* .cvsignore, src/.cvsignore, src/imfs/.cvsignore, wrapup/.cvsignore:
New files.
* libfs created.
* src, src/imfs, wrapup: New directories.
* ChangeLog, Makefile.am, README, configure.in, src/Makefile.am,
wrapup/Makefile.am: New files.
* src/imfs/deviceio.c, src/imfs/imfs_getchild.c,
src/imfs/imfs_readlink.c, src/imfs/imfs.h, src/imfs/imfs_gtkn.c,
src/imfs/imfs_rmnod.c, src/imfs/imfs_chown.c,
src/imfs/imfs_handlers_device.c, src/imfs/imfs_stat.c,
src/imfs/imfs_creat.c, src/imfs/imfs_handlers_directory.c,
src/imfs/imfs_symlink.c, src/imfs/imfs_debug.c,
src/imfs/imfs_handlers_link.c, src/imfs/imfs_unixstub.c,
src/imfs/imfs_directory.c, src/imfs/imfs_handlers_memfile.c,
src/imfs/imfs_unlink.c, src/imfs/imfs_eval.c, src/imfs/imfs_init.c,
src/imfs/imfs_unmount.c, src/imfs/imfs_fchmod.c,
src/imfs/imfs_initsupp.c, src/imfs/imfs_utime.c, src/imfs/imfs_fcntl.c,
src/imfs/imfs_link.c, src/imfs/memfile.c, src/imfs/imfs_fdatasync.c,
src/imfs/imfs_mknod.c, src/imfs/miniimfs_init.c, src/imfs/imfs_free.c,
src/imfs/imfs_mount.c, src/imfs/imfs_fsunmount.c, src/imfs/imfs_ntype.c:
New files. Moved from libc.
* libc/isatty.c, libc/imfs_handlers_directory.c, libc/creat.c,
libc/imfs_directory.c: Fixed style issues.
* libc/eval.c: Ditto.
* libc/fcntl.c: Ditto.
* libc/fsync.c: Ditto.
* libc/ioctl.c: Ditto.
* libc/ioman.c: Ditto.
* libc/link.c: Ditto.
* libc/memfile.c: Ditto.
* libc/mknod.c: Ditto.
* libc/symlink.c: Ditto.
read function in the IMFS properly returns the inode number.
stat()'ing a symbolic link. This is needed to support the port
of the BSD commands like ls to RTEMS.
Jennifer Averett <jennifer.averett@oarcorp.com> to fix
appends (O_APPEND at open time) on in-memory files.
A call such as:
fd = open (file, O_APPEND | O_WRONLY);
did not append to the end of the file.
Jennifer Averett <jennifer.averett@oarcorp.com> to make sure
"/" is created with S_IFDIR set.
Java folks including Oscar Martinez de la Torre <omt@wm.estec.esa.nl>.
and not handling every case properly.
should not have been. This required that IMFS_rmnod be split into
three separate (per file type) routines to avoid dependencies.
In the end, a miniIMFS application is 6K smaller than one using the
full IMFS.
was not set.
readdir support. The next step is to add a mount table and configure
either the miniIMFS or the full IMFS at the application level.
<raguet@crf.canon.fr> to use a local variable.
Renamed IMFS handler tables to include IMFS prefix.
places to make sure memory allocated for filesystem specifif nodes
gets freed.
routine imfs_fcntl.c
node used to manage file access.
indicates an internal error.
calculated.
rather then NAME_MAX. NAME_MAX is 255 and that lets IMFS chew up memory
too fast. Perhaps in the future, the places in IMFS that put a maximum
length name string on the stack and the jnode structure does not include
a maximu length name string can be fixed so this is not a problem.
to avoid dereferencing NULLs.
PROBLEMS
can/will be fixed.
