path: root/cpukit/libfs/src/imfs/imfs_linfile.c (follow)
* imfs: Add IMFS_make_linfile()Sebastian Huber2019-11-191-1/+17
| | | | Update #3818.
* IMFS: Include <rtems/imfs.h>Sebastian Huber2017-12-131-1/+1
| | | | | | Prepare for header file move to common include directory. Update #3254.
* libio: Add rtems_libio_iop_is_writeable()Sebastian Huber2017-09-151-1/+1
| | | | Update #3132.
* Include missing <string.h>Sebastian Huber2017-08-251-0/+2
| | | | Update #2133.
* posix/mmap: Add support for file handler and MAP_ANONKevin Kirspel2017-07-141-0/+1
| | | | | | | | | | | Added a mmap file handler to struct _rtems_filesystem_file_handlers_r. Updated each file handler object to support the default mmap handler. Updated mmap() to call the mmap handler for MAP_SHARED. Added a mmap file handler for shm Added support for MAP_ANON in mmap(). Updates #2859
* IMFS: Fix copy on write for linfilesSebastian Huber2015-02-201-0/+3
* IMFS: Split linfile and memfile modulesSebastian Huber2015-02-121-0/+97
Make several functions static.
