path: root/cpukit/libfs/src/imfs/imfs_mknod.c (follow)
* Removed asserts that shouldn't be called and commented case where thisJennifer Averett1999-03-311-2/+0
| | | | indicates an internal error.
* Changed IMFS to use IMFS_NAME_MAX as the maximum length of a basenameJoel Sherrill1999-02-241-1/+1
| | | | | | | rather then NAME_MAX. NAME_MAX is 255 and that lets IMFS chew up memory too fast. Perhaps in the future, the places in IMFS that put a maximum length name string on the stack and the jnode structure does not include a maximu length name string can be fixed so this is not a problem.
* Added base version of file system infrastructure. This includes a majorJoel Sherrill1998-11-231-0/+76
