* src/dosfs/Makefile.am: Use AM_CPPFLAGS instead of INCLUDES and
AM_CFLAGS. Eliminate LIBNAME.
* src/imfs/Makefile.am: Use AM_CPPFLAGS instead of INCLUDES and
* wrapup/Makefile.am: Eliminate LIBNAME.
* configure.ac: RTEMS_TOP(../..).
* configure.ac: Use AC_CONFIG_AUX_DIR(../..).
Add AC_PROG_RANLIB.
* wrapup/Makefile.am: Don't preinstall libfs.a.
* src/dosfs/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* src/imfs/Makefile.am: Include $(top_srcdir)/../automake/*.am.
Use ../aclocal.
* wrapup/Makefile.am: Include $(top_srcdir)/../automake/*.am.
Move from c/src/libfs to c/src/exec/libfs
* configure.ac: Reflect move.
* Makefile.am: Ditto.
* src/Makefile.am: Ditto.
* src/dosfs/Makefile.am: Ditto.
* src/imfs/Makefile.am: Ditto.
* wrapup/Makefile.am: Ditto.
* src/imfs/imfs_getchild.c: include <string.h>.
* src/imfs/imfs_gtkn.c: Include <string.h>.
* src/imfs/ioman.c: Include <string.h>.
* src/imfs/linearfile.c: Include <string.h>.
* src/imfs/memfile.c: Include <string.h>.
* src/dosfs/Makefile.am: Per PR129 do not install as many files
to the $(includedir).
* src/dosfs/fat.h: Include <string.h>.
Remove DBG1 and DBG2 (unused).
* Per PR169.
* src/dosfs/config.h.in, src/dosfs/stamp-h2.in: Removed from CVS.
* src/dosfs/fat_file.c: Remove bsp.h.
fat_file_write(.. const char*buf ..).
* src/dosfs/fat_file.h: fat_file_write(.. const char*buf ..).
* src/dosfs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/imfs/Makefile.am: Remove AUTOMAKE_OPTIONS.
Addressing PR 140.
* src/dosfs/config.h.in: Removed.
* src/dosfs/stamp-h2.in: Removed.
* .cvsignore: Add config.h*, stamp-h*.
* configure.ac: Remove AC_SRC_DIR(.../dosfs.h).
Remove AM_CONFIG_HEADER(src/dosfs/config.h).
Remove AM_CONFIG_HEADER(src/imfs/config.h).
Add AM_CONFIG_HEADER(config.h).
* src/dosfs/Makefile.am: INCLUDES = -I../.. .
* src/imfs/Makefile.am: INCLUDES = -I../.. .
Reported and tracked as PR130.
* src/dosfs/Makefile.am: Reworked, Disable dosfs for UNIX.
* wrapup/Makefile.am: Disable dosfs for UNIX.
* src/imfs/.cvsignore: Added stamp-h1.in
* DOS filesystem including FAT12, FAT16, and FAT32 support submitted.
* src/dosfs, src/dosfs/Makefile.am, src/dosfs/stamp-h2.in,
src/dosfs/config.h.in, src/dosfs/dosfs.h, src/dosfs/fat.c,
src/dosfs/fat.h, src/dosfs/fat_fat_operations.c,
src/dosfs/fat_fat_operations.h, src/dosfs/fat_file.c,
src/dosfs/fat_file.h, src/dosfs/msdos.h, src/dosfs/msdos_create.c,
src/dosfs/msdos_dir.c, src/dosfs/msdos_eval.c, src/dosfs/msdos_file.c,
src/dosfs/msdos_free.c, src/dosfs/msdos_fsunmount.c,
src/dosfs/msdos_handlers_dir.c, src/dosfs/msdos_handlers_file.c,
src/dosfs/msdos_init.c, src/dosfs/msdos_initsupp.c,
src/dosfs/msdos_misc.c, src/dosfs/msdos_mknod.c,
src/dosfs/msdos_node_type.c, src/dosfs/.cvsignore: New files.
* configure.ac, src/Makefile.am, wrapup/Makefile.am: Modified to
reflect addition.
* src/imfs/imfs_load_tar.c: Add include <sys/types.h>.
Add include <sys/stat.h>. Add include <fcntl.h>.
* src/imfs/imfs_rmnod.c: Add include <stdlib.h>.
* src/imfs/imfs_eval.c: Include <rtems/seterr.h>.
Apply rtems_set_errno_and_return_minus_one.
