When unmounting a JFFS2 filesystem, any outstanding write buffers must
be flushed to disk. In some circumstances, these write buffers are
instantiated by a garbage collection pass and as such no inode number is
associated with it. Due to the way that JFFS2 processes these garbage
collection passes, a write buffer without any associated inodes will not
be flushed unless it is forced with jffs2_flush_wbuf_pad().
On JFFS2 file systems on NOR flash or dataflash that does not have spare
area for metadata and thus does not invoke delayed writes, it is
possible to put the file system into a state where all blocks have been
written to and all files have been deleted from the filesystem. There is
a bug in the JFFS2 file system scan routine that detects this situation
as a corrupted file system since the scan routine relies on "used" space
to discriminate a valid file system when there are blocks that need to
be erased. The correct fix would require a partial rewrite of the scan
routine, so instead this patch tracks the space marked as obsolete along
with space at the end of each block that is otherwise too small to
contain a JFFS2 node so that it can me compared with the dirty space.
Corrupted data (or otherwise non-JFFS2 blocks) will still cause this
check to fail as corrupted data isn't recognized as obsoleted (deleted)
nodes.
The tmp_fat_fd variable is unconditionally opened in the branch where it
is used within the loop and so must be closed or else risk a resource
leak.
When encountering an error during filesystem creation, fat_fd must be
cleaned up appropriately once the file is opened. There was an
opportunity for a resource leak due to jumping to the incorrect error
handling label.
An error is already being reported. Checking the return value of this
function is not useful.
Revert JFFS2 to non-granular locking. This makes the superblock
available to the delayed work that it owns so that delayed work
processing can ensure that shared resources are being exclusively
accessed. This change only affects NAND systems. Moving forward with
granular locking will require a significant investment of time in
producing a test harness that doesn't require hardware such that this
can get a reasonable amount of test coverage.
Change the public image data type to a void pointer.
The repeated reinitialization of jffs2_inode_info must be done by the
members of the struct to avoid altering others.
This provides a non-noop implementation of spinlocks for JFFS2 in terms
of RTEMS mutexes. POSIX spinlocks are not appropriate for the types of
actions that occur during a held JFFS2 spinlock and can cause bad
dispatch level conditions.
This reworks the JFFS2 delayed work queue to avoid use of
on-chain/off-chain semantics since they vary in behavior under
RTEMS_DEBUG and are not guaranteed to be safe to use in SMP systems.
This adds all delayed work structs to the chain on FS init and does not
remove them until umount.
Updates #4956
This moves delayed work to a temporary chain to prevent a locking
inversion between the delayed work lock and the alloc_sem lock. Delayed
work is now processed after the delayed work lock is released. Locking
order is any JFFS2 locks before the delayed work lock.
brains GmbH.
This was added with the writebuffer work and should have been protected
by the error check.
This adds write buffer and bad block support required for JFFS2
operation on NAND devices. This also adds the minor modifications
necessary for RTEMS support in the Linux header stubs and in wbuf.c.
Memory and NOR backed applications should experience no difference in
operation since they do not expose the callbacks required for write
buffer support.
This pulls in wbuf.c from the upstream Linux repository at the state
specified in VERSION.
Mutexes must be locked before they can be unlocked. JFFS2 doesn't
currently see this as an issue because all mutex operations are no-ops.
The RTEMS and Linux JFFS2 compression support have a slightly different
interface. This fixes a bug introduced by:
commit 17c3d536ca8ee17d36ea251eade884e07ff1ee75
Author: Yang Yang <yang.yang29@zte.com.cn>
Date: Thu Jan 28 02:55:35 2021 -0800
jffs2: check the validity of dstlen in jffs2_zlib_compress()
KASAN reports a BUG when download file in jffs2 filesystem.It is
because when dstlen == 1, cpage_out will write array out of bounds.
Actually, data will not be compressed in jffs2_zlib_compress() if
data's length less than 4.
There is a regular need in the kernel to provide a way to declare
having a dynamically sized set of trailing elements in a structure.
Kernel code should always use “flexible array members”[1] for these
cases. The older style of one-element or zero-length arrays should
no longer be used[2].
