path: root/cpukit/libfs/src/rfs/rtems-rfs-dir-hash.c (follow)
* 2010-03-27 Chris Johns <chrisj@rtems.org>Chris Johns2010-03-271-0/+4
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | libfs/src/nfsclient/src/cexphelp.c, libfs/src/nfsclient/src/dirutils.c, libfs/src/nfsclient/src/nfs.modini.c, libfs/src/nfsclient/src/nfsTest.c, libfs/src/nfsclient/src/rpcio.c, libfs/src/nfsclient/src/rpcio.modini.c, libfs/src/nfsclient/src/sock_mbuf.c, libfs/src/nfsclient/src/xdr_mbuf.c, libfs/src/rfs/rtems-rfs-bitmaps-ut.c, libfs/src/rfs/rtems-rfs-bitmaps.c, libfs/src/rfs/rtems-rfs-block.c, libfs/src/rfs/rtems-rfs-buffer-bdbuf.c, libfs/src/rfs/rtems-rfs-buffer-devio.c, libfs/src/rfs/rtems-rfs-buffer.c, libfs/src/rfs/rtems-rfs-dir-hash.c, libfs/src/rfs/rtems-rfs-dir.c, libfs/src/rfs/rtems-rfs-file-system.c, libfs/src/rfs/rtems-rfs-file.c, libfs/src/rfs/rtems-rfs-format.c, libfs/src/rfs/rtems-rfs-group.c, libfs/src/rfs/rtems-rfs-inode.c, libfs/src/rfs/rtems-rfs-link.c, libfs/src/rfs/rtems-rfs-mutex.c, libfs/src/rfs/rtems-rfs-rtems-dev.c, libfs/src/rfs/rtems-rfs-rtems-dir.c, libfs/src/rfs/rtems-rfs-rtems-file.c, libfs/src/rfs/rtems-rfs-rtems-utils.c, libfs/src/rfs/rtems-rfs-rtems.c, libfs/src/rfs/rtems-rfs-shell.c, libfs/src/rfs/rtems-rfs-trace.c: Add HAVE_CONFIG_H support to let files receive configure defines.
* 2010-02-18 Chris Johns <chrisj@rtems.org>Chris Johns2010-02-181-0/+337
* libfs/src/rfs/rtems-rfs-bitmaps.c, libfs/src/rfs/rtems-rfs-bitmaps.h, libfs/src/rfs/rtems-rfs-bitmaps-ut.c, libfs/src/rfs/rtems-rfs-block.c, libfs/src/rfs/rtems-rfs-block.h, libfs/src/rfs/rtems-rfs-block-pos.h, libfs/src/rfs/rtems-rfs-buffer-bdbuf.c, libfs/src/rfs/rtems-rfs-buffer.c, libfs/src/rfs/rtems-rfs-buffer-devio.c, libfs/src/rfs/rtems-rfs-buffer.h, libfs/src/rfs/rtems-rfs-data.h, libfs/src/rfs/rtems-rfs-dir.c, libfs/src/rfs/rtems-rfs-dir.h, libfs/src/rfs/rtems-rfs-dir-hash.c, libfs/src/rfs/rtems-rfs-dir-hash.h, libfs/src/rfs/rtems-rfs-file.c, libfs/src/rfs/rtems-rfs-file.h, libfs/src/rfs/rtems-rfs-file-system.c, libfs/src/rfs/rtems-rfs-file-system-fwd.h, libfs/src/rfs/rtems-rfs-file-system.h, libfs/src/rfs/rtems-rfs-format.c, libfs/src/rfs/rtems-rfs-format.h, libfs/src/rfs/rtems-rfs-group.c, libfs/src/rfs/rtems-rfs-group.h, libfs/src/rfs/rtems-rfs.h, libfs/src/rfs/rtems-rfs-inode.c, libfs/src/rfs/rtems-rfs-inode.h, libfs/src/rfs/rtems-rfs-link.c, libfs/src/rfs/rtems-rfs-link.h, libfs/src/rfs/rtems-rfs-mutex.c, libfs/src/rfs/rtems-rfs-mutex.h, libfs/src/rfs/rtems-rfs-rtems.c, libfs/src/rfs/rtems-rfs-rtems-dev.c, libfs/src/rfs/rtems-rfs-rtems-dir.c, libfs/src/rfs/rtems-rfs-rtems-file.c, libfs/src/rfs/rtems-rfs-rtems.h, libfs/src/rfs/rtems-rfs-rtems-utils.c, libfs/src/rfs/rtems-rfs-shell.c, libfs/src/rfs/rtems-rfs-shell.h, libfs/src/rfs/rtems-rfs-trace.c, libfs/src/rfs/rtems-rfs-trace.h: New. * Makefile.am, preinstall.am, libfs/Makefile.am, wrapup/Makefile.am: Updated with the RFS support. * libfs/README: Updated after 10 years. * libblock/src/flashdisk.c, libblock/src/nvdisk.c, libblock/src/ramdisk-driver.c: Updated to the new error reporting in libblock. * libmisc/shell/main_ls.c, libmisc/shell/print-ls.c: Fix printing the size in long mode. * libnetworking/nfs/bootp_subr.c, libnetworking/rtems/rtems_bootp.c, libnetworking/rtems/rtems_bsdnet_internal.h: Return the BOOTP/DHCP to the forever behaviour of 4.9 with the ability to call BOOTP and control the process if required.
