Use the fstat handler instead.
It is used in combination with the inode number to uniquely identify a
file system node in the system.
The readv() and writev() support was implemented in terms of multiple
calls to the read and write handlers. This imposes a problem on device
files which use an IO vector as single request entity. For example a
low-level network device (e.g. BPF(4)) may use an IO vector to create
one frame from multiple protocol layers each with its own IO vector
entry.
Modify compatbility layer for RTEMS. Add support for Linux 3.11 based
JFFS2.
Import of Linux compatibility layer and JFFS2 file system support from
eCos.
The files are imported from eCos CVS on 2013-09-16.
cvs -d :pserver:anoncvs@ecos.sourceware.org:/cvs/ecos login
cvs -z3 -d :pserver:anoncvs@ecos.sourceware.org:/cvs/ecos co -P ecos
The files
"ecos/packages/compat/linux/current/asm/atomic.h",
"ecos/packages/compat/linux/current/asm/bug.h",
"ecos/packages/compat/linux/current/asm/page.h",
"ecos/packages/compat/linux/current/cyg/crc/crc.h",
"ecos/packages/compat/linux/current/cyg/infra/cyg_type.h",
"ecos/packages/compat/linux/current/linux/compiler.h",
"ecos/packages/compat/linux/current/linux/completion.h",
"ecos/packages/compat/linux/current/linux/config.h",
"ecos/packages/compat/linux/current/linux/crc32.h",
"ecos/packages/compat/linux/current/linux/errno.h",
"ecos/packages/compat/linux/current/linux/fs.h",
"ecos/packages/compat/linux/current/linux/kernel.h",
"ecos/packages/compat/linux/current/linux/list.h",
"ecos/packages/compat/linux/current/linux/mtd/compatmac.h",
"ecos/packages/compat/linux/current/linux/mtd/mtd.h",
"ecos/packages/compat/linux/current/linux/pagemap.h",
"ecos/packages/compat/linux/current/linux/rbtree.h",
"ecos/packages/compat/linux/current/linux/rwsem.h",
"ecos/packages/compat/linux/current/linux/sched.h",
"ecos/packages/compat/linux/current/linux/slab.h",
"ecos/packages/compat/linux/current/linux/spinlock.h",
"ecos/packages/compat/linux/current/linux/stat.h",
"ecos/packages/compat/linux/current/linux/string.h",
"ecos/packages/compat/linux/current/linux/timer.h",
"ecos/packages/compat/linux/current/linux/types.h",
"ecos/packages/compat/linux/current/linux/version.h",
"ecos/packages/compat/linux/current/linux/vmalloc.h",
"ecos/packages/compat/linux/current/linux/wait.h",
"ecos/packages/compat/linux/current/linux/workqueue.h", and
"ecos/packages/compat/linux/current/linux/zlib.h"
"ecos/packages/compat/linux/current/linux/zutil.h"
are copied to "cpukit/libfs/src/jffs2/include".
The file "ecos/packages/services/crc/current/src/crc32.c" is copied to
"cpukit/libfs/src/jffs2/src/compat-crc32.c".
The file "ecos/packages/compat/linux/current/src/rbtree.c" is copied to
"cpukit/libfs/src/jffs2/src/compat-rbtree.c".
The file "ecos/packages/fs/jffs2/current/src/dir-ecos.c" is copied to
"cpukit/libfs/src/jffs2/src/dir-rtems.c".
The file "ecos/packages/fs/jffs2/current/src/flashio.c" is copied to
"cpukit/libfs/src/jffs2/src/flashio.c".
The file "ecos/packages/fs/jffs2/current/src/fs-ecos.c" is copied to
"cpukit/libfs/src/jffs2/src/fs-rtems.c".
The file "ecos/packages/fs/jffs2/current/src/malloc-ecos.c" is copied to
"cpukit/libfs/src/jffs2/src/malloc-rtems.c".
The file "ecos/packages/fs/jffs2/current/src/os-ecos.h" is copied to
"cpukit/libfs/src/jffs2/src/os-rtems.h".
The LICENSE file referenced in some files of this patch set is part of a
previous patch set imported from Linux.
Import of Journalling Flash File System, Version 2 from Linux 3.11.
This part of the Linux kernel is under a separate license which is
similar to the RTEMS license.
The file "cpukit/libfs/src/jffs2/include/linux/jffs2.h" is a copy of
"linux-3.11/include/uapi/linux/jffs2.h".
The file "LICENSE.JFFS2" is a copy of "linux-3.11/fs/jffs2/LICENCE".
The files
"linux-3.11/fs/jffs2/LICENCE",
"linux-3.11/fs/jffs2/acl.h",
"linux-3.11/fs/jffs2/build.c",
"linux-3.11/fs/jffs2/compr.c",
"linux-3.11/fs/jffs2/compr.h",
"linux-3.11/fs/jffs2/compr_rtime.c",
"linux-3.11/fs/jffs2/compr_rubin.c",
"linux-3.11/fs/jffs2/compr_zlib.c",
"linux-3.11/fs/jffs2/debug.c",
"linux-3.11/fs/jffs2/debug.h",
"linux-3.11/fs/jffs2/erase.c",
"linux-3.11/fs/jffs2/gc.c",
"linux-3.11/fs/jffs2/jffs2_fs_i.h",
"linux-3.11/fs/jffs2/jffs2_fs_sb.h",
"linux-3.11/fs/jffs2/nodelist.c",
"linux-3.11/fs/jffs2/nodelist.h",
"linux-3.11/fs/jffs2/nodemgmt.c",
"linux-3.11/fs/jffs2/read.c",
"linux-3.11/fs/jffs2/readinode.c",
"linux-3.11/fs/jffs2/scan.c",
"linux-3.11/fs/jffs2/summary.h",
"linux-3.11/fs/jffs2/write.c", and
"linux-3.11/fs/jffs2/xattr.h"
are copied to "cpukit/libfs/src/jffs2/src".