This code was transformed with the help of Coccinelle:
(linux-5.19-rc2$ spatch --jobs $(getconf _NPROCESSORS_ONLN) --sp-file script.cocci --include-headers --dir . > output.patch)
identifier S, member, array;
type T1, T2;
struct S {
T1 member;
T2 array[
- 0
-fstrict-flex-arrays=3 is coming and we need to land these changes
to prevent issues like these in the short future:
../fs/minix/dir.c:337:3: warning: 'strcpy' will always overflow; destination buffer has size 0,
but the source string has length 2 (including NUL byte) [-Wfortify-source]
strcpy(de3->name, ".");
Since these are all [0] to [] changes, the risk to UAPI is nearly zero. If
this breaks anything, we can use a union with a new member name.
[1] https://en.wikipedia.org/wiki/Flexible_array_member
[2] https://www.kernel.org/doc/html/v5.16/process/deprecated.html#zero-length-and-one-element-arrays
Link: https://github.com/KSPP/linux/issues/78
Build-tested-by: kernel test robot <lkp@intel.com>
Link: https://lore.kernel.org/lkml/62b675ec.wKX6AOZ6cbE71vtF%25lkp@intel.com/
Acked-by: Dan Williams <dan.j.williams@intel.com> # For ndctl.h
Signed-off-by: Gustavo A. R. Silva <gustavoars@kernel.org>
Use kzalloc rather than duplicating its implementation, which
makes code simple and easy to understand.
Signed-off-by: Haowen Bai <baihaowen@meizu.com>
[rw: Fixed printk string]
Signed-off-by: Richard Weinberger <richard@nod.at>
By making filler_t the same as read_folio, we can use the same function
for both in gfs2. We can push the use of folios down one more level
in jffs2 and nfs. We also increase type safety for future users of the
various read_cache_page() family of functions by forcing the parameter
to be a pointer to struct file (or NULL).
Signed-off-by: Matthew Wilcox (Oracle) <willy@infradead.org>
Reviewed-by: Christoph Hellwig <hch@lst.de>
Reviewed-by: Andreas Gruenbacher <agruenba@redhat.com>
In preparation for unifying the read_cache_page() and read_folio()
implementations, make jffs2_do_readpage_unlock() get the inode
from the page instead of passing it in from read_cache_page().
If an error is returned in jffs2_scan_eraseblock() and some memory
has been added to the jffs2_summary *s, we can observe the following
kmemleak report:
unreferenced object 0xffff88812b889c40 (size 64):
comm "mount", pid 692, jiffies 4294838325 (age 34.288s)
hex dump (first 32 bytes):
40 48 b5 14 81 88 ff ff 01 e0 31 00 00 00 50 00 @H........1...P.
00 00 01 00 00 00 01 00 00 00 02 00 00 00 09 08 ................
backtrace:
[<ffffffffae93a3a3>] __kmalloc+0x613/0x910
[<ffffffffaf423b9c>] jffs2_sum_add_dirent_mem+0x5c/0xa0
[<ffffffffb0f3afa8>] jffs2_scan_medium.cold+0x36e5/0x4794
[<ffffffffb0f3dbe1>] jffs2_do_mount_fs.cold+0xa7/0x2267
[<ffffffffaf40acf3>] jffs2_do_fill_super+0x383/0xc30
[<ffffffffaf40c00a>] jffs2_fill_super+0x2ea/0x4c0
[<ffffffffb0315d64>] mtd_get_sb+0x254/0x400
[<ffffffffb0315f5f>] mtd_get_sb_by_nr+0x4f/0xd0
[<ffffffffb0316478>] get_tree_mtd+0x498/0x840
[<ffffffffaf40bd15>] jffs2_get_tree+0x25/0x30
[<ffffffffae9f358d>] vfs_get_tree+0x8d/0x2e0
[<ffffffffaea7a98f>] path_mount+0x50f/0x1e50
[<ffffffffaea7c3d7>] do_mount+0x107/0x130
[<ffffffffaea7c5c5>] __se_sys_mount+0x1c5/0x2f0
[<ffffffffaea7c917>] __x64_sys_mount+0xc7/0x160
[<ffffffffb10142f5>] do_syscall_64+0x45/0x70
unreferenced object 0xffff888114b54840 (size 32):
c0 75 b5 14 81 88 ff ff 02 e0 02 00 00 00 02 00 .u..............