* src/imfs/memfile.c: Include <rtems/seterr.h>.
* src/imfs/imfs_readlink.c: Include <rtems/seterr.h>.
* src/imfs/imfs_unlink.c: Include <rtems/seterr.h>.
* src/imfs/imfs_link.c: Include <rtems/seterr.h>.
* src/imfs/imfs_chown.c: Include <rtems/seterr.h>.
* src/imfs/ioman.c: Include <rtems/seterr.h>.
* src/imfs/imfs_mount.c: Include <rtems/seterr.h>.
* src/imfs/imfs_directory.c: Include <rtems/seterr.h>.
* src/imfs/imfs_stat.c: Include <rtems/seterr.h>.
* src/imfs/imfs_fchmod.c: Include <rtems/seterr.h>.
* src/imfs/imfs_symlink.c: Include <rtems/seterr.h>.
* src/imfs/imfs_mknod.c: Include <rtems/seterr.h>.
* src/imfs/linearfile.c: Include <rtems/seterr.h>.
* src/imfs/imfs_unmount.c: Include <rtems/seterr.h>.
* src/imfs/imfs.h: Apply rtems_set_errno_and_return_minus_one.
Comment out increment_and_check_linkcounts.
* wrapup/Makefile.am: Remove HAS_IMFS.
* src/imfs/Makefile.am: Cleanup.
Reported by Ibragimov Ilya <ibr@oktet.ru> and tracked as PR49.
* src/imfs/imfs_directory.c: Do not calculate the offset twice.
* src/imfs/imfs_load_tar.c: Minor modification so this will
compile with gcc-2.95.3 with the arguments "-m5200 -O4".
* imfs/imfs_load_tar.c: Changed the code around to remove an
internal compiler error on the Coldfire target.
* configure.in: Remove.
* src/imfs/imfs_getchild.c: Correct length of static string
as reported by Ibragimov Ilya <ibr@oktet.ru>.
* src/imfs/Makefile.am: Use 'PREINSTALL_FILES ='.
* src/imfs/Makefile.am: Revamp INCLUDES handling to make automake-1.5
happy.
* src/imfs/imfs_eval.c: The CD_UP problem in imfs_eval has been
touched. The order of the questions is the key.
* src/imfs/deviceio.c: Make sure errno gets set to reflect
the status from the driver.
* src/imfs/imfs_initsupp.c: Create the root node with the
desired permissions. Nodes should be created with the right
permissions because chmod() is not supported by the miniIMFS
so changing after creation is not possible.
* configure.in: Add [-ansi -fasm] to RTEMS_PROG_CC_FOR_TARGET.
* src/imfs/memfile.c (memfile_open): Did not set iop->size
and thus the value was incorrect. Before this field was cleared,
this resulted in the value from the last time that IOP was used
being still in place. Discovered by Andrew Bythell
<abythell@nortelnetworks.com>.
* src/imfs/imfs_debug.c (IMFS_print_jnode): Modified to print
only information that does not vary based on target or memory
configuration. The old prints are still there in case they
are needed in the future to debug. Printing target dependent
addresses makes the test output vary by target unnecessarily.
* src/imfs/memfile.c: Reapply fix from bug report from
Jose Sturniolo <jsturnio@nec.com.ar> where NULL pointer
was dereferenced when freeing a triply indirect file.
The fix was applied to the 4.5 release branch and not
the development branch.
* src/imfs/Makefile.am: Apply include_*HEADERS instead of H_FILES.
* configure.in: Add src/imfs/config.h
* src/imfs/Makefile.am: Add INCLUDES += -I. to pickup config.h
* src/imfs/.cvsignore: Add config.h and stamp-h
* src/imfs/*.c: Add config.h support.
* src/imfs/imfs.h, src/imfs/imfs_creat.c, src/imfs/imfs_debug.c,
src/imfs/imfs_eval.c, src/imfs/imfs_fchmod.c,
src/imfs/imfs_handlers_memfile.c, src/imfs/imfs_init.c,
src/imfs/imfs_initsupp.c, src/imfs/imfs_stat.c, src/imfs/memfile.c,
src/imfs/miniimfs_init.c: Final developmental update to "tarfs".
When rtems_tarfs_load() is called, it checks the permissions
on each file. If there is write permission, it just creates a
standard file using "creat()" and therefore, uses the IMFS MEMORY_FILE.
