#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Update #3818.
Prepare for header file move to common include directory.
Update #3254.
Update #3132.
Update #2133.
Added a mmap file handler to struct _rtems_filesystem_file_handlers_r.
Updated each file handler object to support the default mmap handler.
Updated mmap() to call the mmap handler for MAP_SHARED.
Added a mmap file handler for shm
Added support for MAP_ANON in mmap().
Updates #2859
Make several functions static.