00 00 84 00 00 00 44 00 00 00 6b 6b 6b 6b 6b a5 ......D...kkkkk.
backtrace:
[<ffffffffae93be24>] kmem_cache_alloc_trace+0x584/0x880
[<ffffffffaf423b04>] jffs2_sum_add_inode_mem+0x54/0x90
[<ffffffffb0f3bd44>] jffs2_scan_medium.cold+0x4481/0x4794
unreferenced object 0xffff888114b57280 (size 32):
comm "mount", pid 692, jiffies 4294838393 (age 34.357s)
10 d5 6c 11 81 88 ff ff 08 e0 05 00 00 00 01 00 ..l.............
00 00 38 02 00 00 28 00 00 00 6b 6b 6b 6b 6b a5 ..8...(...kkkkk.
backtrace:
[<ffffffffaf423c34>] jffs2_sum_add_xattr_mem+0x54/0x90
[<ffffffffb0f3a24f>] jffs2_scan_medium.cold+0x298c/0x4794
unreferenced object 0xffff8881116cd510 (size 16):
comm "mount", pid 692, jiffies 4294838395 (age 34.355s)
hex dump (first 16 bytes):
00 00 00 00 00 00 00 00 09 e0 60 02 00 00 6b a5 ..........`...k.
backtrace:
[<ffffffffaf423cc4>] jffs2_sum_add_xref_mem+0x54/0x90
[<ffffffffb0f3b2e3>] jffs2_scan_medium.cold+0x3a20/0x4794
Therefore, we should call jffs2_sum_reset_collected(s) on exit to
release the memory added in s. In addition, a new tag "out_buf" is
added to prevent the NULL pointer reference caused by s being NULL.
(thanks to Zhang Yi for this analysis)
Fixes: e631ddba5887 ("[JFFS2] Add erase block summary support (mount time improvement)")
Cc: stable@vger.kernel.org
Co-developed-with: Zhihao Cheng <chengzhihao1@huawei.com>
Signed-off-by: Baokun Li <libaokun1@huawei.com>
If jffs2_build_filesystem() in jffs2_do_mount_fs() returns an error,
we can observe the following kmemleak report:
unreferenced object 0xffff88811b25a640 (size 64):
comm "mount", pid 691, jiffies 4294957728 (age 71.952s)
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
backtrace:
[<ffffffffa493be24>] kmem_cache_alloc_trace+0x584/0x880
[<ffffffffa5423a06>] jffs2_sum_init+0x86/0x130
[<ffffffffa5400e58>] jffs2_do_mount_fs+0x798/0xac0
[<ffffffffa540acf3>] jffs2_do_fill_super+0x383/0xc30
[<ffffffffa540c00a>] jffs2_fill_super+0x2ea/0x4c0
unreferenced object 0xffff88812c760000 (size 65536):
bb bb bb bb bb bb bb bb bb bb bb bb bb bb bb bb ................
backtrace:
[<ffffffffa493a449>] __kmalloc+0x6b9/0x910
[<ffffffffa5423a57>] jffs2_sum_init+0xd7/0x130
This is because the resources allocated in jffs2_sum_init() are not
released. Call jffs2_sum_exit() to release these resources to solve
the problem.
inode->i_mutex has been replaced with inode->i_rwsem long ago. Fix
comments still mentioning i_mutex.
Signed-off-by: hongnanli <hongnan.li@linux.alibaba.com>
Add a rcu argument to the ->get_acl() callback to allow
get_cached_acl_rcu() to call the ->get_acl() method in the next patch.
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
Building with W=1 shows a few warnings for empty macros:
fs/jffs2/scan.c: In function 'jffs2_scan_xattr_node':
fs/jffs2/scan.c:378:66: error: suggest braces around empty body in an 'if' statement [-Werror=empty-body]
378 | jffs2_sum_add_xattr_mem(s, rx, ofs - jeb->offset);
fs/jffs2/scan.c: In function 'jffs2_scan_xref_node':
fs/jffs2/scan.c:434:65: error: suggest braces around empty body in an 'if' statement [-Werror=empty-body]
434 | jffs2_sum_add_xref_mem(s, rr, ofs - jeb->offset);
fs/jffs2/scan.c: In function 'jffs2_scan_eraseblock':
fs/jffs2/scan.c:893:88: error: suggest braces around empty body in an 'if' statement [-Werror=empty-body]
893 | jffs2_sum_add_padding_mem(s, je32_to_cpu(node->totlen));
Change all these macros to 'do { } while (0)' statements to avoid the
warnings and make the code a little more robust.