If there is no write permission, it creates a LINEAR_FILE node
with the appropriate properties. If the permission is ever changed
to writeable, IMFS_fchmod converts it to a regular memory file.
* src/imfs/linearfile.c, src/imfs/imfs_load_tar.c: New files.
* src/imfs/Makefile.am, src/imfs/imfs.h,
src/imfs/imfs_eval.c, src/imfs/imfs_handlers_memfile.c,
src/imfs/imfs_init.c, src/imfs/imfs_initsupp.c,
src/imfs/imfs_stat.c, src/imfs/miniimfs_init.c: Added "tarfs".
This is not really a tar filesystem. It is a way to load a tar
image into the IMFS but actually leave bulky file contents in the
original tar image. It essentially adds the linear file type and
associated support and a loader routine.
* src/imfs/memfile.c: Bug report from Sturniolo Jose
<jsturnio@nec.com.ar> where NULL pointer was dereferenced.
* src/imfs/imfs_eval.c: Always return imaginary node at mount points.
* src/imfs/Makefile.am, src/imfs/deviceio.c, src/imfs/imfs_chown.c,
src/imfs/imfs_config.c, src/imfs/imfs_creat.c, src/imfs/imfs_debug.c,
src/imfs/imfs_directory.c, src/imfs/imfs_eval.c, src/imfs/imfs_fchmod.c,
src/imfs/imfs_free.c, src/imfs/imfs_fsunmount.c, src/imfs/imfs_gtkn.c,
src/imfs/imfs_init.c, src/imfs/imfs_initsupp.c, src/imfs/imfs_link.c,
src/imfs/imfs_mknod.c, src/imfs/imfs_mount.c, src/imfs/imfs_readlink.c,
src/imfs/imfs_rmnod.c, src/imfs/imfs_stat.c, src/imfs/imfs_symlink.c,
src/imfs/imfs_unixstub.c, src/imfs/imfs_unlink.c,
src/imfs/imfs_unmount.c, src/imfs/imfs_utime.c, src/imfs/ioman.c,
src/imfs/memfile.c, src/imfs/miniimfs_init.c:
<rtems/XXX.h>. Now we do not have to reach up and over to
libc to pick them up.
* src/imfs/imfs_config.c: New file containing IMFS configuration
information split from libc/base_fs.c.
* src/imfs/ioman.c: New file. Moved from lib/libc. Missed previously.
* src/imfs/Makefile.am: Added imfs_config.c and ioman.c.
* Makefile.am, configure.in: Introduce GNU canonicalization to libfs/.
The approach is currently a bit of a hack as GNU canonicalization
does not support the per-BSP build some of the other directories
require. As more of the tree is converted, this will become less
of an issue.
* .cvsignore, src/.cvsignore, src/imfs/.cvsignore, wrapup/.cvsignore:
New files.
* libfs created.
* src, src/imfs, wrapup: New directories.
* ChangeLog, Makefile.am, README, configure.in, src/Makefile.am,
wrapup/Makefile.am: New files.
* src/imfs/deviceio.c, src/imfs/imfs_getchild.c,
src/imfs/imfs_readlink.c, src/imfs/imfs.h, src/imfs/imfs_gtkn.c,
src/imfs/imfs_rmnod.c, src/imfs/imfs_chown.c,
src/imfs/imfs_handlers_device.c, src/imfs/imfs_stat.c,
src/imfs/imfs_creat.c, src/imfs/imfs_handlers_directory.c,
src/imfs/imfs_symlink.c, src/imfs/imfs_debug.c,
src/imfs/imfs_handlers_link.c, src/imfs/imfs_unixstub.c,
src/imfs/imfs_directory.c, src/imfs/imfs_handlers_memfile.c,
src/imfs/imfs_unlink.c, src/imfs/imfs_eval.c, src/imfs/imfs_init.c,
src/imfs/imfs_unmount.c, src/imfs/imfs_fchmod.c,
src/imfs/imfs_initsupp.c, src/imfs/imfs_utime.c, src/imfs/imfs_fcntl.c,
src/imfs/imfs_link.c, src/imfs/memfile.c, src/imfs/imfs_fdatasync.c,
src/imfs/imfs_mknod.c, src/imfs/miniimfs_init.c, src/imfs/imfs_free.c,
src/imfs/imfs_mount.c, src/imfs/imfs_fsunmount.c, src/imfs/imfs_ntype.c:
New files. Moved from libc.
