path: root/cpukit/libfs/src/imfs/imfs_ntype.c (follow)
* IMFS: New support functionsSebastian Huber2012-03-131-2/+2
| | | | Add and use IMFS_type() and IMFS_is_directory().
* Filesystem: Reference counting for locationsSebastian Huber2012-03-131-6/+21
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | o A new data structure rtems_filesystem_global_location_t was introduced to be used for o the mount point location in the mount table entry, o the file system root location in the mount table entry, o the root directory location in the user environment, and o the current directory location in the user environment. During the path evaluation global start locations are obtained to ensure that the current file system instance will be not unmounted in the meantime. o The user environment uses now reference counting and is protected from concurrent access. o The path evaluation process was completely rewritten and simplified. The IMFS, RFS, NFS, and DOSFS use now a generic path evaluation method. Recursive calls in the path evaluation have been replaced with iteration to avoid stack overflows. Only the evaluation of symbolic links is recursive. No dynamic memory allocations and intermediate buffers are used in the high level path evaluation. No global locks are held during the file system instance specific path evaluation process. o Recursive symbolic link evaluation is now limited by RTEMS_FILESYSTEM_SYMLOOP_MAX. Applications can retrieve this value via sysconf(). o The device file system (devFS) uses now no global variables and allocation from the workspace. Node names are allocated from the heap. o The upper layer lseek() performs now some parameter checks. o The upper layer ftruncate() performs now some parameter checks. o unmask() is now restricted to the RWX flags and protected from concurrent access. o The fchmod_h and rmnod_h file system node handlers are now a file system operation. o The unlink_h operation has been removed. All nodes are now destroyed with the rmnod_h operation. o New lock_h, unlock_h, clonenod_h, and are_nodes_equal_h file system operations. o The path evaluation and file system operations are now protected by per file system instance lock and unlock operations. o Fix and test file descriptor duplicate in fcntl(). o New test fstests/fsnofs01.
* Remove stray white spaces.Ralf Corsepius2004-04-171-1/+1
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-041-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | * src/dosfs/dosfs.h, src/dosfs/fat.h, src/dosfs/fat_fat_operations.h, src/dosfs/fat_file.h, src/dosfs/msdos.h, src/dosfs/msdos_create.c, src/dosfs/msdos_dir.c, src/dosfs/msdos_eval.c, src/dosfs/msdos_file.c, src/dosfs/msdos_free.c, src/dosfs/msdos_fsunmount.c, src/dosfs/msdos_handlers_dir.c, src/dosfs/msdos_handlers_file.c, src/dosfs/msdos_init.c, src/dosfs/msdos_initsupp.c, src/dosfs/msdos_misc.c, src/dosfs/msdos_mknod.c, src/dosfs/msdos_node_type.c, src/imfs/deviceio.c, src/imfs/imfs.h, src/imfs/imfs_chown.c, src/imfs/imfs_config.c, src/imfs/imfs_creat.c, src/imfs/imfs_debug.c, src/imfs/imfs_directory.c, src/imfs/imfs_eval.c, src/imfs/imfs_fchmod.c, src/imfs/imfs_fcntl.c, src/imfs/imfs_fdatasync.c, src/imfs/imfs_free.c, src/imfs/imfs_fsunmount.c, src/imfs/imfs_getchild.c, src/imfs/imfs_gtkn.c, src/imfs/imfs_handlers_device.c, src/imfs/imfs_handlers_directory.c, src/imfs/imfs_handlers_link.c, src/imfs/imfs_handlers_memfile.c, src/imfs/imfs_init.c, src/imfs/imfs_initsupp.c, src/imfs/imfs_link.c, src/imfs/imfs_mknod.c, src/imfs/imfs_mount.c, src/imfs/imfs_ntype.c, src/imfs/imfs_readlink.c, src/imfs/imfs_rmnod.c, src/imfs/imfs_stat.c, src/imfs/imfs_symlink.c, src/imfs/imfs_unixstub.c, src/imfs/imfs_unlink.c, src/imfs/imfs_unmount.c, src/imfs/imfs_utime.c, src/imfs/ioman.c, src/imfs/linearfile.c, src/imfs/memfile.c, src/imfs/miniimfs_init.c: URL for license changed.
* 2001-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-221-0/+4
| | | | | | | * configure.in: Add src/imfs/config.h * src/imfs/Makefile.am: Add INCLUDES += -I. to pickup config.h * src/imfs/.cvsignore: Add config.h and stamp-h * src/imfs/*.c: Add config.h support.
* Added base version of file system infrastructure. This includes a majorJoel Sherrill1998-11-231-0/+29
