path: root/cpukit/libfs/src/jffs2/src/compat-crc32.c (unfollow)
2018-04-30jffs2: Do not use command line definesSebastian Huber1-0/+2
Update #3375.
2013-09-19JFFS2: Import from eCosSebastian Huber1-0/+166
Import of Linux compatibility layer and JFFS2 file system support from eCos. The files are imported from eCos CVS on 2013-09-16. cvs -d :pserver:anoncvs@ecos.sourceware.org:/cvs/ecos login cvs -z3 -d :pserver:anoncvs@ecos.sourceware.org:/cvs/ecos co -P ecos The files "ecos/packages/compat/linux/current/asm/atomic.h", "ecos/packages/compat/linux/current/asm/bug.h", "ecos/packages/compat/linux/current/asm/page.h", "ecos/packages/compat/linux/current/cyg/crc/crc.h", "ecos/packages/compat/linux/current/cyg/infra/cyg_type.h", "ecos/packages/compat/linux/current/linux/compiler.h", "ecos/packages/compat/linux/current/linux/completion.h", "ecos/packages/compat/linux/current/linux/config.h", "ecos/packages/compat/linux/current/linux/crc32.h", "ecos/packages/compat/linux/current/linux/errno.h", "ecos/packages/compat/linux/current/linux/fs.h", "ecos/packages/compat/linux/current/linux/kernel.h", "ecos/packages/compat/linux/current/linux/list.h", "ecos/packages/compat/linux/current/linux/mtd/compatmac.h", "ecos/packages/compat/linux/current/linux/mtd/mtd.h", "ecos/packages/compat/linux/current/linux/pagemap.h", "ecos/packages/compat/linux/current/linux/rbtree.h", "ecos/packages/compat/linux/current/linux/rwsem.h", "ecos/packages/compat/linux/current/linux/sched.h", "ecos/packages/compat/linux/current/linux/slab.h", "ecos/packages/compat/linux/current/linux/spinlock.h", "ecos/packages/compat/linux/current/linux/stat.h", "ecos/packages/compat/linux/current/linux/string.h", "ecos/packages/compat/linux/current/linux/timer.h", "ecos/packages/compat/linux/current/linux/types.h", "ecos/packages/compat/linux/current/linux/version.h", "ecos/packages/compat/linux/current/linux/vmalloc.h", "ecos/packages/compat/linux/current/linux/wait.h", "ecos/packages/compat/linux/current/linux/workqueue.h", and "ecos/packages/compat/linux/current/linux/zlib.h" "ecos/packages/compat/linux/current/linux/zutil.h" are copied to "cpukit/libfs/src/jffs2/include". The file "ecos/packages/services/crc/current/src/crc32.c" is copied to "cpukit/libfs/src/jffs2/src/compat-crc32.c". The file "ecos/packages/compat/linux/current/src/rbtree.c" is copied to "cpukit/libfs/src/jffs2/src/compat-rbtree.c". The file "ecos/packages/fs/jffs2/current/src/dir-ecos.c" is copied to "cpukit/libfs/src/jffs2/src/dir-rtems.c". The file "ecos/packages/fs/jffs2/current/src/flashio.c" is copied to "cpukit/libfs/src/jffs2/src/flashio.c". The file "ecos/packages/fs/jffs2/current/src/fs-ecos.c" is copied to "cpukit/libfs/src/jffs2/src/fs-rtems.c". The file "ecos/packages/fs/jffs2/current/src/malloc-ecos.c" is copied to "cpukit/libfs/src/jffs2/src/malloc-rtems.c". The file "ecos/packages/fs/jffs2/current/src/os-ecos.h" is copied to "cpukit/libfs/src/jffs2/src/os-rtems.h". The LICENSE file referenced in some files of this patch set is part of a previous patch set imported from Linux.
