Change rtems-rfs to rtems_rfs
PR 1968/filesystem
* libfs/src/rfs/rtems-rfs-file.c: Fix to the seek bug where a seek
to 0 after reading the end of the file did not point to the
correct block.
* libfs/src/rfs/rtems-rfs-rtems.h,
libfs/src/rfs/rtems-rfs-trace.c: Fix the trace flags. Used to fix
the bug.
* libfs/src/rfs/rtems-rfs-trace.c,
libfs/src/rfs/rtems-rfs-trace.h: Add inode-delete.
* libfs/src/rfs/rtems-rfs-shell.c: Fix formatting.
* libfs/src/rfs/rtems-rfs-rtems-dir.c: Use ssize_t. Fix spelling.
* libfs/src/rfs/rtems-rfs-block.c: Fix rtems_rfs_block_get_bpos to
return the position correctly. A bpos does not have any special
processing. Do no reset the buffer handle when shrinking
indirectly.
* libfs/src/rfs/rtems-rfs-inode.c: Add trace.
* libfs/src/rfs/rtems-rfs-format.c: Fix comments.
* libfs/src/rfs/rtems-rfs-group.c: Limit the inodes to the blocks
in a group so the accounting works.
* libfs/src/rfs/rtems-rfs-dir.c: PR 1705. Fix handling the offsets
when deleting an entry.
* libfs/src/rfs/rtems-rfs-buffer.h: Remove
rtems_rfs_buffer_handle_reset. It is not needed and dangerous.
libfs/src/nfsclient/src/cexphelp.c,
libfs/src/nfsclient/src/dirutils.c,
libfs/src/nfsclient/src/nfs.modini.c,
libfs/src/nfsclient/src/nfsTest.c,
libfs/src/nfsclient/src/rpcio.c,
libfs/src/nfsclient/src/rpcio.modini.c,
libfs/src/nfsclient/src/sock_mbuf.c,
libfs/src/nfsclient/src/xdr_mbuf.c,
libfs/src/rfs/rtems-rfs-bitmaps-ut.c,
libfs/src/rfs/rtems-rfs-bitmaps.c,
libfs/src/rfs/rtems-rfs-block.c,
libfs/src/rfs/rtems-rfs-buffer-bdbuf.c,
libfs/src/rfs/rtems-rfs-buffer-devio.c,
libfs/src/rfs/rtems-rfs-buffer.c,
libfs/src/rfs/rtems-rfs-dir-hash.c, libfs/src/rfs/rtems-rfs-dir.c,
libfs/src/rfs/rtems-rfs-file-system.c,
libfs/src/rfs/rtems-rfs-file.c, libfs/src/rfs/rtems-rfs-format.c,
libfs/src/rfs/rtems-rfs-group.c, libfs/src/rfs/rtems-rfs-inode.c,
libfs/src/rfs/rtems-rfs-link.c, libfs/src/rfs/rtems-rfs-mutex.c,
libfs/src/rfs/rtems-rfs-rtems-dev.c,
libfs/src/rfs/rtems-rfs-rtems-dir.c,
libfs/src/rfs/rtems-rfs-rtems-file.c,
libfs/src/rfs/rtems-rfs-rtems-utils.c,
libfs/src/rfs/rtems-rfs-rtems.c, libfs/src/rfs/rtems-rfs-shell.c,
libfs/src/rfs/rtems-rfs-trace.c: Add HAVE_CONFIG_H support to let
files receive configure defines.
* libfs/src/rfs/rtems-rfs-bitmaps.c,
libfs/src/rfs/rtems-rfs-bitmaps.h,
libfs/src/rfs/rtems-rfs-block.c, libfs/src/rfs/rtems-rfs-block.h,
libfs/src/rfs/rtems-rfs-block-pos.h,
libfs/src/rfs/rtems-rfs-buffer.h, libfs/src/rfs/rtems-rfs-data.h,
libfs/src/rfs/rtems-rfs-dir.c, libfs/src/rfs/rtems-rfs-dir.h,
libfs/src/rfs/rtems-rfs-dir-hash.h,
libfs/src/rfs/rtems-rfs-file.c, libfs/src/rfs/rtems-rfs-file.h,
libfs/src/rfs/rtems-rfs-file-system-fwd.h,
libfs/src/rfs/rtems-rfs-file-system.h,
libfs/src/rfs/rtems-rfs-format.h, libfs/src/rfs/rtems-rfs-group.c,
libfs/src/rfs/rtems-rfs-group.h, libfs/src/rfs/rtems-rfs.h,
libfs/src/rfs/rtems-rfs-inode.c, libfs/src/rfs/rtems-rfs-inode.h,
libfs/src/rfs/rtems-rfs-link.c, libfs/src/rfs/rtems-rfs-link.h,
libfs/src/rfs/rtems-rfs-mutex.c, libfs/src/rfs/rtems-rfs-mutex.h,
libfs/src/rfs/rtems-rfs-shell.c, libfs/src/rfs/rtems-rfs-shell.h,
libfs/src/rfs/rtems-rfs-trace.c, libfs/src/rfs/rtems-rfs-trace.h:
New.
* Makefile.am, preinstall.am, libfs/Makefile.am,
wrapup/Makefile.am: Updated with the RFS support.
* libfs/README: Updated after 10 years.
* libblock/src/flashdisk.c, libblock/src/nvdisk.c,
libblock/src/ramdisk-driver.c: Updated to the new error reporting
in libblock.
* libmisc/shell/main_ls.c, libmisc/shell/print-ls.c: Fix printing
the size in long mode.
* libnetworking/nfs/bootp_subr.c,
libnetworking/rtems/rtems_bootp.c,
libnetworking/rtems/rtems_bsdnet_internal.h: Return the BOOTP/DHCP
to the forever behaviour of 4.9 with the ability to call BOOTP and
control the process if required.
