* Makefile.am: Add $(dirstamp) to compilation rules.
* Makefile.am: Add $(dirstamp) to preinstallation rules.
* Makefile.am: Merge-in src/Makefile.am, src/imfs/Makefile.am,
src/dosfs/Makefile.am.
* src/Makefile.am, src/imfs/Makefile.am, src/dosfs/Makefile.am:
Removed.
* src/dosfs/config.h: Remove.
* src/dosfs/Makefile.am: Remove config.h
AM_CPPFLAGS += -I$(top_builddir).
* src/imfs/config.h: Remove.
* src/imfs/Makefile.am: Remove config.h
PR 515/filesystem
* src/dosfs/fat_fat_operations.c: Remove commented out code.
PR 509/filesystem
* src/dosfs/fat.c: _fat_block_read and _fat_block_write return error
codes instead of -1 in case of errors, as they are supposed to do
according to the comments documenting these functions.
PR 440/filesystem
* src/dosfs/fat_fat_operations.c: Improve write speed with FAT12 and
FAT16 filesystems. Previously merged on 4.6 branch.
* ChangeLog: Correct line length.
* src/dosfs/Makefile.am: noinst_HEADERS += fat.h
* src/dosfs/msdos_file.c (msdos_file_read, msdos_file_write):
Use '0' as initial value for ret instead of RC_OK.
* src/dosfs/msdos_conv.c: Remove isupper, islower, toupper, tolower
(Unused).
PR 492/filesystem
* src/dosfs/fat_file.c: Fix inconsistent types in va_args call.
PR 487/filesystem
* src/dosfs/fat_file.c: Correct typing per gcc 3.3 warnings.
* src/dosfs/dosfs.h, src/dosfs/fat.h, src/dosfs/fat_fat_operations.h,
src/dosfs/fat_file.h, src/dosfs/msdos.h, src/dosfs/msdos_create.c,
src/dosfs/msdos_dir.c, src/dosfs/msdos_eval.c,
src/dosfs/msdos_file.c, src/dosfs/msdos_free.c,
src/dosfs/msdos_fsunmount.c, src/dosfs/msdos_handlers_dir.c,
src/dosfs/msdos_handlers_file.c, src/dosfs/msdos_init.c,
src/dosfs/msdos_initsupp.c, src/dosfs/msdos_misc.c,
src/dosfs/msdos_mknod.c, src/dosfs/msdos_node_type.c,
src/imfs/deviceio.c, src/imfs/imfs.h, src/imfs/imfs_chown.c,
src/imfs/imfs_config.c, src/imfs/imfs_creat.c, src/imfs/imfs_debug.c,
src/imfs/imfs_directory.c, src/imfs/imfs_eval.c,
src/imfs/imfs_fchmod.c, src/imfs/imfs_fcntl.c,
src/imfs/imfs_fdatasync.c, src/imfs/imfs_free.c,
src/imfs/imfs_fsunmount.c, src/imfs/imfs_getchild.c,
src/imfs/imfs_gtkn.c, src/imfs/imfs_handlers_device.c,
src/imfs/imfs_handlers_directory.c, src/imfs/imfs_handlers_link.c,
src/imfs/imfs_handlers_memfile.c, src/imfs/imfs_init.c,
src/imfs/imfs_initsupp.c, src/imfs/imfs_link.c,
src/imfs/imfs_mknod.c, src/imfs/imfs_mount.c, src/imfs/imfs_ntype.c,
src/imfs/imfs_readlink.c, src/imfs/imfs_rmnod.c,
src/imfs/imfs_stat.c, src/imfs/imfs_symlink.c,
src/imfs/imfs_unixstub.c, src/imfs/imfs_unlink.c,
src/imfs/imfs_unmount.c, src/imfs/imfs_utime.c, src/imfs/ioman.c,
src/imfs/linearfile.c, src/imfs/memfile.c, src/imfs/miniimfs_init.c:
URL for license changed.