Signed-off-by: Arnd Bergmann <arnd@arndb.de>
KASAN report a slab-out-of-bounds problem. The logs are listed below.
It is because in function jffs2_scan_dirent_node, we alloc "checkedlen+1"
bytes for fd->name and we check crc with length rd->nsize. If checkedlen
is less than rd->nsize, it will cause the slab-out-of-bounds problem.
jffs2: Dirent at *** has zeroes in name. Truncating to %d char
BUG: KASAN: slab-out-of-bounds in crc32_le+0x1ce/0x260 at addr ffff8800842cf2d1
Read of size 1 by task test_JFFS2/915
BUG kmalloc-64 (Tainted: G B O ): kasan: bad access detected
INFO: Allocated in jffs2_alloc_full_dirent+0x2a/0x40 age=0 cpu=1 pid=915
___slab_alloc+0x580/0x5f0
__slab_alloc.isra.24+0x4e/0x64
__kmalloc+0x170/0x300
jffs2_scan_eraseblock+0x1ca4/0x3b64
jffs2_scan_medium+0x285/0xfe0
jffs2_do_mount_fs+0x5fb/0x1bbc
jffs2_do_fill_super+0x245/0x6f0
jffs2_fill_super+0x287/0x2e0
mount_mtd_aux.isra.0+0x9a/0x144
mount_mtd+0x222/0x2f0
jffs2_mount+0x41/0x60
mount_fs+0x63/0x230
vfs_kern_mount.part.6+0x6c/0x1f4
do_mount+0xae8/0x1940
SyS_mount+0x105/0x1d0
INFO: Freed in jffs2_free_full_dirent+0x22/0x40 age=27 cpu=1 pid=915
__slab_free+0x372/0x4e4
kfree+0x1d4/0x20c
jffs2_build_remove_unlinked_inode+0x17a/0x1e4
jffs2_do_mount_fs+0x1646/0x1bbc
mount_fs+0x63/0x230
entry_SYSCALL_64_fastpath+0x1e/0x97
Call Trace:
[<ffffffff815befef>] dump_stack+0x59/0x7e
[<ffffffff812d1d65>] print_trailer+0x125/0x1b0
[<ffffffff812d82c8>] object_err+0x34/0x40
[<ffffffff812dadef>] kasan_report.part.1+0x21f/0x534
[<ffffffff81132401>] ? vprintk+0x2d/0x40
[<ffffffff815f1ee2>] ? crc32_le+0x1ce/0x260
[<ffffffff812db41a>] kasan_report+0x26/0x30
[<ffffffff812d9fc1>] __asan_load1+0x3d/0x50
[<ffffffff815f1ee2>] crc32_le+0x1ce/0x260
[<ffffffff814764ae>] ? jffs2_alloc_full_dirent+0x2a/0x40
[<ffffffff81485cec>] jffs2_scan_eraseblock+0x1d0c/0x3b64
[<ffffffff81488813>] ? jffs2_scan_medium+0xccf/0xfe0
[<ffffffff81483fe0>] ? jffs2_scan_make_ino_cache+0x14c/0x14c
[<ffffffff812da3e9>] ? kasan_unpoison_shadow+0x35/0x50
[<ffffffff812da462>] ? kasan_kmalloc+0x5e/0x70
[<ffffffff812d5d90>] ? kmem_cache_alloc_trace+0x10c/0x2cc
[<ffffffff818169fb>] ? mtd_point+0xf7/0x130
[<ffffffff81487dc9>] jffs2_scan_medium+0x285/0xfe0
[<ffffffff81487b44>] ? jffs2_scan_eraseblock+0x3b64/0x3b64
[<ffffffff812d57df>] ? __kmalloc+0x12b/0x300
[<ffffffff814a2753>] ? jffs2_sum_init+0x9f/0x240
[<ffffffff8148b2ff>] jffs2_do_mount_fs+0x5fb/0x1bbc
[<ffffffff8148ad04>] ? jffs2_del_noinode_dirent+0x640/0x640
[<ffffffff81127c5b>] ? __init_rwsem+0x97/0xac
[<ffffffff81492349>] jffs2_do_fill_super+0x245/0x6f0
[<ffffffff81493c5b>] jffs2_fill_super+0x287/0x2e0
[<ffffffff814939d4>] ? jffs2_parse_options+0x594/0x594
[<ffffffff81819bea>] mount_mtd_aux.isra.0+0x9a/0x144
