 1 | -4/+146 |
* | IMFS: Fix resource leak in IMFS_allocate_node() | Sebastian Huber | 2012-12-21 | 1 | -1/+7 |
* | libfs: Doxygen Enhancement Task #1 | Alex Ivanov | 2012-12-20 | 21 | -172/+301 |
* | libfs: Doxygen Enhancement Task #6" | Mathew Kallada | 2012-12-20 | 24 | -64/+219 |
* | libfs: Doxygen Enhancement Task #2 | Alex Ivanov | 2012-12-18 | 22 | -151/+251 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/8032207 | ||||
* | dosfs: Avoid error caused by bdbuf configuration | Sebastian Huber | 2012-12-14 | 1 | -10/+5 |
| | | | | | | The success of a block size change depends on the bdbuf configuration. Do not treat a failed block size change as a hard error. This is only a missed performance optimization. | ||||
* | Fix spelling | Sebastian Huber | 2012-12-14 | 1 | -1/+1 |
* | dosfs: Add sync_device option for msdos_format() | Sebastian Huber | 2012-12-13 | 2 | -0/+10 |
* | dosfs: Fix error status handling | Sebastian Huber | 2012-12-13 | 1 | -16/+18 |
* | dosfs: Bugfix for disks of for example 100MB size | Ralf Kirchner | 2012-12-13 | 1 | -49/+101 |
* | dosfs: Whitespace change | Ralf Kirchner | 2012-12-13 | 1 | -1/+0 |
* | dosfs: Fix request evaluation | Ralf Kirchner | 2012-12-13 | 1 | -4/+0 |
| | | | | | Return the ability to set a cluster size other than one sector for unaligned volumes. | ||||
* | misc: Header File Doxygen Enhancement Task #3 | Mathew Kallada | 2012-12-12 | 15 | -106/+158 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/8006220 |
