Avoid use of RTEMS_RELLDFLAGS.
Close #3390.
Update #2843.
Update #2843.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3132.
Added a mmap file handler to struct _rtems_filesystem_file_handlers_r.
Updated each file handler object to support the default mmap handler.
Updated mmap() to call the mmap handler for MAP_SHARED.
Added a mmap file handler for shm
Added support for MAP_ANON in mmap().
Updates #2859
Some kernel-space header expect that <sys/param.h> is present.
Update #2833.
Provide extentions to <inttpes.h> PRIxxx constants for more POSIX types.
Start with existing definitions found in RTEMS Project owned code
in cpukit/.
updates #2983.
Update #2388.
Close #2700.
closes #2384
Use the fstat handler instead.
The __FILE__ prevents reproducible builds.
Similar to the task priority option, the new CPU affinity
option is first controlled by the RPCI specific rpciodCpuset
option. If that is not set, it uses the global network task config.
If that is also not set, it falls back to not setting the affinity
at all, using all CPUs.
The readv() and writev() support was implemented in terms of multiple
calls to the read and write handlers. This imposes a problem on device
files which use an IO vector as single request entity. For example a
low-level network device (e.g. BPF(4)) may use an IO vector to create
one frame from multiple protocol layers each with its own IO vector
entry.
If opts is NULL, then strchr() will dereference it and search for 's'.
1063863 Dereference after null check
Avoid assert() and use proper cleanup if nfsInit() fails to allocate a
resource.
There were minor conflicts and the modifications that were
in the repo were favored over the modifications in the submitted
patch.
The NFS status codes do not map directly to the corresponding errno
values.
The XDR library has a problem on architectures with short enums like the
default ARM EABI. Short enums means that the size of the enum type is
variable and the smallest integer type to hold all enum values will be
selected. For many enums this is char. The XDR library uses int32_t
for enum_t. There are several evil casts from an enum type to enum_t
which leads to invalid memory accesses on short enum architectures. A
workaround is to add appropriate dummy enum values.
The pathconf_limits_and_options field of
rtems_filesystem_mount_table_entry_t is now a const pointer to reduce
the read-write memory demands of file system instances.
The scope of the file system operations is the file system instance.
The scope of the file system node handlers is the file location. The
benefit of moving the operations to the mount table entry is a size
reduction of the file location (rtems_filesystem_location_info_t). The
code size is slightly increased due to additional load instructions.
Restructure rtems_filesystem_mount_table_entry_t to improve cache
efficiency.
It is now the responsibility of the read() and write() handler to update
the offset field of the IO descriptor (rtems_libio_t). This change
makes it possible to protect the IO descriptor from concurrent access by
per file locks.
According to POSIX the lseek() function shall not, by itself, extend the
size of a file.
Remove the size field of rtems_libio_t. A file has only one size but
may have multiple open file descriptors. Thus a file size field in the
file descriptor may lead to inconsistencies.
New default handlers rtems_filesystem_default_lseek_file() and
rtems_filesystem_default_lseek_directory().
for details.
Use UID and GID of the NFS handle for node and symbolic link creation.
According to POSIX the read() call should return the maximum number of
bytes available for regular files.