[<ffffffff81819eb6>] mount_mtd+0x222/0x2f0
[<ffffffff81819c94>] ? mount_mtd_aux.isra.0+0x144/0x144
[<ffffffff81258757>] ? free_pages+0x13/0x1c
[<ffffffff814fa0ac>] ? selinux_sb_copy_data+0x278/0x2e0
[<ffffffff81492b35>] jffs2_mount+0x41/0x60
[<ffffffff81302fb7>] mount_fs+0x63/0x230
[<ffffffff8133755f>] ? alloc_vfsmnt+0x32f/0x3b0
[<ffffffff81337f2c>] vfs_kern_mount.part.6+0x6c/0x1f4
[<ffffffff8133ceec>] do_mount+0xae8/0x1940
[<ffffffff811b94e0>] ? audit_filter_rules.constprop.6+0x1d10/0x1d10
[<ffffffff8133c404>] ? copy_mount_string+0x40/0x40
[<ffffffff812cbf78>] ? alloc_pages_current+0xa4/0x1bc
[<ffffffff81253a89>] ? __get_free_pages+0x25/0x50
[<ffffffff81338993>] ? copy_mount_options.part.17+0x183/0x264
[<ffffffff8133e3a9>] SyS_mount+0x105/0x1d0
[<ffffffff8133e2a4>] ? copy_mnt_ns+0x560/0x560
[<ffffffff810e8391>] ? msa_space_switch_handler+0x13d/0x190
[<ffffffff81be184a>] entry_SYSCALL_64_fastpath+0x1e/0x97
[<ffffffff810e9274>] ? msa_space_switch+0xb0/0xe0
Memory state around the buggy address:
ffff8800842cf180: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
ffff8800842cf200: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
>ffff8800842cf280: fc fc fc fc fc fc 00 00 00 00 01 fc fc fc fc fc
ffff8800842cf300: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
ffff8800842cf380: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
Reported-by: Kunkun Xu <xukunkun1@huawei.com>
Signed-off-by: lizhe <lizhe67@huawei.com>
[ 393.799778] BUG: KASAN: slab-out-of-bounds in jffs2_rtime_compress+0x214/0x2f0 at addr ffff800062e3b281
[ 393.809166] Write of size 1 by task tftp/2918
[ 393.813526] CPU: 3 PID: 2918 Comm: tftp Tainted: G B 4.9.115-rt93-EMBSYS-CGEL-6.1.R6-dirty #1
[ 393.823173] Hardware name: LS1043A RDB Board (DT)
[ 393.827870] Call trace:
[ 393.830322] [<ffff20000808c700>] dump_backtrace+0x0/0x2f0
[ 393.835721] [<ffff20000808ca04>] show_stack+0x14/0x20
[ 393.840774] [<ffff2000086ef700>] dump_stack+0x90/0xb0
[ 393.845829] [<ffff20000827b19c>] kasan_object_err+0x24/0x80
[ 393.851402] [<ffff20000827b404>] kasan_report_error+0x1b4/0x4d8
[ 393.857323] [<ffff20000827bae8>] kasan_report+0x38/0x40
[ 393.862548] [<ffff200008279d44>] __asan_store1+0x4c/0x58
[ 393.867859] [<ffff2000084ce2ec>] jffs2_rtime_compress+0x214/0x2f0
[ 393.873955] [<ffff2000084bb3b0>] jffs2_selected_compress+0x178/0x2a0
[ 393.880308] [<ffff2000084bb530>] jffs2_compress+0x58/0x478
[ 393.885796] [<ffff2000084c5b34>] jffs2_write_inode_range+0x13c/0x450
[ 393.892150] [<ffff2000084be0b8>] jffs2_write_end+0x2a8/0x4a0
[ 393.897811] [<ffff2000081f3008>] generic_perform_write+0x1c0/0x280
[ 393.903990] [<ffff2000081f5074>] __generic_file_write_iter+0x1c4/0x228
[ 393.910517] [<ffff2000081f5210>] generic_file_write_iter+0x138/0x288
