The rtems_filesystem_location_info_t::node_access_2 was unused by the
IMFS. Use it to hold the context of generic nodes. This makes it
possible to use node handlers for objects with and without a
corresponding file system node.
For example network sockets created with socket() have only a file
descriptor, but no corresponding file system node. The UNIX(4) domain
sockets can be bound to file system nodes. In both cases the
rtems_filesystem_location_info_t must provide a pointer to the socket
structure used by the socket node handlers. With the context pointer
(for sockets, this is the socket structure) in
rtems_filesystem_location_info_t::node_access_2 the same node handlers
can be used in both cases.
The readv() and writev() support was implemented in terms of multiple
calls to the read and write handlers. This imposes a problem on device
files which use an IO vector as single request entity. For example a
low-level network device (e.g. BPF(4)) may use an IO vector to create
one frame from multiple protocol layers each with its own IO vector
entry.
This is for the RFS file system. There is a bug in the
rtems_rfs_bitmap_create_search loop. It is supposed to iterate
over the range of bits in a search element ( usually 32 bits ),
so it should loop through bits 0 through 31. Instead it loops
through 0 - 32, causing some blocks not to be allocated. As in
PR 2163, this depends on the block size and number of blocks in
a file system. Block sizes and group sizes that are powers of 2
seem to work fine ( 512 byte blocks, 4096 block groups, etc ).
When the block sizes are not powers of 2, then this loop error
causes some of the blocks at the end of a group to be skipped,
preventing 100% of the blocks from being used. A simple test
for this and PR2163 is to create a RAM disk with block size
3900 and at least 1 full group ( 31200 blocks ). A file system
with these sizes will not be able to allocate 100% of the blocks.
This is for the RFS file system. The statvfs call reports 1 block free
when the file system is full because it does not account for the superblock
in its calculation of free blocks.
This is a simple fix that adjusts the number of blocks reported to account
for the superblock. We may want to wait for a more complete solution such
as locating the superblock in each group.
This is for the RFS file system. There is a bug in the group search
algorithm where it will skip groups, causing blocks to remain
unallocated. This is dependant on the size of the blocks and number
of blocks in a group, so it does not always show up. The fix corrects
the skipping of groups during the search, allowing all of the blocks
to be found.
Return an error status with errno set to ENOSYS during node creation for
nodes not available in the current configuration.
Patch from Nick for this. Thanks.
The read call was only returning once the requested buffer was full.
The change returns any available data.
The FIFO was incorrectly set to the default control block.
This handler is necessary to implement the KQUEUE(2) system calls.
Add <sys/event.h> from FreeBSD 8.4.
This handler is necessary to implement the SELECT(2) and POLL(2) system
calls.
Add <sys/poll.h> from FreeBSD 8.4.
This is in line with Linux and FreeBSD.
According to POSIX this case is implementation defined. Linux and
FreeBSD return EINVAL.
Modify compatbility layer for RTEMS. Add support for Linux 3.11 based
JFFS2.
Import of Linux compatibility layer and JFFS2 file system support from
eCos.
The files are imported from eCos CVS on 2013-09-16.
cvs -d :pserver:anoncvs@ecos.sourceware.org:/cvs/ecos login
cvs -z3 -d :pserver:anoncvs@ecos.sourceware.org:/cvs/ecos co -P ecos
The files
"ecos/packages/compat/linux/current/asm/atomic.h",
"ecos/packages/compat/linux/current/asm/bug.h",
"ecos/packages/compat/linux/current/asm/page.h",
"ecos/packages/compat/linux/current/cyg/crc/crc.h",
"ecos/packages/compat/linux/current/cyg/infra/cyg_type.h",
"ecos/packages/compat/linux/current/linux/compiler.h",
"ecos/packages/compat/linux/current/linux/completion.h",
"ecos/packages/compat/linux/current/linux/config.h",
"ecos/packages/compat/linux/current/linux/crc32.h",
"ecos/packages/compat/linux/current/linux/errno.h",
"ecos/packages/compat/linux/current/linux/fs.h",
"ecos/packages/compat/linux/current/linux/kernel.h",
"ecos/packages/compat/linux/current/linux/list.h",
"ecos/packages/compat/linux/current/linux/mtd/compatmac.h",
"ecos/packages/compat/linux/current/linux/mtd/mtd.h",
"ecos/packages/compat/linux/current/linux/pagemap.h",
"ecos/packages/compat/linux/current/linux/rbtree.h",
"ecos/packages/compat/linux/current/linux/rwsem.h",
"ecos/packages/compat/linux/current/linux/sched.h",
"ecos/packages/compat/linux/current/linux/slab.h",
"ecos/packages/compat/linux/current/linux/spinlock.h",
"ecos/packages/compat/linux/current/linux/stat.h",
"ecos/packages/compat/linux/current/linux/string.h",
"ecos/packages/compat/linux/current/linux/timer.h",
"ecos/packages/compat/linux/current/linux/types.h",
"ecos/packages/compat/linux/current/linux/version.h",
"ecos/packages/compat/linux/current/linux/vmalloc.h",
"ecos/packages/compat/linux/current/linux/wait.h",
"ecos/packages/compat/linux/current/linux/workqueue.h", and
"ecos/packages/compat/linux/current/linux/zlib.h"
"ecos/packages/compat/linux/current/linux/zutil.h"
are copied to "cpukit/libfs/src/jffs2/include".