* msdos_create.c: Remove unused variable warning.
PR 443/filesystem
* src/imfs/deviceio.c: deviceio.c mishandles return codes
PR 440/filesystem
* src/dosfs/fat_fat_operations.c: Improve write data speed for DOSFS FAT12/FAT16 systems
PR 439/filesystem
PR 439/filesystem
*src/dosfs/fat_file.c: flush temporary buffer when closing files
PR 439/filesystem
PR 441/filesystem
*src/dosfs/msdos.h: add rename support to DOSFS
*src/dosfs/msdos_create.c: add rename support to DOSFS
*src/dosfs/msdos_file.c: add rename support to DOSFS
*src/dosfs/msdos_init.c: add rename support to DOSFS
*src/dosfs/msdos_mknod.c: add rename support to DOSFS
PR 441/filesystem
PR 434/filesystem
* src/imfs/imfs_init.c: Modified to return error code
* src/imfs/miniimfs_init.c: Modified to return error code
* src/imfs/imfs_initsup.c: Modified to set error upon memory failure.
PR 434/filesystem
* ChangeLog: Correct format.
opertations will wait for ever.
will wait for ever.
* configure.ac: Remove (Merged-in into ../configure.ac)
* Makefile.am, src/Makefile.am, src/dosfs/Makefile.am,
src/imfs/Makefile.am: Reflect having merged configure.ac into
../configure.ac.
* src/dosfs/config.h: New.
* src/dosfs/Makefile.am: Add config.h.
* src/imfsfs/config.h: New.
* src/imfs/Makefile.am: Add config.h.
Remove COMMON_C_FILES, DOC_FILES (Unused).
* src/dosfs/fat.c: include config-header "config.h".
* src/dosfs/fat_fat_operations.c: Ditto.
* src/dosfs/fat_file.c: Ditto.
* src/dosfs/msdos_conv.c: Ditto.
PR 411/filesystem
* src/imfs/imfs_unlink.c: Fix bug where renaming a memfile and
then unlinking it causes a memory leak.
PR 367/filesystem
* src/dosfs/Makefile.am, src/dosfs/fat.c, src/dosfs/fat.h,
src/dosfs/fat_fat_operations.c, src/dosfs/fat_file.c,
src/dosfs/msdos.h, src/dosfs/msdos_dir.c: Some bugs were still
present in the DOSFS implementation:
- FAT12 did not work properly on Big-Endian machines
- Some synchronization and error handling problems were present
- Some legal codings for EOC were not recognized
PR 338/filesystem
* src/imfs/ioman.c: Fix reentrancy problem with
rtems_io_lookup_name() (API change).
* src/dosfs/msdos_initsupp.c: Specify inherited priority as 0 since this
is a FIFO queuing semaphore.
* src/imfs/Makefile.am: Eliminate C_O_FILES.
* src/dosfs/Makefile.am: Ditto.
* src/dosfs/fat.h, src/dosfs/msdos.h: Added casts to remove warnings
on 16 bit targets like the h8300.
* configure.ac: Cosmetical fixes.
* configure.ac: Fix package name.
* configure.ac: Add nostdinc to AM_INIT_AUTOMAKE.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* src/imfs/memfile.c: Fixed case where last close of unlinked file
did not remove the resources associated with that file. Reported
by Till Straumann <strauman@slac.stanford.edu> on the mailing list.
* src/dosfs/fat.c, src/imfs/deviceio.c, src/imfs/imfs.h,
src/imfs/imfs_directory.c, src/imfs/imfs_fchmod.c,
src/imfs/memfile.c: Eliminated warnings. A lot of this focus
was on changing read and write entry points to return ssize_t
as read(2) and write(2) now do.
* wrapup/Makefile.am: Remove.
* wrapup/.cvsignore: Remove.
* Makefile.am: Remove wrapup SUBDIR.
* configure.ac: Remove wrapup/Makefile.