[ 393.916870] [<ffff20000829ec1c>] __vfs_write+0x1b4/0x238
[ 393.922181] [<ffff20000829ff00>] vfs_write+0xd0/0x238
[ 393.927232] [<ffff2000082a1ba8>] SyS_write+0xa0/0x110
[ 393.932283] [<ffff20000808429c>] __sys_trace_return+0x0/0x4
[ 393.937851] Object at ffff800062e3b280, in cache kmalloc-64 size: 64
[ 393.944197] Allocated:
[ 393.946552] PID = 2918
[ 393.948913] save_stack_trace_tsk+0x0/0x220
[ 393.953096] save_stack_trace+0x18/0x20
[ 393.956932] kasan_kmalloc+0xd8/0x188
[ 393.960594] __kmalloc+0x144/0x238
[ 393.963994] jffs2_selected_compress+0x48/0x2a0
[ 393.968524] jffs2_compress+0x58/0x478
[ 393.972273] jffs2_write_inode_range+0x13c/0x450
[ 393.976889] jffs2_write_end+0x2a8/0x4a0
[ 393.980810] generic_perform_write+0x1c0/0x280
[ 393.985251] __generic_file_write_iter+0x1c4/0x228
[ 393.990040] generic_file_write_iter+0x138/0x288
[ 393.994655] __vfs_write+0x1b4/0x238
[ 393.998228] vfs_write+0xd0/0x238
[ 394.001543] SyS_write+0xa0/0x110
[ 394.004856] __sys_trace_return+0x0/0x4
[ 394.008684] Freed:
[ 394.010691] PID = 2918
[ 394.013051] save_stack_trace_tsk+0x0/0x220
[ 394.017233] save_stack_trace+0x18/0x20
[ 394.021069] kasan_slab_free+0x88/0x188
[ 394.024902] kfree+0x6c/0x1d8
[ 394.027868] jffs2_sum_write_sumnode+0x2c4/0x880
[ 394.032486] jffs2_do_reserve_space+0x198/0x598
[ 394.037016] jffs2_reserve_space+0x3f8/0x4d8
[ 394.041286] jffs2_write_inode_range+0xf0/0x450
[ 394.045816] jffs2_write_end+0x2a8/0x4a0
[ 394.049737] generic_perform_write+0x1c0/0x280
[ 394.054179] __generic_file_write_iter+0x1c4/0x228
[ 394.058968] generic_file_write_iter+0x138/0x288
[ 394.063583] __vfs_write+0x1b4/0x238
[ 394.067157] vfs_write+0xd0/0x238
[ 394.070470] SyS_write+0xa0/0x110
[ 394.073783] __sys_trace_return+0x0/0x4
[ 394.077612] Memory state around the buggy address:
[ 394.082404] ffff800062e3b180: 00 00 00 00 00 00 00 00 fc fc fc fc fc fc fc fc
[ 394.089623] ffff800062e3b200: 00 00 00 00 00 00 00 00 fc fc fc fc fc fc fc fc
[ 394.096842] >ffff800062e3b280: 01 fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
[ 394.104056] ^
[ 394.107283] ffff800062e3b300: fb fb fb fb fb fb fb fb fc fc fc fc fc fc fc fc
[ 394.114502] ffff800062e3b380: fb fb fb fb fb fb fb fb fc fc fc fc fc fc fc fc
[ 394.121718] ==================================================================
Signed-off-by: Yang Yang <yang.yang29@zte.com.cn>
Extend some inode methods with an additional user namespace argument. A
filesystem that is aware of idmapped mounts will receive the user
namespace the mount has been marked with. This can be used for
additional permission checking and also to enable filesystems to
translate between uids and gids if they need to. We have implemented all
relevant helpers in earlier patches.