The file "ecos/packages/services/crc/current/src/crc32.c" is copied to
"cpukit/libfs/src/jffs2/src/compat-crc32.c".
The file "ecos/packages/compat/linux/current/src/rbtree.c" is copied to
"cpukit/libfs/src/jffs2/src/compat-rbtree.c".
The file "ecos/packages/fs/jffs2/current/src/dir-ecos.c" is copied to
"cpukit/libfs/src/jffs2/src/dir-rtems.c".
The file "ecos/packages/fs/jffs2/current/src/flashio.c" is copied to
"cpukit/libfs/src/jffs2/src/flashio.c".
The file "ecos/packages/fs/jffs2/current/src/fs-ecos.c" is copied to
"cpukit/libfs/src/jffs2/src/fs-rtems.c".
The file "ecos/packages/fs/jffs2/current/src/malloc-ecos.c" is copied to
"cpukit/libfs/src/jffs2/src/malloc-rtems.c".
The file "ecos/packages/fs/jffs2/current/src/os-ecos.h" is copied to
"cpukit/libfs/src/jffs2/src/os-rtems.h".
The LICENSE file referenced in some files of this patch set is part of a
previous patch set imported from Linux.
Import of Journalling Flash File System, Version 2 from Linux 3.11.
This part of the Linux kernel is under a separate license which is
similar to the RTEMS license.
The file "cpukit/libfs/src/jffs2/include/linux/jffs2.h" is a copy of
"linux-3.11/include/uapi/linux/jffs2.h".
The file "LICENSE.JFFS2" is a copy of "linux-3.11/fs/jffs2/LICENCE".
The files
"linux-3.11/fs/jffs2/LICENCE",
"linux-3.11/fs/jffs2/acl.h",
"linux-3.11/fs/jffs2/build.c",
"linux-3.11/fs/jffs2/compr.c",
"linux-3.11/fs/jffs2/compr.h",
"linux-3.11/fs/jffs2/compr_rtime.c",
"linux-3.11/fs/jffs2/compr_rubin.c",
"linux-3.11/fs/jffs2/compr_zlib.c",
"linux-3.11/fs/jffs2/debug.c",
"linux-3.11/fs/jffs2/debug.h",
"linux-3.11/fs/jffs2/erase.c",
"linux-3.11/fs/jffs2/gc.c",
"linux-3.11/fs/jffs2/jffs2_fs_i.h",
"linux-3.11/fs/jffs2/jffs2_fs_sb.h",
"linux-3.11/fs/jffs2/nodelist.c",
"linux-3.11/fs/jffs2/nodelist.h",
"linux-3.11/fs/jffs2/nodemgmt.c",
"linux-3.11/fs/jffs2/read.c",
"linux-3.11/fs/jffs2/readinode.c",
"linux-3.11/fs/jffs2/scan.c",
"linux-3.11/fs/jffs2/summary.h",
"linux-3.11/fs/jffs2/write.c", and
"linux-3.11/fs/jffs2/xattr.h"
are copied to "cpukit/libfs/src/jffs2/src".
ftruncate() and open() with O_TRUNC shall upon successful completion
mark for update the st_ctime and st_mtime fields of the file.
truncate() shall upon successful completion, if the file size is
changed, mark for update the st_ctime and st_mtime fields of the file.
The POSIX standard "The Open Group Base Specifications Issue 7", IEEE
Std 1003.1, 2013 Edition says nothing about the behaviour of truncate()
if the file size remains unchanged.
Future directions of the standard may mandate the behaviour specified in
ftruncate():
http://austingroupbugs.net/view.php?id=489
Implement POSIX requirements in the high-level file system layer.
Replace strcpy and strcat with counted variants.
Also eliminates possibly dead code in case the name_type can never
actually be MSDOS_NAME_INVALID.
1063860 Logically dead code.
If opts is NULL, then strchr() will dereference it and search for 's'.
1063863 Dereference after null check
Change the type for storing the return from iconv to be signed.
Fix the type of "cmpltd" to be ssize_t so that assigning it to -1
will terminate processing as intended.
Explicitly promote 32-bit integer to 64-bits for multiplication.
Free fs_info in case root_node is NULL.
This area is protected by the RFS file system instance lock.
This is a cosmetic fix. There was no bug.
This area is protected by the FAT file system instance lock.
declaration, matching its definition
See https://www.rtems.org/bugzilla/show_bug.cgi?id=2137
the error.
The change lets the mrfs_fsrdwr test pass.
Move implementation specific parts of states.h and states.inl into new
header file statesimpl.h. The states.h contains now only the
application visible API.
