Closes #2139
The output of the modules.html is much improved. Most
filesystem and POSIX API related groups are properly nested.
Some formatting issues were addressed as were multiple
inconsistencies.
http://www.google-melange.com/gci/task/view/google/gci2012/8120204
Patch committed with fixes for whitespace issues.
http://www.google-melange.com/gci/task/view/google/gci2012/8006220
The functions
o rtems_bdbuf_get(),
o rtems_bdbuf_read(),
o rtems_bdbuf_syncdev(), and
o rtems_bdbuf_purge_dev(),
use now the disk device instead of the device identifier. This makes
bdbuf independent of rtems_disk_obtain() and rtems_disk_release(). It
is the responsiblity of the file system to obtain the disk device. This
also reduces the overhead to get a buffer.
The key for the AVL tree uses now the disk device instead of the device
identifier. The pointer is interpreted as an unsigned integer. This
reduces the memory overhead and makes the comparison operation a bit
faster.
Removed function rtems_bdbuf_purge_major(). This function was too
destructive and could have unpredictable side effects.
PR 1948/filesystem
* libfs/src/rfs/rtems-rfs-file-system.c,
libfs/src/rfs/rtems-rfs-file-system.h,
libfs/src/rfs/rtems-rfs-format.c, libfs/src/rfs/rtems-rfs-rtems.c:
Add support for mount passing an ASCIIZ string containing
configuration options. Remove the hardcoded dir string and
size. Fix comments.
* libblock/src/bdbuf.c: Fix state labels in trace output.
* libfs/src/rfs/rtems-rfs-file-system.h,
libfs/src/rfs/rtems-rfs-file-system.c: Move questionable macros to
C functions.
* libfs/src/rfs/rtems-rfs-file-system.h: Revert previous change.
Force RTEMS_RFS_VERSION_MASK to be 32bit.
PR 1556/cpukit
* libfs/src/rfs/rtems-rfs-bitmaps.h,
libfs/src/rfs/rtems-rfs-block-pos.h,
libfs/src/rfs/rtems-rfs-buffer.h,
libfs/src/rfs/rtems-rfs-file-system-fwd.h,
libfs/src/rfs/rtems-rfs-file.h,
libfs/src/rfs/rtems-rfs-format.h,
libfs/src/rfs/rtems-rfs-group.h,
libfs/src/rfs/rtems-rfs-inode.h:
Rename "struct rtems_rfs_*_t" into "struct _rtems_rfs_*".
* libfs/src/rfs/rtems-rfs-file-system.h: Remove bogus typecast.
* libfs/src/rfs/rtems-rfs-block.c: Reset a buffer handle after
moving down an indirection level.
* libfs/src/rfs/rtems-rfs-dir.c: Move directory entry validation
into a macro and use the macro. Fix the range check on the ino so
all inodes can be used.
libfs/src/rfs/rtems-rfs-file-system.h:: Add a version number to
the superblock. Use RTEMS_RFS_INODE_SIZE.
* libfs/src/rfs/rtems-rfs-file.c: Fix the size offset on partial
block lengths. Set the size in the file handle on a truncate to
0.
* libfs/src/rfs/rtems-rfs-format.c: Add a version number to
the superblock. Use RTEMS_RFS_INODE_SIZE. A better set of defaults
for small disks.
* libfs/src/rfs/rtems-rfs-inode.c: Use RTEMS_RFS_INODE_SIZE. Free
the allocated inode if it cannot be opened.
* libfs/src/rfs/rtems-rfs-inode.h: Add RTEMS_RFS_INODE_SIZE.
* libfs/src/rfs/rtems-rfs-rtems-file.c: Move some of the iop
acceses inside the fs lock.
* libfs/src/rfs/rtems-rfs-shell.c: Use RTEMS_RFS_INODE_SIZE.
* libfs/src/rfs/rtems-rfs-dir.c: Fix printf format warning for a
64bit off_t.
* libfs/src/rfs/rtems-rfs-file-system.h: Add a macro to get the
file system flags.
* libfs/src/rfs/rtems-rfs-group.c,
libfs/src/rfs/rtems-rfs-group.h: Add rtems_rfs_group_usage.
* libfs/src/rfs/rtems-rfs-rtems.c: Fill in all the fields in the
statvfs struct.
* libfs/src/rfs/rtems-rfs-shell.c: Use rtems_rfs_group_usage.
* libfs/src/rfs/rtems-rfs-bitmaps.c,
libfs/src/rfs/rtems-rfs-bitmaps-ut.c,
libfs/src/rfs/rtems-rfs-block.c, libfs/src/rfs/rtems-rfs-block.h,
libfs/src/rfs/rtems-rfs-buffer-bdbuf.c,
libfs/src/rfs/rtems-rfs-buffer.c,
libfs/src/rfs/rtems-rfs-buffer-devio.c,
libfs/src/rfs/rtems-rfs-buffer.h, libfs/src/rfs/rtems-rfs-data.h,
libfs/src/rfs/rtems-rfs-dir.c, libfs/src/rfs/rtems-rfs-dir.h,
libfs/src/rfs/rtems-rfs-dir-hash.c,
libfs/src/rfs/rtems-rfs-dir-hash.h,
libfs/src/rfs/rtems-rfs-file.c, libfs/src/rfs/rtems-rfs-file.h,
libfs/src/rfs/rtems-rfs-format.h, libfs/src/rfs/rtems-rfs-group.c,
libfs/src/rfs/rtems-rfs-group.h, libfs/src/rfs/rtems-rfs.h,
libfs/src/rfs/rtems-rfs-inode.c, libfs/src/rfs/rtems-rfs-inode.h,
libfs/src/rfs/rtems-rfs-link.c, libfs/src/rfs/rtems-rfs-link.h,
libfs/src/rfs/rtems-rfs-mutex.c, libfs/src/rfs/rtems-rfs-mutex.h,
libfs/src/rfs/rtems-rfs-rtems.c,
libfs/src/rfs/rtems-rfs-rtems-dev.c,
libfs/src/rfs/rtems-rfs-rtems-dir.c,
libfs/src/rfs/rtems-rfs-rtems-file.c,
libfs/src/rfs/rtems-rfs-rtems.h,
libfs/src/rfs/rtems-rfs-rtems-utils.c,
libfs/src/rfs/rtems-rfs-shell.c, libfs/src/rfs/rtems-rfs-shell.h,
libfs/src/rfs/rtems-rfs-trace.c, libfs/src/rfs/rtems-rfs-trace.h:
New.
* Makefile.am, preinstall.am, libfs/Makefile.am,
wrapup/Makefile.am: Updated with the RFS support.
* libfs/README: Updated after 10 years.
* libblock/src/flashdisk.c, libblock/src/nvdisk.c,
libblock/src/ramdisk-driver.c: Updated to the new error reporting
in libblock.
* libmisc/shell/main_ls.c, libmisc/shell/print-ls.c: Fix printing
the size in long mode.
* libnetworking/nfs/bootp_subr.c,
libnetworking/rtems/rtems_bootp.c,
libnetworking/rtems/rtems_bsdnet_internal.h: Return the BOOTP/DHCP
to the forever behaviour of 4.9 with the ability to call BOOTP and
control the process if required.