As requested we simply extend the exisiting inode method instead of
introducing new ones. This is a little more code churn but it's mostly
mechanical and doesnt't leave us with additional inode methods.
Link: https://lore.kernel.org/r/20210121131959.646623-25-christian.brauner@ubuntu.com
Cc: Christoph Hellwig <hch@lst.de>
Cc: David Howells <dhowells@redhat.com>
Cc: Al Viro <viro@zeniv.linux.org.uk>
Cc: linux-fsdevel@vger.kernel.org
Signed-off-by: Christian Brauner <christian.brauner@ubuntu.com>
The macro use will already have a semicolon.
Signed-off-by: Tom Rix <trix@redhat.com>
Set rp_size to zero will be ignore during remounting.
The method to identify whether we input a remounting option of
rp_size is to check if the rp_size input is zero. It can not work
well if we pass "rp_size=0".
This patch add a bool variable "set_rp_size" to fix this problem.
Reported-by: Jubin Zhong <zhongjubin@huawei.com>
The log of this problem is:
jffs2: Error garbage collecting node at 0x***!
jffs2: No space for garbage collection. Aborting GC thread
This is because GC believe that it do nothing, so it abort.
After going over the image of jffs2, I find a scene that
can trigger this problem stably.
The scene is: there is a normal dirent node at summary-area,
but abnormal at corresponding not-summary-area with error
name_crc.
The reason that GC exit abnormally is because it find that
abnormal dirent node to GC, but when it goes to function
jffs2_add_fd_to_list, it cannot meet the condition listed
below:
if ((*prev)->nhash == new->nhash && !strcmp((*prev)->name, new->name))
So no node is marked obsolete, statistical information of
erase_block do not change, which cause GC exit abnormally.
The root cause of this problem is: we do not check the
name_crc of the abnormal dirent node with summary is enabled.
Noticed that in function jffs2_scan_dirent_node, we use
function jffs2_scan_dirty_space to deal with the dirent
node with error name_crc. So this patch add a checking
code in function read_direntry to ensure the correctness
of dirent node. If checked failed, the dirent node will
be marked obsolete so GC will pass this node and this
problem will be fixed.
Cc: <stable@vger.kernel.org>
Signed-off-by: Zhe Li <lizhe67@huawei.com>
When debug (print) macros are not enabled, change them to use the
no_printk() macro instead of <nothing>. This fixes gcc warnings when
-Wextra is used:
../cpukit/libfs/src/jffs2/src/nodelist.c:255:37: warning: suggest braces around empty body in an ‘else’ statement [-Wempty-body]
../cpukit/libfs/src/jffs2/src/nodelist.c:278:38: warning: suggest braces around empty body in an ‘else’ statement [-Wempty-body]
../cpukit/libfs/src/jffs2/src/nodelist.c:558:52: warning: suggest braces around empty body in an ‘else’ statement [-Wempty-body]
../cpukit/libfs/src/jffs2/src/xattr.c:1247:58: warning: suggest braces around empty body in an ‘if’ statement [-Wempty-body]
../cpukit/libfs/src/jffs2/src/xattr.c:1281:65: warning: suggest braces around empty body in an ‘if’ statement [-Wempty-body]
Builds without warnings on all 3 levels of CONFIG_JFFS2_FS_DEBUG.
Signed-off-by: Randy Dunlap <rdunlap@infradead.org>
Cc: David Woodhouse <dwmw2@infradead.org>
Cc: Richard Weinberger <richard@nod.at>
Cc: linux-mtd@lists.infradead.org
A follow up patch uses no_printk().
CID 1506523: Unchecked return value from library (CHECKED_RETURN)
CID 1506522: Unchecked return value from library (CHECKED_RETURN)
CID 1437618: Unchecked return value from library (CHECKED_RETURN)
Close #4718
Directly use "static inline" which is available in C99 and later. This brings
the RTEMS implementation closer to standard C.
Close #3935.
The original file cpukit/libfs/src/ftpfs/tftpDriver.c
is split into two:
tftpfs.c - This file contains the code from tftpDriver.c
related to file system operations such as mount(),
open(), read(), and so on.
tftpDriver.c - In the original file remains only the code related
to networking. This code implements the Trivial
File Transfer Protocol (TFTP).
Moreover, the code is extended to support
* RFC 2347 TFTP Option Extension
* RFC 2348 TFTP Blocksize Option
* RFC 7440 TFTP Windowsize Option
Update #4666.
Update #4666.
Replace the existing /* fall through */ comments and its variants with
the new pseudo-keyword macro fallthrough[1]. Also, remove unnecessary
fall-through markings when it is the case.
[1] https://www.kernel.org/doc/html/v5.7/process/deprecated.html?highlight=fallthrough#implicit-switch-case-fall-through
Thanks for the advice mentioned in the email.
This is my v3 patch for this problem.
Mounting jffs2 on nand flash will get message "failed: I/O error"
with the steps listed below.
1.umount jffs2
2.erase nand flash
3.mount jffs2 on it (this mounting operation will be successful)
4.do chown or chmod to the mount point directory
5.umount jffs2
6.mount jffs2 on nand flash
After step 6, we will get message "mount ... failed: I/O error".
Typical image of this problem is like:
Empty space found from 0x00000000 to 0x008a0000
Inode node at xx, totlen 0x00000044, #ino 1, version 1, isize 0...
The reason for this mounting failure is that at the end of function
jffs2_scan_medium(), jffs2 will check the used_size and some info
of nr_blocks.If conditions are met, it will return -EIO.
The detail is that, in the steps listed above, step 4 will write
jffs2_raw_inode into flash without jffs2_raw_dirent, which will
cause that there are some jffs2_raw_inode but no jffs2_raw_dirent
on flash. This will meet the condition at the end of function
jffs2_scan_medium() and return -EIO if we umount jffs2 and mount it
again.
We notice that jffs2 add the value of c->unchecked_size if we find
an inode node while mounting. And jffs2 will never add the value of
c->unchecked_size in other situations. So this patch add one more
condition about c->unchecked_size of the judgement to fix this problem.
Using uninitialized_var() is dangerous as it papers over real bugs[1]
(or can in the future), and suppresses unrelated compiler warnings
(e.g. "unused variable"). If the compiler thinks it is uninitialized,
either simply initialize the variable or make compiler changes.
In preparation for removing[2] the[3] macro[4], remove all remaining
needless uses with the following script:
git grep '\buninitialized_var\b' | cut -d: -f1 | sort -u | \
xargs perl -pi -e \
's/\buninitialized_var\(([^\)]+)\)/\1/g;
s:\s*/\* (GCC be quiet|to make compiler happy) \*/$::g;'
drivers/video/fbdev/riva/riva_hw.c was manually tweaked to avoid
pathological white-space.
No outstanding warnings were found building allmodconfig with GCC 9.3.0
for x86_64, i386, arm64, arm, powerpc, powerpc64le, s390x, mips, sparc64,
alpha, and m68k.
[1] https://lore.kernel.org/lkml/20200603174714.192027-1-glider@google.com/
[2] https://lore.kernel.org/lkml/CA+55aFw+Vbj0i=1TGqCR5vQkCzWJ0QxK6CernOU6eedsudAixw@mail.gmail.com/
[3] https://lore.kernel.org/lkml/CA+55aFwgbgqhbp1fkxvRKEpzyR5J8n1vKT1VZdz9knmPuXhOeg@mail.gmail.com/
[4] https://lore.kernel.org/lkml/CA+55aFz2500WfbKXAx8s67wrm9=yVJu65TpLgN_ybYNv0VEOKA@mail.gmail.com/
Reviewed-by: Leon Romanovsky <leonro@mellanox.com> # drivers/infiniband and mlx4/mlx5
Acked-by: Jason Gunthorpe <jgg@mellanox.com> # IB
Acked-by: Kalle Valo <kvalo@codeaurora.org> # wireless drivers
Reviewed-by: Chao Yu <yuchao0@huawei.com> # erofs
Signed-off-by: Kees Cook <keescook@chromium.org>
There is a regular need in the kernel to provide a way to declare having a
dynamically sized set of trailing elements in a structure. Kernel code should
always use “flexible array members”[1] for these cases. The older style of
one-element or zero-length arrays should no longer be used[2].
[2] https://github.com/KSPP/linux/issues/21
